Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 36728190 times)
0 Members and 9802 Guests are viewing this topic.
Offline tggzzz
« Reply #136300 on: May 30, 2024, 02:33:44 pm »
So, it turns out modern silicon chip design is more software than hardware type work. Who would have thunk? (But it makes sense).
I'm way out of my depth here with my new job...... I am absolutely not a software person......  |O
I disagree, except in a boring literal ways.
Hardware is inherently massively parallel (duh!). That doesn't change when describing/constraining/testing a design using schematics or text. It is necessary that the text explicitly expresses the parallelism (standard computer languages fail to manage that).
The way the design is expressed looks like the syntax of a classic software language, but the semantics are completely different. That causes never-ending problems for softies that think it is easy to convert from C/etc to VHDL/Verilog.
OTOH, yes, you do need to understand text editors/IDEs and compilation. Big deal :)
OT3H, the compilation tools are massive, and there is a significant learning curve. That's because hardware is complex :)
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #136301 on: May 30, 2024, 02:39:36 pm »
I much prefer working with schematics and PCB's than code. To my eyes, VHDL may as well be C or Python or etc etc... Just give me a schematic and some resistors. :-DD
Offline CalibrationGuy
« Reply #136302 on: May 30, 2024, 03:27:40 pm »
Could not help myself. Gotta stop doing this...
OK, drumroll please!
See pic.
TomG.
For a moment I thought I was having a heart attack, but it was actually just my wallet cramping up and hurting when I looked at that picture.
McBryce.
Funny, I had that same feeling, now I know what it is....
TomG.
Offline Vince
« Reply #136303 on: May 30, 2024, 03:37:18 pm »
Congratulations on your new job Terra !  ;D
A whole new set of skill to be acquired... then once you have become an expert you can help us out on the forum ! :popcorn:
I never played with that stuff, all I can remember from 30 years ago is the VHDL was an absolute pain when trying to make logic hips out of an FPGA because you just couldn't control the propagation delays so the chip could have erratic behaviour even though on paper it was perfectly functional... but to be fair I also seem to remember, many years later, that somehow that problem was largely overcome and now designers didn't have to care all that much about it, and could draw whatever they wanted and somehow the FPGA would actually do what it was intended to do.
I guess the compilers were much improved ?!
Yes I know absolutely squat... and I don't see that changing since I don't quite see what use I could have for that kind of stuff as a hobbyist...
Anyway, it's cool that your new employer is giving you a chance at this, even though he knows you know squat about it.
I don't see that kind of miracle happening over here. They only employ people that have a good Eng. degree from a reputable expensive private school, and are already masters in their field, beginners ignored.
Have fun...
Offline tggzzz
« Reply #136304 on: May 30, 2024, 03:55:15 pm »
You can't do that with conventional digital logic designs, either.
You have to structure the design so min/typ propagation delays are unimportant.
You have to state the clock period and external timing requirements, in the form of constraints.
It is then up to the compiler, and place and route tools to fiddle around with the internal implementation to meet those constraints.
If that can't be achieved, then you have to restructure your design.
That should remove "erratic" behaviour. Whether the (non-erratic) behaviour is correct is something your tests ought to reveal :)
« Last Edit: May 30, 2024, 03:57:59 pm by tggzzz »
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #136305 on: May 30, 2024, 04:02:56 pm »
3585A - searching the problem: input section
The following users thanked this post: ch_scr, factory, duckduck
Offline factory
« Reply #136306 on: May 30, 2024, 05:37:25 pm »
Wow thanks for all the hard work you put into little guy, he must love you so much by now !  :D
Incredible for the probe tip ! I thought it missing would be a show stopper and condemn little guy to the trash... and in the end it was a standard part, who would have thought !!  :wtf:
The tolerance on anything with a glass envelope is rather..wild. Like that Nik-c tube on my Rochar DVM that just won't fit at all inside the tube bracket...... or like you here, light bulbs that won't !
Luckily small light bulbs you can buy lots of, for cheap... so you can just pick one that fits.
Thanks for your work ! :-+
And thanks for sending him to me, to repair, will put him to good use next time I'm fixing one of the IC based counters.  ;)
The irony with the 3406A probe accessories, is the isolator probe accessory that these screw on tips are for is missing from the set, as you can see there is a choice, but only the sharp pointy tip would have been supplied with the 10525A.
The witches hat & two sleeves at the top of the picture are not part of the set either.
I know what you mean with glass parts that don't fit, seem to remember trouble with some cheap flanged neons for the power switches, that also don't fit well.  |O
« Last Edit: May 30, 2024, 05:39:38 pm by factory »
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #136307 on: May 30, 2024, 06:03:46 pm »
Absolutely agree, the 3458As are a rare case where time works in your favour.
The drift of the LTZ1000 does significantly decrease over time, so the new ones need some years to stabilize ...
« Reply #136308 on: May 30, 2024, 07:00:14 pm »
I guess I'll see about the drift. I have an array of 732s to check that out. My reference 3458a drifted 1.6ppm in 20 months. Non 002 option, BTW.
TomG.
Offline Wolfgang
« Reply #136309 on: May 31, 2024, 12:11:02 am »
002 Option just selects the initial error. I guess those have been pre-aged a little bit :). Any, after a few years the drift should decrease significantly.
