I would very much like to add PV due to skyrocketing energy costs over here. Now I need to find out if other buildings are casting shadows and where it would actually make sense to set this up, and if so: on which parts of the roof.
My idea:
take a portable PV cell (like one of those 50 or 100 W gizmos), fling it onto the roof and attach an electronic load. Monitor for voltage or current drop and write out a protocol. Then look if this changes dramatically over the day.
Repeat for different areas of the roof.
Note: drone flights and just taking photos would be an option in principle, however due to new legislation are a no go unless you are a licensed operator ...
Does my approach make sense, or am I missing something ?
As others have noted, plenty of software available to do the heavy lifting nowadays. One point to note however: because of the precise construction of solar cell
arrays they are much more sensitive to
partial shading than an naïve understanding would lead one to expect. One would think that if say 10% of a panel was shaded one would expect a 10% reduction in output but that is not the case; if a long thin shadow covers 10% of the panel but 100% of the
strings of cells then the output can be almost nothing. The same applies to a shadow across a corner of a panel that might cover a small
percentage of the panel area but covers a significant
proportion of the
strings on the panel.
The reason for this is that a panel is constructed as several
strings of cells in series, with the strings then themselves connected in series. There are bypass diodes between strings so that if a string is shaded and not producing current then the current from the other strings bypasses it to continue producing power and also to avoid causing damage by creating hot spots. A picture makes it much clearer:
It's a bit like the situation with a battery pack where one of the battery cells can get reverse biased if it is undervoltage with respect to the rest of the cells in the pack. Thus if just one cell out of all the cells that make up a string is shaded it can take the whole string out of use.
So when watching out for shading of a panel, make sure to watch out for partial shading that one might naïvely think would be relatively insignificant. Dave Jones got caught out by this recently when he relocated some of his panels and put them where the apparently trivial shadow from a TV antenna pole significantly reduced the output from the whole array.
