As I mentioned above, the Amprobe MTL-90B probes that came with my AM-130 aren't bad. PVC coated, so they don't drape very well. However, the gold (or gold-tone) plating on the tips gives them nice characteristics for continuity testing and stable resistance readings.
After rejecting some Fluke TL71s from Amazon as possibly/likely counterfeit, I decided to try some others.
I ordered a set of the Pomona 5519A probes, new and in the box, from eBay, along with a set of Franky's Brymen leads (
http://www.ebay.com/itm/171162377470 ) that looked similar to the stock Amprobe leads, but with silicone insulation.
The Pomonas disappoint. The tip coating, even after cleaning, doesn't give terribly reliable resistance readings. Worse, they cause the continuity buzzer on my non-latching meters (Amprobe AM-130 and Greenlee DM-820a, both made by Brymen) to cut out, waver, and scratch simply by rubbing the probe tips together. My Fluke 77-IV, with its latched continuity buzzer, can even be made to cut out from time to time. The silicone does give them a nice drape without kinks and tangles.
However, the Brymen leads in the link above are just top-notch. The silicone wires lay out flat, and, best of all, the tips give nice consistent readings on all three meters, with perfect operation of the continuity buzzers. I love them already. For 17 USD shipped, they're a good deal.
Now that I've looked at the Probe Masters a bit more, it looks like they'd be competitive as well, and supplied closer to home.
