Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 15212415 times)
Vince, wkb, SingleBitError and 32 Guests are viewing this topic.
Offline Saskia
« Reply #95675 on: July 27, 2021, 06:35:40 am »
reached agreement with realtor. Negotiating with employer.
Good deal. Hope it all falls in place.  :-+
Thanks.
Boss said that nobody said "no" yet and he is escalating to our group head plus HR and the business function.
The following users thanked this post: Robert763, Brumby, mnementh, bd139
« Reply #95676 on: July 27, 2021, 07:11:54 am »
When did the rule on using torque screwdrivers come in in the UK? I didn't see the muppet who replaced our consumer unit a couple of years ago. Mind you he managed to trip it off a couple of times. One was terminating a SWA feed for a heat pump to the isolator. He connected the MCB before the isolaotor  |O
Anyone using SMAs or precision RF connectors should have torque spanners too. I have several and a torque calibrator to set them  (cross checked with the fancy digital one at work).
« Last Edit: July 27, 2021, 07:13:50 am by Robert763 »
« Reply #95677 on: July 27, 2021, 07:22:37 am »
Uh oh, am I going to fall out of favor again if I admit that I don't own any torque tools?  :o :scared:
« Reply #95678 on: July 27, 2021, 07:28:30 am »
Take it as a good opportunity.   ;D
« Reply #95679 on: July 27, 2021, 07:37:23 am »
I'll sleep on it.  ;D
Offline tggzzz
« Reply #95680 on: July 27, 2021, 07:50:52 am »
I am using the sound of two colliding small powerful magnets as my SMS notification. Hard to miss.
That's far too missable for my ears, but it is nice :(
Irritatingly my phone only has canned choices for messages.
Offline tautech
« Reply #95681 on: July 27, 2021, 08:09:56 am »
Not with me. Us old buggers have mostly had enough experience as not to need them......cylinder heads, big ends and main bearing caps excluded.  :P
Avid Rabid Hobbyist
Offline tautech
« Reply #95682 on: July 27, 2021, 08:18:11 am »
28 years and 10 minutes since pop passed so goodnight and I'm to drink in his honor alone.  :'(  :popcorn:
Avid Rabid Hobbyist
The following users thanked this post: Brumby, mnementh, bd139, beanflying
« Reply #95683 on: July 27, 2021, 08:48:54 am »
It was only a month back you didn't own Digital Calipers so don't make us use undue enabling - AGAIN :-DD
Offline Cymaphore
« Reply #95684 on: July 27, 2021, 09:02:55 am »
Attached you see my primary WIHA TorqueVario-S 2872 handle, it can be set to 0.8 - 5.0 Nm. In my mobile case I also have a couple of fixed torque adapters for convenience (currently I don't have it with me), they can be flexibly switched but cover the most widely required values.
That WIHA slimBit 6mm system is very nice in general and can be conveniently combined. Don't know how I was able to live before it :-)
Some people are still wondering why it constantly "clicks" when I tighten critical screw terminals.
The following users thanked this post: BU508A, mnementh, Specmaster, Neomys Sapiens, Andrew_Debbie, mansaxel
« Reply #95685 on: July 27, 2021, 09:15:07 am »
Most joins are made with Wago 221's now.
Personally, I hate wire nuts, and love 221's. They are fantastic. And of course, a bit expensive. But worth it.
Marking is done, if at all, on the outlet/switch face, and indicates the fuse number and distribution board.
I don't know what you're talking about, I get them for free...   :popcorn:
When you're pulling in enough cables to fill a 3-phase 64-way board, you mark the cables or you're going to have a very bad day when it comes time to terminate them.
Torque-drivers are required by the regs here for termination into boards (ie MCBs, RCBOs, earth/neutral bars etc), though not for accessories (sockets, switches, spurs etc).
There’s something to be said in support of a proper apprenticeship scheme where a year or two of gripping and dragging cables builds sufficient strength to twist a screwdriver with sufficient force to make a properly sound connection.
Limp wristed sparkles need be shown the door and warned not to let it hit them on the way out !  :box:
Harsh words considering that we are now having an influx of the fairer sex into the trade now, who probably don't have that degree of strength in their wrists and any attempt to show the door is likely to, especially if she is a batshit crazy red head going to be rather painful  >:D
« Last Edit: July 27, 2021, 10:22:04 am by Specmaster »
Offline VK5RC
« Reply #95686 on: July 27, 2021, 09:50:50 am »
Re torque settings, as I have been playing 'a lot of bicycle' at the moment, torque settings are everywhere - I think for a very good reason - carbon fibre can be pretty brittle and I have stripped a few alloy bolt heads in my time. Park tool makes quite a nice variable torque T driver unit which takes 1/4 inch hex drive, for not crazy $.
