Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 35752751 times)
0 Members and 2347 Guests are viewing this topic.
Offline ch_scr
« Reply #105275 on: October 23, 2021, 09:13:53 am »
I Built this for current measurement with a DMM or clamp meter.
It's just a C13/C14 lead cut in two and taken through a box.
The neutral is taken through the loop on top.
A variation is to replace the loop stain reliefs with 4mm safety sockets and a loop with two shrouded 4mm plugs. It can then be used with DMM or clamp meter.
Edit: my cased variac has C13/C14 connectors and I have leads with C14 on one end and a 13A socket of safeblock on the other.
Most of the power distribution around the workshop is by C13 outlet strips.
:-+ on the C13 outlet strips, wayyy more space efficient!
« Reply #105276 on: October 23, 2021, 09:29:00 am »
Yes, the C13 strip concept is Useful. I have rescued from the metal skip at work a bunch of 19" rack mount ones, with individually fused outlets. Mains inlet is Neutrik Powercon, and one is fed from my shop contactor system, the other is fixed. I also have two Schuko 19" outlet strips, one switched, one not. That together with a RJ45 patch panel takes almost all my bench 19" space. I should be getting a boat anchor rack too, if I get around to buying more anchors. Today, the only real anchor is my Solartron volt meter; the rest are small and compact. I mean, a 410b is both sleek and stylish!
Offline ch_scr
« Reply #105277 on: October 23, 2021, 11:34:01 am »
New TE day  :scared:
Got a "LEM Memobox 800" on the bay of evil for 105€, comes with 1Ph and 3Ph voltage and current cables, flexible current clamps (1Ph+3Ph) but a gorilla cut the plug of the 3Ph current clamp harness  :palm: He also seemed to have left a mark of his "feather touch" on one of the sockets.
The device itself is only held inside the shiny metal box with 2 screws, very service friendly.
Inside we finde lots of analog and digital goodness: ADC's, CPLD's, a DSP aaand... a dead 3.6V battery.
I did open it up before turning it on  :-/O but I believe the seller showed it boot-looping.
Also it is worse than useless without software, and the only place having it is tequipment.net - but for me all the links are dead?
I did shoot them an email but have not heard back  :-\
Also, the Fluke 1745 is similar but the plugs up front are different. Seems they bought LEM and did their own take on it?
Edit:
Upon closer inspection, it looks like there are two harnesses for external current sense transformers - with different cables and plugs. And one of the plugs looks like the one for the other flexible clamp. Seems like they needed two external ones and chopped up the original in a pinch? Another clue might be the 3Ph clamps beeing 2kA full scale - not enough resolution to get usefull low power logging in a domestic setting one could imagine.
The damaged socket clean up alright with a little bit of knife-and-file. Also, the box for the 1Ph clamp has the sound of something loose ratteling around inside, you know what that means  :-/O
Edit2: Ok, it looks like I might got incredibly lucky here:
The ratteling was a piece of loose glue and not only have both boxes the full 3Ph connection, meaning I get the pinout of the missing plug served on a silver platter, but also it looks like the only difference between the 200A range and the 2000A range pcb's are one resistor - 5000R on one and 500R on the other  :-/O
« Last Edit: October 23, 2021, 12:25:04 pm by ch_scr »
The following users thanked this post: Vince, med6753, mnementh, capt bullshot, cyclin_al, duckduck
« Reply #105278 on: October 23, 2021, 01:07:22 pm »
OT post. I'm my son's modify a Knight Rider model so that it sits at a more realistic height as the makers have made this particular model look like a low rider, and we need some metal rod 2.4 mm to make up replacement axles and while searching about the various likely shops, drew a blank. But I did discover a fantastic model railway shop that very few people actually know about as it is in a small building, not all shop like, in a small industrial estate in the middle of a housing estate, right here in my home City, so I thought I share the link with you all in case there are any modellers here as well. NAWTS
The following users thanked this post: mnementh, ch_scr
Offline tonyalbus
    • My Channel
« Reply #105279 on: October 23, 2021, 01:40:06 pm »
PH-163 maybe this seller for the US, i am a bit scared to order there becouse of the shipping and imports etc.
https://www.techupv.com/index.php?main_page=product_info&products_id=618978
Offline vk6zgo
« Reply #105280 on: October 23, 2021, 02:32:46 pm »
Picked a great day to skive off kite fishing as nothing much happening here.
Caught a feed for the mate and I but nothing more.  :(
It was long overdue to have the rig see the light of day...one like this:
https://www.fishingtacklesale.co.nz/product/810164
So wait... what...?
You actually wanted to catch something...?  :o
That's just unnatural. Contravenes the whole purpose of going fishing; to kill a few bottles with your mate while enjoying a beautiful day out on a boat or on a sandbar...
As soon as you catch something, then you have to do work.
ewwwwwww.
*well-known to tie a bobber and nothing else on the end of his line*
I know a bloke they call "Matthew 14:15-21", because all he does is "loafs & fishes".
« Reply #105281 on: October 23, 2021, 03:39:56 pm »
   I Built this for current measurement with a DMM or clamp meter.  It's just a C13/C14 lead cut in two and taken through a box.
