Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 36584086 times)
0 Members and 897 Guests are viewing this topic.
« Reply #96725 on: August 07, 2021, 03:59:49 am »
Gaaaaaah fuck the universe. Just spent 2 damn hours trying to get DisplayPort audio working on my PC. Then I trip over this nugget: https://www.asus.com/support/FAQ/1045437/ .... Just magic reset your BIOS. It works?!?!?!?! But why?!?!?!?!!
I am seriously not impressed with this Asus board. Hardware is fine but the firmware is awful. ASRock was better.
Now that I think of it... why are you faffing aboot with gawwdamn DP anyways? While it supposedly is "the best thing since sliced bread", in practice, since they're constantly arguing over what's going to be in the next revision, it almost never works as advertised.
Meanwhile, almost every time, unless your cable falls out HDMI just works. Version mismatch? No problem; you just get kicked back to 60FPS. But it still works.  :-//
« Reply #96726 on: August 07, 2021, 05:00:34 am »
Woah! I get busy for a little while and we go flying past 96,000 posts?!? 2000 messages just went right by. :o
meanwhile the TEA thread has a sticky from Dave and were mentions in the last mail-bag video.  :-+
Wow! I haven't watched the recent mailbag, yet, but I did see the sticky on the thread. We're not worthy!
OK, going to go watch the mailbag now.
That was very cool. Sent Dave a thank-you DM.
Congrats, Tony, on your bench getting featured! Your lab sure has grown since you first arrived. ;D
« Last Edit: August 07, 2021, 05:24:21 am by bitseeker »
The following users thanked this post: mnementh, Specmaster, tonyalbus
« Reply #96727 on: August 07, 2021, 08:04:29 am »
HDMI doesn’t just work here. I can’t shift more than 30Hz on HDMI for some reason. Also HDMI connectors are total shit. And on top of that don’t get me started on HDCP incompatibilities.
Offline Peter_O
« Reply #96728 on: August 07, 2021, 08:18:11 am »
Why did this guy make me thinking about posting it here?   :)
https://debeste.de/206261/Hochzeitstorte-f-r-Fantasy-Fans
« Last Edit: August 07, 2021, 08:20:12 am by Peter_O »
The following users thanked this post: BU508A, ch_scr, Andrew_Debbie
Offline tonyalbus
    • My Channel
« Reply #96729 on: August 07, 2021, 08:52:28 am »
Thanks, yes it has :) .. dave showed last years picture so its even worse  :palm:
The following users thanked this post: BU508A, med6753, Specmaster, capt bullshot, bd139, ch_scr, FransW, factory, cyclin_al, duckduck
« Reply #96730 on: August 07, 2021, 08:57:56 am »
I hope you have a strong floor  :-DD
Offline tautech
« Reply #96731 on: August 07, 2021, 09:03:32 am »
This year it looks far better IMO.  ;)
Avid Rabid Hobbyist
The following users thanked this post: bd139, ch_scr, cyclin_al
Offline tonyalbus
    • My Channel
« Reply #96732 on: August 07, 2021, 09:17:51 am »
Yes more Siglent  :-DD
« Reply #96733 on: August 07, 2021, 10:05:42 am »
Oculus, the info you requested in the Type 454 Horizontal Amplifier.
Voltage drop across R1014. 66.8V.
Voltage drop across R1024. Identical 66.8V.  (Trace on center line, Horizontal position centered, no signal, trigger set to Auto.)
I'll leave the scope out of the case for the rest of the day in case you need more data. I will not be on Discord later today.
The following users thanked this post: BU508A, mnementh, Specmaster, bd139, ch_scr, FransW, 0culus, tonyalbus
Offline capt bullshot
« Reply #96734 on: August 07, 2021, 10:15:52 am »
Depressed that my car brakes need replacement I've bought 500 of these HLMP-ED31-QT000 for 8euroni. If someone needs Agilent original LEDs, let me know  :-DD
Quote from: Avago Datasheet
These Precision Optical Perform ance AlInGaP and AlInGaP II LEDs provide superior light output for excellent readabil-ity in sunlight and are extremely reliable.These LED lamps are untinted, nondiff  used,  T-1¾  packages  incorporating  second  generation  optics  producing  well  defi ned spatial radiation patterns at specifi c viewing cone angles.These  lamps  are  made  with  an  advanced  optical  grade  epoxy,   off   ering   superior   high   temperature   and   high   moisture  resistance  performance  in  outdoor  signal  and  sign   applications.   The   high   maximum   LED   junction   tempera  ture  limit  of  +130°  C  enables  high  temperature  operation   in   bright   sunlight   conditions.   The   package   epoxy  contains  both  uv-a  and  uv-b  inhibitors  to  reduce  the eff  ects of long term exposure to direct sunlight.
