Another vote for Probemaster.
Between the 8000 and 9000 series', the modular 9000 series makes better sense for electronics IME. The reason is the connector ends don't pop off in instances the 8000 series would due to the connector + probe weight hanging off of the test point/pin/leg. You can prop them up of course, but it gets annoying if you have to do this all the time.
The 8000 series probe body is really nice to handle, and are excellent if you don't use connectors all that frequently. And if you've the budget, I'd recommend both (i.e. set of 8000 probes only + 9000 series kit).
Their spring loaded probes are also excellent (8000 series softie body w/ pogo pins).
Regarding value, you can get a set of bare probes (
8000 lead only), the deluxe electronics kit (
9104), and spring loaded kit (
815x) for less than a Fluke TLK287 kit (not only less money, but you get more pieces).