« Reply #136310 on: May 31, 2024, 06:36:37 am »
And it does!
Offline Wolfgang
« Reply #136311 on: May 31, 2024, 10:16:01 am »
My box is a first or second generation one with a complete Keysight refurbishment (new caps, line filters, fan, front panel, VFD, nonvolatile memory, ...)
So I guess the LTZ1000 is about 20 years old. Nice !
Offline McBryce
« Reply #136312 on: May 31, 2024, 12:09:11 pm »
Unless... They swapped the LTZ1000 as part of the refurbishment too? :D
McBryce.
Offline Wolfgang
« Reply #136313 on: May 31, 2024, 05:07:50 pm »
No, its also vintage :)
Offline m k
« Reply #136314 on: June 01, 2024, 11:21:06 am »
Fluke version.
Offline m k
« Reply #136315 on: June 02, 2024, 06:44:55 pm »
(An addendum for the shaded device)
First happened so that I ordered a set of six AA to C adapters from ePay and got one, next try from T emu was a fast success.
But the place is too tight, maybe correct but too tight anyway.
So sub-C order is placed, but then what.
I remembered that I've saved a 18V battery from lawn trimmer, for identification purposes.
So no problem, ripping that two decades old battery apart and dang, six cells have life, sane also, around 1V.
Now four of them are charging, 120mA and 6.1V, and keeping their cool.
  • Country: jp
« Reply #136316 on: June 04, 2024, 03:41:10 pm »
Hello to my European friends! I have a small favour to ask....
I would like to purchase 20 or so of these, is anyone in Germany able to buy a bunch and sent them to me in Japan in return for a Paypal transfer? :)
https://www.buerklin.com/en/p/staeubli-electrical-connectors/laboratory-connectors/22-1050/12F170/
« Reply #136317 on: June 04, 2024, 03:59:42 pm »
Panel mount plugs? That's an odd one, what're you building?
  • Country: jp
« Reply #136318 on: June 04, 2024, 04:10:52 pm »
Just some 4-wire shorting plugs, and 4-wire banana to BNC adapters to enable me to connect the kelvin resistance standards I am making for my LCR meters directly to my multimeter. :)
The following users thanked this post: AVGresponding, duckduck
Offline wkb
  • PA1WBU
« Reply #136319 on: June 04, 2024, 04:11:52 pm »
If no volunteers appear from DE I guess I can order them for you from NL?
« Reply #136320 on: June 04, 2024, 04:47:25 pm »
 Staubli have a office in Japan  :)
https://www.staubli.com/jp/en/about-us/who-we-are/staeubli-japan.html
Even if the won't sell direct (or give you samples  8) ) they may be able to point you to a local stockist.
I have a few in stock but not 20....
Edit: The 22-1054 might be a better choice. It has a M3 female thread so you won't have a stud sticking out of your short.
Cheap Farnell / Newark versions https://www.farnell.com/datasheets/3098896.pdf
« Last Edit: June 04, 2024, 04:54:44 pm by Robert763 »
« Reply #136321 on: June 04, 2024, 05:10:24 pm »
@TERRA Operative
I'm a Bürklin customer, so I think, I can help here.
20 pieces of the order number 12F170 are EUR 37.60 plus 19% VAT and shipping.
What about Robert's suggestion?
Those have the order number 12F160 and 20 of them cost 25.40 plus VAT and shipping.
Let me now if I should order them for you.
  • Country: jp
« Reply #136322 on: June 05, 2024, 04:37:55 am »
The part I am looking at seems to be actually discontinued (unless I'm looking at things wrong?) so I was thinking that availability was down to what suppliers have in stock.
I'll send off an email to Staubli Japan and see what they say. If no-go, I'll ping back here to work something out. :)
I'm looking at using the stud version as I need to space it from the board for longer reach to get around the deep-ish sockets and the rubber bumper around the front panel on my 34461A (some of my boards are a bit larger than the edge of the front panel).
I'll check out the Multicomp ones too, thanks for the link, although Farnell etc don't operate in Japan it seems..
« Last Edit: June 05, 2024, 04:40:18 am by TERRA Operative »
Offline m k
« Reply #136323 on: June 05, 2024, 08:25:34 am »
20 range is silent.
It can't make its mind between 9.99 - 10.1 so generally it's sort of like spot on.
After many hours its disagreement with its self has widened, maybe it's cooking maize.
Leftover cells could do a difference in EY503, if I could find out how to open the battery case without a chainsaw.
Last first charge of new pack long ago didn't go well, the pack missed a temp sensor.
Now after next recharge it's back to its more steady state.
And is more steady than first time, after who knows how long hibernation.
It's actually quite difficult to charge those cells without a proper power supply.
I left charging on over night, but current was very safe, maybe under C/20.
Finally stopped next day when 6V was giving 30mA.
If memory serves the original charge time was 3h.
The following users thanked this post: factory, duckduck, BILLPOD
Offline McBryce
« Reply #136324 on: June 10, 2024, 02:36:19 pm »
Anyone in Germany looking to buy a boat load of anchors? https://www.ebay.de/itm/285901090089 (not my stuff).
McBryce.
