Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 35707530 times)
0 Members and 3231 Guests are viewing this topic.
Offline FransW
« Reply #72600 on: October 19, 2020, 10:37:42 am »
Yes,
I have quite a collection of from the PM661x, PM665x and PM666x series.
It all started quite by accident or denial of TEA symptoms.
PE1CCN, Systems Engineering, HP, Philips, TEK, BRYMAN, Fluke, Keithley
Offline tonyalbus
    • My Channel
« Reply #72601 on: October 19, 2020, 10:41:35 am »
Yes,
it starts with acceptance, for a peace of mind.... but thats where it also ends, i have not seen any of us cuered  :-DD :-DD :-DD
« Reply #72602 on: October 19, 2020, 11:26:25 am »
Yeah I'm drawing them up in Kicad at some point over next couple of days and will post on here. At the moment it's on bits of paper with annotations and scribbles in pen all over it  :-DD
As any properly enginerded project will be. Carry on! :-+
« Reply #72603 on: October 19, 2020, 12:25:24 pm »
My current brain dump is easier, so I could skip ahead. A drawing mostly made to see if my brain is too broken to cram one lamp, one start, one stop button together into a 5-conductor cable to have a pump start and stop button where it's convenient. 5-conductor mains cable (Romex, NYM-J, EKK, et c) is much easier to buy cheap than say 7-core.
One set of switches goes where the skimmer sits, so one can start and stop the pump from there.
One set goes right by the filter. The old regulation central is there already, and has a rotary switch for the motor contactor (of course three-phase, only countries where Edison had too much influence run 1-phase mains to homes) , but I'm planning to replace that with a new one, up on a wall, with some new-fangled control and monitoring (acoustic cavitation monitoring, for instance) and therefore I need convenient start/stop controls where the operator can reach them.
Edit 1: This is for a pool. Forgot to write that.
Edit 2: I don't like the lack of a NC pushbutton in the KiCad library.
« Last Edit: October 19, 2020, 12:28:25 pm by mansaxel »
Offline battlecoder
  • Country: cl
    • A BIT of Mystery
« Reply #72604 on: October 19, 2020, 12:29:26 pm »
I am still trying to remember what exactly inspired me.
PM6613, 250MHz. Externally referenced.
A thing of beauty.
That's the kind of counter I ""need"".
« Last Edit: October 19, 2020, 12:39:35 pm by battlecoder »
Offline nixiefreqq
« Reply #72605 on: October 19, 2020, 12:43:23 pm »
And large electricity bill  :-DD
Forgot to mention. I have SINNED hard. I bought a non-RPN calculator. A TI-85. Forgive me.
Well what on hell happened there then eh? It is as it happens a pretty good calculator, I have 2 of them personally  :-+
he has still not proven ownership to my satisfaction.
maybe a pic of it on a local newspaper with the banner headline and date showing?
(try to make it a classy newspaper.....not something with a half naked girl on page 3)
free range primate
« Reply #72606 on: October 19, 2020, 01:13:07 pm »
Initial proof  :-DD
Anyway for my sins, the new power supply has arrived and it works perfectly:
I will say that in the insides are a bit of a mess (dirt) so I'll have to clean it out. But it works nicely.
The following users thanked this post: BU508A, med6753, mnementh, Specmaster, Kosmic, tonyalbus
« Reply #72607 on: October 19, 2020, 01:22:27 pm »
Busy as hell today being an enabler and thank gawd it's drawing to a close as tiring but nice to get away overseas  :P to Waiheke island (ferry ride) where one of our dear friends had a knees up for her 60th.
It's alright for some [nationalities].  :P
We're still waiting to have a delayed 'big birthday' of a friend from back at the beginning of the year. It was originally supposed to have happened before lockdown started. But with hints of what might be coming, and with quite a few old folks expected to be involved we all decided (Without any Governmental 'help' or 'advice', thank you very much.) to postpone in an abundance of caution.
« Reply #72608 on: October 19, 2020, 01:31:38 pm »
On other notes:
Which concert costs only 45 Cent?
50 Cent feat. Nickelback
 :palm:   :-DD    :-DD
"Reservations"
"Hi, I need to book a round trip to German and I'm going to need a luggage allowance, I have to take some very large, very heavy boots with me."
The following users thanked this post: BU508A, mnementh, bd139
Offline tonyalbus
    • My Channel
« Reply #72609 on: October 19, 2020, 01:36:05 pm »
Initial proof  :-DD
Ah yes..much nicer then the older ET30/2 i have..
Offline FransW
« Reply #72610 on: October 19, 2020, 01:52:41 pm »
Tony,
Herewith a detail from the 9927 service manual.
Frans
Offline tonyalbus
    • My Channel
« Reply #72611 on: October 19, 2020, 02:16:44 pm »
Tony,
Frans
so the Xtal will just go along with the external ref??   cool, very simple solution, Thanks
Offline FransW
« Reply #72612 on: October 19, 2020, 02:27:07 pm »
Connect and / or dis-connect with a switch.
The manual (in French):
https://elektrotanya.com/racal_dana_model_9926_and_9927_frequency_meters_up_to_1%2C3_ghz.pdf/download.html#dl
I can assist with translating relevant parts.