The neutral is taken through the loop on top. A variation is to replace the loop strain reliefs with 4mm safety sockets and a loop with two shrouded 4mm plugs. It can then be used with DMM or clamp meter.
Edit: my cased variac has C13/C14 connectors and I have leads with C14 on one end and a 13A socket of safeblock on the other. Most of the power distribution around the workshop is by C13 outlet strips.
Oh, that's entirely too nice a bit of purpose-built kit.  :-DD
Much nicer  :-+   than my old deathtrap dim-bulb tester, which also has a current loop in the white/neutral barely seen behind the duplex.
*tzzzzzzz* :bullshit:
The following users thanked this post: ch_scr, factory, cyclin_al
Offline ch_scr
« Reply #105282 on: October 23, 2021, 03:57:15 pm »
State of the bench as of now, feast your eyes - it's not going to stay that way for long:
Also why does this (always?) feel like:
a) Doing this took way too long
b) I've waited to do this for way too long
c) I'm glad I have done it
all at the same time  :-//
« Reply #105283 on: October 23, 2021, 05:44:10 pm »
TEA today  :)
Picked up an another bunch of kit. Mostly RF. A HP 8754A Vector Network Analyser complete with manuals and screen overlays. I've now got three of these compact 4-1300MHz VNAs. They have a built-in source. No RF "test set" built in but detectors are. This means you can make two port measurements with as little as a power splitter. I also picked up  8502B Transmission /Reflection test set. This is a 75R unit with N type test port. Looks identical to the 50R A model which I already have. To go with that is a HP 85036B 75R Calibration kit (current item $3300 from Keysight). Also 75R is a R&S ZRB2 SWR bridge.
Non RF are a couple of vintage PYE resistance decade boxes.
The following users thanked this post: Vince, mnementh, capt bullshot, ch_scr, Kosmic, cyclin_al
« Reply #105284 on: October 23, 2021, 06:53:48 pm »
Discord is currently a two-man operation...  >.>
« Reply #105285 on: October 23, 2021, 07:09:19 pm »
Goddammit BU508A is telling dad jokes on Discord, disregard, disregard, DO NOT LOG DISCORD!!!
Offline dl6lr
« Reply #105286 on: October 23, 2021, 07:11:35 pm »
ALERT! I think this shop is scam. I've seen more of those shops, some with surprisingly low offers and always with free shipping, for things that are offered on eBay or other platforms. There is no legal address, only an email. If you try to find that image, you get i.e. the following links:
https://www.rwangary.top/index.php?main_page=product_info&products_id=394161
https://www.mshipusnow.com/index.php?main_page=product_info&products_id=513760
For more fun, compare this ebay offer
https://www.ebay.de/itm/283479872458?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
with this scam shop:
https://www.rangeier.top/index.php?main_page=product_info&cPath=6_43_55_978_1874&products_id=12018
https://www.nexteous.top/index.php?main_page=product_info&cPath=2_65_365_825_926&products_id=13096
Offline factory
« Reply #105287 on: October 23, 2021, 07:19:43 pm »
I tend to agree, it looks to be one of many sites that copy ePay listings.  :--
Edit: it loaded OK on my phone, but Norton really doesn't like it on the PC.
« Last Edit: October 23, 2021, 07:25:12 pm by factory »
« Reply #105288 on: October 23, 2021, 07:29:43 pm »
Aside from Amazon; if they don't accept PayPal, as far as I'm concerned, they don't exist.  :-//
*toddles off to Discord*
The following users thanked this post: SilverSolder, Specmaster, wolfy007, Bad_Driver
« Reply #105289 on: October 23, 2021, 10:57:36 pm »
Shoot.  ::) Took an afternoon nap, missed Discord. Anything exciting happen?
Edit....did BD check in? Was Saskia on and update us on her hubby?
« Last Edit: October 23, 2021, 11:00:23 pm by med6753 »
« Reply #105290 on: October 23, 2021, 11:45:41 pm »
I missed it as well, Anders posted to say that it was basically just 2 people tonight.
« Reply #105291 on: October 24, 2021, 02:04:10 am »
I got on Discord aboot a hour late. Saskia was there, but I didn't see any update aside from that he was grumpy like a grizzly bear woke up from a long winter's nap.
bd139 didn't show. I assume he had some form of MCP entanglement.  ;)
*toddles off to ded*
« Last Edit: October 24, 2021, 02:06:21 am by mnementh »
Offline Zucca
  • EE meid in Itali
« Reply #105292 on: October 24, 2021, 03:20:31 am »
Hey mansa,
what are you doing here in South Carolina USA?
It was yesterday in front of me....  ^-^
Offline Saskia
« Reply #105293 on: October 24, 2021, 05:22:06 am »
@med thx fer asking, he needs to undergo another heart surgery on Nov 5. They need to cut through scarring to free up a clogged blood vessel. They expect a. 4 hour endoscopic surgery and consider this a high risk issue. Not doing it is not an option though as you could count the days before the next cardiac attack. No fun.
In other news the building permit should arrive hopefully next week. we have a notary appointment on Friday.
