Seems that Panaplex driver is not connecting.
Pin 20 of display PCB is unused 5th digit, pins 4 pulsed 180V, it's for 4th and 5th anode, so pin 20 is active.
From pin 20 to GND through 390k I got only few tenths of millivolts, I think it should be more.
Over 270k display PCB DP resistors were only some faint something, GND side was nothing so wafer is ok.
The machine is now left on over night but I think there is something else.
I also tried currency but got nothing, so maybe above voltages are correct, they were scoped using DSO138 and P6122.
Maybe I should connect that pin 20 permanently.
BTW,
off switch started working when supply was moved to before it.
OT,
iron is heavy, even lighter parts in large quantities.
Moving quantities is also an excellent demonstration of how near the surface is water in a human being.
OT2,
it may be a surprise that major part of fat is leaving a body through lungs.
