For the second day in a row I've had to towel off TE parcels left on my doorstep. This despite the fact I leave a bright blue IKEA bag, weighed down with a length of Unistrut, on my doorstep, for the purpose of protecting my parcel from the weather.
Yesterday was the Agilent 54621D. Well packed and dry, despite the outer box turning into papier-mâché. Nice little scope, very short form factor for a CRT.
I like the UI much more than Tek scopes.
Today was the HP 6633B. This came in some of the best packing I've ever seen. Outer heavy duty black plastic bin-liner type stuff, then outer box, then various packing materials and also the wrecking ball, then an inner box, then more packing, and finally the prize.
Wouldn't have made a good pass-the-parcel game though, it weighs in at 12.2kg, with the packing adding a couple of kilos on top of that!
It's currently acclimatising, I'll give it a brief test in a couple of hours.
Looks like I'll be working this weekend; the vaccination station we put in a supply for needs more work.
They wanted a genset, and changeover contactor; we're now fitting that, with a trench having had to be re-dug to accommodate the extra armoured cables.
Oh, and they need some more lights for the walkways around the cabins, you can throw 20 or 30 of those up in no time I expect?
Then they decided they need an extra cabin for the security guards, as they don't want them in the medical areas. That's no problem, right?
Yes, it is a fucking problem, now we have to re-dig the goddam trench again, no doubt scraping even more cables and exposing the armourings, and pull another cable from the damn substation (where our main panel board is). This also means the marginally rated genset won't be big enough, but they're ignoring that problem, presumably gambling on it not having to be used, and consequently no-one noticing.
They are in for a shock, as we will most certainly do a proper test once we have everything wired in. Can't wait for the genset to fall over when we do a manual changeover...
At this rate the vaccination station should be operational by the time the covid crisis is over.