If one reads the superlatives in the datasheet, you've probably bought the best LEDs available ever ;)
The following users thanked this post: mnementh, bd139, ch_scr, DC1MC, factory
Offline DC1MC
« Reply #96735 on: August 07, 2021, 10:18:29 am »
Do many do you want ;) ?
« Reply #96736 on: August 07, 2021, 10:28:50 am »
Stop posting Tek porn. You're going to turn my house blue  :-DD
« Reply #96737 on: August 07, 2021, 10:30:38 am »
By the way, congrats for your PhD Wolfgang. Quite an accomplishment.  :clap:
Did you note the credits mentioning at least two known members of the eevblog forum?
BTW, Congrats to Wolfgang, quite impressive what you've achieved.
The following users thanked this post: Wolfgang
« Reply #96738 on: August 07, 2021, 10:35:33 am »
Just got myself a Wavetek LT 8155 set, for £50 shipped.
Both batteries are somewhat tired, but I may be able to rejuvenate or re-cell them. More annoyingly, the only accessory included is the calibration adapter.
So now I either have to see how much WWG want for some RJ45 adapters, or have the patience to wait for some to appear on the bay of evil...
Oh, and the flash ROM lithium cell is at ~2.93V so needs replacing too.
Still, for the price, I can't complain.
The following users thanked this post: bd139, tonyalbus
« Reply #96739 on: August 07, 2021, 10:43:39 am »
None, you've seen the piles of stuff that I already have  |O |O :-DD
Offline DC1MC
« Reply #96740 on: August 07, 2021, 10:48:20 am »
OK, let's do it vice-versa, where can I get one of these LED PCB that looks like primitive display ?
« Reply #96741 on: August 07, 2021, 11:21:11 am »
Sorry, I can't figure what LED PCB you're speaking of? Need some more hints.
« Reply #96742 on: August 07, 2021, 11:56:01 am »
Congratulations from my side, too! What a nice work.   :clap:
I've downloaded and started reading it. Very interesting topic!   :-+
Thank you!
Mounty
« Reply #96743 on: August 07, 2021, 12:06:29 pm »
We both have troublesome Tek's which are driving us up the wall. But at least his doesn't threaten to burn the house down.  :palm:
« Last Edit: August 07, 2021, 12:10:59 pm by med6753 »
« Reply #96744 on: August 07, 2021, 12:07:29 pm »
Thank you!
Mounty
So do we have to call you Dr. Wolfgang from now on?  ;D
« Reply #96745 on: August 07, 2021, 12:11:00 pm »
Thank you!
Mounty
Ahem. Not me. Him!  *points to Wolfgang*  :D
« Reply #96746 on: August 07, 2021, 01:16:28 pm »
So much nope!
https://www.eevblog.com/forum/buysellwanted/agilent-34401a-286199/
Giblets, that is crusty af. I would hesitate to pay half that amount, for an HP branded 01A with obvious first-stage display driver failure.
Buy this badly listed 3478A with a lowball offer instead, and do all the data manipulation at the other end of an HPIB cable:
https://www.ebay.co.uk/itm/144142988949
I mean, if you're gonna spunk a fat wedge on an HPAK DMM at least get a modern one:
https://www.ebay.co.uk/itm/194274209080
Something for you to repair, BD?
https://www.ebay.co.uk/itm/384316119462
There's a slew of these from this seller. They're in Israel...  anyone feeling brave?
https://www.ebay.co.uk/itm/224560747072
And finally, for those who are fed up of frivolous tubes, here are some serious ones:
https://www.ebay.co.uk/itm/174874314987
The following users thanked this post: bd139, ch_scr, factory
« Reply #96747 on: August 07, 2021, 01:27:28 pm »
So much nope!
Yeah the suspicious colouring in around the edges is "interesting" as well. I'd pay 50 for it just to see though  :-DD
Those are classified as "dangerous as fuck tubes". They are microwave tubes and are chock full of Berylium Oxide.
here's a slightly less serious but still interesting tube which was used for submarine cable repeaters. You can see the level of seriousness for all these things which are roughly "thou must not fail".
Dread to think how much these tubes cost when they were new considering in the early 80s I couldn't even afford obsolete ones from the local radio shop so had to go routing through the trash and things left on the side of the street for them :palm:
As for the Sansui, I am currently readjusting my lifestyle around older technology so that might be of interest  :popcorn:
The following users thanked this post: Vince, mnementh, ch_scr, factory, syau
« Reply #96748 on: August 07, 2021, 01:29:45 pm »
At least it doesn't look like it was dragged through the desert like most Israeli stuff. If it were here I might take a shot at it. But from there? Nope.  ::)
« Reply #96749 on: August 07, 2021, 01:37:13 pm »
I'm very happy with the Sansui amp I picked up earlier this year and featured in this thread. Very clean sounding.  :-+
The following users thanked this post: mnementh, Specmaster, bd139, ch_scr
