I was playing around a bit earlier, and the result is a few more pictures, which will be split up accordingly.
Intensity/ColorgradingThat turned out really well; I've seen much worse—Good!
With Colorgrading, you can't adjust the intensity (same like Rigol DHO).
But since it already looks good as is, it's not really necessary.
XY ModeNothing exciting—just standard.
The screen is a bit too small for my taste, but other than that... standard.
DecodeI quickly checked it with a UART signal from the demo board.
There are a total of decoder channels.
I’ll test the remaining decoders as well.
Since I’m going to show screenshots of all the scope’s menus anyway, there aren’t that many of them.
Then, as requested, I fed in a square wave signal again—first at 1 MHz, then 20Mhz and 50 MHz.
It looks good, and of course it depends on the generator.
Then there's another unpleasant issue that I had to deal with on at least two channels.
But I'll get to that in a moment.