Offline Cymaphore
« Reply #95687 on: July 27, 2021, 10:06:38 am »
If someone here already has a TorqueVario and faces such a problem, I could recommend WIHA 283108 as Adapter. I use it mostly to access cabinets and for battery terminals and such things. It's compatible with all the 6mm equipment.
Just for fun I once put the adapter into the small electronics handle, put in an 1/4" to 1/2" adapter, added a 30mm nut and gave to our mechanics guy with a serious look on my face. Made my day.
« Reply #95688 on: July 27, 2021, 10:29:50 am »
You are obviously a joke cookie.  ;D
Welcome to the nut-house!  :-DD
Offline Cymaphore
« Reply #95689 on: July 27, 2021, 10:41:41 am »
You'll get free tickets once my carrer as stand-up comedian is finally progressing. However, my kids are occasionally complaining about me being childish. Don't understand what they mean. ;-)
« Last Edit: July 27, 2021, 11:47:45 am by Cymaphore »
Offline Andrew_Debbie
« Reply #95690 on: July 27, 2021, 10:44:49 am »
Thurlby-Thandar  1503 DMM on eBay -- no bids at the moment.
Could be picked up very cheaply.    https://www.ebay.co.uk/itm/194248800504?hash=item2d3a2178f8:g:BxUAAOSwL6dg-UKo
Update - the bid snipes are starting.   . . .
Offline tggzzz
« Reply #95691 on: July 27, 2021, 11:00:26 am »
Or another: https://www.ebay.co.uk/itm/373661983722
« Reply #95692 on: July 27, 2021, 11:03:40 am »
You'll get free tickets once my carrer as stand-up comedian is finally progressing. However, my kinds are occasionally complaining about me being childish. Don't understand what they mean. ;-)
That's fine. Everyone is as old as he behaves.  8) :-DD
« Reply #95693 on: July 27, 2021, 11:06:23 am »
Finally got my second dose of Bill G nanoparticles. Installing windows on all my things now.
More seriously, full on macguyver mode today. It’s amazing that projects get 99.9% complete and then someone realises they forgot a critical part like make A talk to B  :palm:. Thus sticky tape it is  :palm:
The following users thanked this post: BU508A, mnementh, Specmaster, ch_scr, mansaxel
Offline McBryce
« Reply #95694 on: July 27, 2021, 12:11:21 pm »
Vintage Multimeter for the brave? Who'd be willing to measure 5kV (AC or DC) with this meter and these probes?
https://www.ebay.de/itm/224547972795
McBryce.
« Reply #95695 on: July 27, 2021, 12:32:25 pm »
Yeh, but its only a 3.5 digit meter, already got plenty of those.
« Reply #95696 on: July 27, 2021, 12:32:39 pm »
5100 DMM updates:
The 5100AF manual I found on-line is close but there are differences.  I orderd a 5100 paper manual from an eBay seller in the US.   Seller won't ship to the UK, so it is going to a relative.   It will get here eventually.
Most of the power supply voltage tests  reference  to TP4 / Mecca.     It is not in the best location.   I've taken the opportunity to get a pin socket to banana test lead.
More cramped then it looks in the photo  (click for larger view)
« Last Edit: July 27, 2021, 12:40:19 pm by Andrew_Debbie »
The following users thanked this post: wolfy007, bd139
« Reply #95697 on: July 27, 2021, 12:34:36 pm »
McBryce.
Why not, they did back in the day when that was a current product. I don't see why there should be a problem as long as the probes and leads are in good condition.
« Reply #95698 on: July 27, 2021, 12:37:54 pm »
I plan to use my Beckman 310  to check the +/-  300V on the Dana 5100.   I trust it more than my other meters on anything over 100V.     The plan is to get the Dana to the point where I can safely use it on high voltages.
« Reply #95699 on: July 27, 2021, 12:58:29 pm »
McBryce.
Worred about safety?   Get a brand new Simpson 260   !!    https://simpsonelectric.com/products/test-equipment/vom-multimeters/260-8-260-8p/
There is a version with a 600V CAT III rating.
« Last Edit: July 27, 2021, 01:04:12 pm by Andrew_Debbie »