Frans
« Last Edit: October 19, 2020, 02:31:23 pm by FransW »
Offline PA0PBZ
« Reply #72613 on: October 19, 2020, 02:44:18 pm »
Tony,
Frans
That's strange, because the chip has an external oscillator input (pin 33), I wonder why they didn't use that:
External Oscillator Enable - In this mode, the signal at EXT OSC INPUT is used as a timebase instead of the on-board crystal oscillator (built around the OSC INPUT, OSC OUTPUT inputs). This input can be used for an external stable temperature compensated crystal oscillator or for special measurements with any external source. The on-board crystal oscillator continues to work when the external oscillator is selected. This is necessary to avoid hang-up problems, and has no effect on the chip's functional operation. If the on-board oscillator frequency is less than 1MHz or only the external oscillator is used, THE OSC INPUT MUST BE CONNECTED TO THE EXT OSC INPUT providing the timebase has enough voltage swing for OSC INPUT (See Electrical Specifications). If the external timebase is TTL level a pullup resistor must be used for OSC INPUT. The other way is to put a 22MΩ resistor between OSC INPUT and OSC OUTPUT and capacitively couple the EXT OSC INPUT to OSC INPUT. This will bias the OSC INPUT at its threshold and the drive voltage will need to be only 2VP-P. The external timebase frequency must be greater than 100kHz or the chip will reset itself to enable the on-board oscillator.
https://www.renesas.com/eu/en/www/doc/datasheet/icm7226a-b.pdf
« Reply #72614 on: October 19, 2020, 02:46:10 pm »
Update on the PL310, while working my way through the control section of the main board on Saturday evening, hence why I missed discord :palm:, I had either lifted a leg of the components, or in some cases removed them altogether and one such thing was 200K resistor. This resistor on re-installing it decided that it would jump out of the tweezers, because where it was located, it was impossible to fit any other way, and it jumped over the back of the bench never to be seen again, so will be making an order to Bitbox soon.
I found that the parts in both the voltage control and the current control all checked out OK, removed the multiplexer (CD4052) and it had zero effect on the controls. Just wondering if its possible that I somehow managed to get a batch of faulty LM324's as this is the means of control???
Had a chat with the technical dept at Aim TTi today, and they kindly emailed me a copy of the service manual as parts of the one I found online are missing, sadly the one they sent me was of a real old PL310 and the one that I require  :palm: Hopefully they will find the correct manual and send it me. They also said that were going to pop in the post to me tomorrow a pair of the shorting links that are missing on the PL310 :-+
Offline tonyalbus
    • My Channel
« Reply #72615 on: October 19, 2020, 02:55:05 pm »
Tony,
Frans
Thanks!
« Reply #72616 on: October 19, 2020, 02:57:51 pm »
Scope ball schematics attached. Disclaimer: not used to build anything yet. May be annotation errors.
The following users thanked this post: BU508A, med6753, shakalnokturn, tonyalbus
Offline 25 CPS
« Reply #72617 on: October 19, 2020, 03:05:15 pm »
I may have to mug you for that HeathKit.
>:D
Heh.  Heh heh.  Heh.  I'm either going to be mugged for that Heathkit or I'm going to get home from work in the middle of the night and find a whole bunch of empty shelves in the basement where my technical equipment used to be.
Car Electronics is also Electronics,
and about the t-shirt... we know what it is... but the wife thinks it are the nazca lines  :-DD
I just watched the video now, and speaking of the basement, I do have a dashboard from a trolleybus that was scrapped almost 30 years ago somewhere down there and the spedometer's set up the same way with a bias voltage and some sort of pulse train from a sensor on one of the wheels.  I've never done anything with it but now I'm thinking I should drag it out and put it on the bench and see if I can get the dash instruments to come to life.
The following users thanked this post: mnementh, FransW, tonyalbus
« Reply #72618 on: October 19, 2020, 03:41:22 pm »
he has still not proven ownership to my satisfaction. maybe a pic of it on a local newspaper with the banner headline and date showing?
Ummm... why...?  ???
Where's the fun in that...?
« Reply #72619 on: October 19, 2020, 04:09:03 pm »
The speedometer in my car perversely works it the other way around. The mechanical [eddy currents in a disk] speedometer sends pulses from the rotating magnet to the ECU to supply it with an indication of road speed.
« Reply #72620 on: October 19, 2020, 04:30:30 pm »
First error found. Decoupling capacitor bus not grounded  :-DD
« Reply #72621 on: October 19, 2020, 04:47:49 pm »
TTi update time, they did manage to find me a far better copy of the correct schematic this time after I sent them photos of the boards. Turns out that this is not a "brown" one after all but a "grey" one and as such is much newer. When they introduced the newer model, they decided to use up the old stock of the brown cases while the new grey ones were being made.
If anyone else has downloaded the manual and discovered the missing information for revision 4 boards, I attach the scan of that schematic below for your records.
« Last Edit: October 19, 2020, 06:41:37 pm by Specmaster »
The following users thanked this post: BravoV, bingo600, Gertjan, mnementh, bd139, tonyalbus
« Reply #72622 on: October 19, 2020, 04:54:32 pm »
The speedometer on some buses works differently, being driven by a three-phase supply generated by a small three-phase generator driven from the gearbox output shaft.
« Reply #72623 on: October 19, 2020, 05:14:11 pm »
PCB fun. Getting there. Routing is painful on this  >:(
40 minutes later:
3d view:
Fixing all the little niggles now ...
« Last Edit: October 19, 2020, 06:03:16 pm by bd139 »
The following users thanked this post: mnementh, Specmaster, factory
Offline FransW
« Reply #72624 on: October 19, 2020, 05:22:02 pm »
Can't think of anything else but "competitive pricing" as a spin-off of more sophisticated and priced models.
Compare with the HP5315, also no ref input.
On-site usage?
« Last Edit: October 19, 2020, 05:25:24 pm by FransW »
