Author Topic: What about this?  (Read 2290 times)
Offline scrub332Topic starter
What about this?
« on: May 16, 2016, 08:40:12 pm »
Looking through the various eBay listings for multimeters and I come across this dodgy looking thing.
http://www.ebay.co.uk/itm/Digital-LCD-Multimeter-Ammeter-Voltmeter-AC-DC-OHM-Circuit-Voltage-Tester-Buzzer-/182072250196?hash=item2a645a0f54:g:uhEAAOSwZG9Wj46q
How bad is it going to be in terms of safety?
Offline rob77
  • Country: sk
Re: What about this?
« Reply #1 on: May 16, 2016, 08:48:04 pm »
at that price it's going to be really bad - basically usable only for small voltages up to 50V max.
Offline Lightages
  • Canadian po
« Reply #2 on: May 16, 2016, 09:07:36 pm »
What rob77 said. It is a low priced piece of junk that might work or let you down when you need to depend on it. It will also be unsafe for anything over CAT1.
Offline JPortici
« Reply #3 on: May 17, 2016, 07:12:44 am »
aha! i've had the same one since forever. it was the go-to 10€ multimeter for us students back in high school
Same form factor only that it's all yellow (orange-y) and no backlight
Offline Whales
    • Halestrom
« Reply #4 on: May 17, 2016, 07:32:07 am »
By all means go for a cheapie if it's your first meter (I'm assuming).  Just don't use it for anything above 50V, as suggested by Rob.
Later on you can look at better meters.  Until then, get your hands on anything.
« Last Edit: May 17, 2016, 07:36:44 am by Whales »
