It's junk repair time again this week-end... yesterday a friend bought me his bathroom radiator, a large one with electronics : comes with a remote control bearing an LCD display and 2 dozen buttons.
IT's just a freaking radiator FFS....
Anyway. He bought it 15 years ago so we thought... again some old filter cap that needs to be replaced. Indeed it needed to be replaced, was completely dead, the chinese component tester had a hard time even figuring this one out.
Sadly the repair was unsuccessful because there was a bigger, more fundamental, and rarer problem : unlike all oher radiators I fixed, this one had a much more luxurious / expensive power supply design : normally it's just a zener diode with big dropper X2 film cap, but not here. Here we have a nice molded transformer, and full diode bridge, and wow, no less than 4 opto-couplers, 2 relays and two big ass SMD transistors to drive their coils. Way beefier than I have ever seen elsewhere.
The micro is located on a remote board, the front panel board, that carries the buttons and LEDs and buzzer.
Anyway, to cut a long story short.... the transformer has just one secondary, marked 24Vac, but I measured it at nearly 40 Volts !
The filter cap I measured very shy of 50 Volts across it ! It's rated also at 50V.... not good eh ? This powers the relay coils, which are rated at 24V not 48....
Then from that, they derive 5V for the micro. Only way I see they could be doing that, was a tiny TO-92 package but... it was not a regulator, it was a BC337 NPN transistor... which means they are doing the regulation "by hand", and there must be a 4.3V Zener diode next to this transistor...
Anyway, the transistor was dead and was sending 15V to the micro... yes, it was not happy about that....
So basically, somehow the transformer failed, produced a much higher voltage than was planned, and it blew everything downstream.
Radiator is 15 years old but still produced to day yet... yet the boards are not available ?! Is this a joke ?! What kind of a manufacturer is that...
So I declared this one dead, and gladly so because it takes so much space my bench is unusable for anything else, so it better get the hell out of my house ASAP. Friend said he would pick it up today
Anyway, it's the first time I see these small molded transformer fail, is that a thing, or am I just unlucky ?