Online TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #105294 on: October 24, 2021, 05:35:02 am »
Sooooo, any of you gents got a TDS500, 600 or 700 series scope and a gpib-pc interface?
If so, wanna take 10 mins and dump some firmware for me? I'm specifically looking for the elusive V5.3 firmware for my TDS784C, but any firmware I can get for any of these models I'll upload to the tek wiki.
https://w140.com/tekwiki/wiki/TDS784
Just need to follow steps 1-5 and 7 here:
https://www.eevblog.com/forum/repair/unified-tektool-released-!-(firmware-flash-tools-for-old-tds-series)/msg3758918/#msg3758918
If you can help out, you'll get the adoration and appreciation of at least one person for at least a couple minutes until the next shiny thing distracts me. :D
« Last Edit: October 24, 2021, 09:39:24 am by TERRA Operative »
« Reply #105295 on: October 24, 2021, 06:54:41 am »
Hey mansa,
I would never be caught owning a sedan! I'm strictly a estate person. (I have been known to drive sedans when renting abroad, and I and my employer are cheap, so I usually end up with a small sedan; last time it was a little GM something. )
Offline tggzzz
« Reply #105296 on: October 24, 2021, 07:57:42 am »
For what it is worth, my thoughts are with you.
The following users thanked this post: Saskia
« Reply #105297 on: October 24, 2021, 08:07:16 am »
Quickly booted up my 520 and it is running 2.16E yep I do have an Agilent GPIB adapter but never tried to hook them both together.
Might be of interest too I fell over this post and list of Firmwares and TEK models
http://www.ko4bb.com/doku2015/doku.php?id=test_equipment:tds_series_firmware
Team,
I was wondering if anyone knows what the latest firmware / software
revisions are for the three digit TDS series.
I am mostly looking for the 754 / 784 series but since the three
digit series is not being built any more, it might be a good idea to
collect this info and put in the files area for future reference.
Thanks
This is how it was about 5 years ago. Some may have changed but I doubt it. I know for sure that some 400's have a hardware depending last version and possibly that could also be true for some 500 and 700's that's why two versions are shown, I'm not 100& sure about that, though.
TDS310,F/W,2.04
TDS320,F/W,2.04
TDS340,F/W,1.09
TDS340A,F/W,1.09
TDS350,F/W,2.04
TDS360,F/W,1.09
TDS380,F/W,1.09
TDS410,F/W,2.53
TDS410A,F/W,1.02
TDS420,F/W,2.55
TDS420,F/W,2.60
TDS420A,F/W,1.02
TDS430A,F/W,1.02
TDS460,F/W,2.55
TDS460,F/W,2.60
TDS460A,F/W,1.02
TDS510A,F/W,1.00
TDS520,F/W,2.16
TDS520A,F/W,3.87
TDS520B,F/W,4.21
TDS520C,F/W,5.3
TDS520D,F/W,6.3
TDS520D,F/W,7.11
TDS524A,F/W,3.87
TDS540,F/W,2.16
TDS540A,F/W,3.84
TDS540B,F/W,4.21
TDS540C,F/W,5.3
TDS540D,F/W,6.6
TDS540D,F/W,7.11
TDS544A,F/W,3.84
TDS580C,F/W,5.3
TDS580D,F/W,6.3
TDS580D,F/W,7.11
TDS620,F/W,2.06
TDS620A,F/W,3.87
TDS620B,F/W,4.41
TDS640,F/W,2.06
TDS640A,F/W,3.88
TDS684B,F/W,4.41
TDS680B,F/W,4.41
TDS644A,F/W,3.85
TDS644B,F/W,4.41v
TDS714L,F/W,6.6
TDS714L,F/W,7.11
TDS724A,F/W,4.21
TDS724C,F/W,5.3
TDS754C,F/W,5.3
TDS724D,F/W,6.3
TDS724D,F/W,7.11
TDS724D,F/W,7.2e
TDS744A,F/W,4.21
TDS754A,F/W,4.21
TDS754C,F/W,5.11
TDS754D,F/W,6.6
TDS754D,F/W,7.11
TDS782A,F/W,4.21
TDS784A,F/W,4.21
TDS784C,F/W,5.3
TDS784D,F/W,6.6
TDS784D,F/W,7.11
TDS784D,F/W,7.4e
TDS794D,F/W,6.6
TDS794D,F/W,7.11
TDS820. F/W,2.03
TLS216,F/W,1.03
THS720,F/W,1.03
THS720A,F/W,1.16
THS710A,F/W,1.16
THS720P,F/W,1.16
THS730A,F/W,1.16
/Håkan
  • Country: jp
« Reply #105298 on: October 24, 2021, 08:16:34 am »
Yeah, I've seen that list, but trying to actually find those firmwares for download is a bit of a task....
Would be nice to start uploading them as we can find them for posterity I was thinking.
« Reply #105299 on: October 24, 2021, 10:15:39 am »
Saskia, my thoughts are with you both, he really is having a tough time right now, its a stressful time for you both, lets hope and pray that this is a successful operation for him and sets him on the road to recovery.
