Poll
279 (28.2%)
446 (45.1%)
49 (4.9%)
51 (5.2%)
165 (16.7%)
Total Members Voted: 808
Author Topic: Flir E4 Thermal imaging camera teardown  (Read 5548338 times)
0 Members and 265 Guests are viewing this topic.
Offline mrflibble
« Reply #2625 on: December 29, 2013, 06:47:32 pm »
I think it may be related to this ...
Shift range of raw values because that is handy for some operation or other (panorama) ...
RAW Temp Range from sensor : 0 27773
convert.exe: divide by zero `14020.368/(0.02656248*(65535*u+-1.0*7342))' @ error/fx.c/FxEvaluateSubexpression/2191.
0 <= 7342 <= 27773
« Last Edit: December 29, 2013, 06:58:38 pm by mrflibble »
Offline tomas123
« Reply #2626 on: December 29, 2013, 07:15:55 pm »
we both understood why the panorama stitching can results in out of range values (logarithm)
I never used flir.php with self generated images and every user can simple edit the script for his requirements
we have here a nice fork for batch converting of images
https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg350556/#msg350556
last week I posted
https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg352778/#msg352778
and changed my lines 173 ff for better color tables
// extract color table, swap Cb Cr and expand video pal color table from [16,235] to [0,255]
// best results: Windows -colorspace sRGB | MAC -colorspace RGB
exec($exiftool.' '.$flirimg.' -b -Palette | '.$convert.' -size "'.$exif[0]['PaletteColors'].'X1" -depth 8 YCbCr:- -separate -swap 1,2 -set colorspace YCbCr -combine -colorspace sRGB  '.$embpal);
//  clip BT.601 offset, the brightness is limited (16..238?)
exec($convert." ".$embpal." -level 4096,60928 ".$embpal);
Offline OrBy
« Reply #2627 on: December 29, 2013, 07:25:55 pm »
Whoa - everyone has been busy this morning!
Ok - I am for sure opening the offending panoramic.jpg's in FLIR Tools and re-saving them. It does not affect every one that I have done but it does affect a few so it does not seem like a one off issue.
I do wonder if I am actually causing this or if it has to do with the fact that I am choosing to not crop the image in MS ICE before processing them though splitjpg.php?
Here is one of the images that seems to fail when running though flir.php
http://members.shaw.ca/orby/FLIR/panoramic.jpg
Offline mrflibble
« Reply #2628 on: December 29, 2013, 07:31:32 pm »
Of course. I'm not trying to diss you; I quite like the work you're doing. All I am trying to point out that the error message does indicate a div by zero. Why that is (user error, dev error, exploding cpu error), I don't care, div by zero is div by zero. Which was my point to begin with.
At any rate, regardless of intentions, do you see now that div by zero is occuring? What you do with this info is obviously entirely up to you because it's your code. All I try to do is point out what I think is happening, and is causing that error.
Offline tomas123
« Reply #2629 on: December 29, 2013, 10:26:53 pm »
I don't think, that the bold expression goes to zero:
u is RAW Sensor value => Integer
u   (0.02656248*(65535*u+-1.0*7342)
0   -195,0217282
1   1545,750399
2   3286,522525
3   5027,294652
4   6768,066779
5   8508,838906
6   10249,61103
7   11990,38316
|O |O   I wrote myself, that Imagemagick u range goes 0...1 (float) |O |O
Flir formula goes out of range, if RAW value less then abs(Planck_Offset)
this only happens with self made RAW values (i.e. panorama)
I changed flir.php from
exec($convert." raw.png -fx \"($B/ln($R1/($R2*(65535*u+$O))+$F)-$Smin)/$Sdelta\" ir.png");
to
// check RAW value > |Planck Offset|
// x?y:z  Imagemagick ternary conditional expression, returns value y if x > 0, otherwise z
exec($convert." raw.png -fx \"($B/ln($R1/($R2*((65535*u+$O)?(65535*u+$O):1))+$F)-$Smin)/$Sdelta\" ir.png");
« Last Edit: December 29, 2013, 10:32:20 pm by tomas123 »
The following users thanked this post: railrun
Offline OrBy
« Reply #2630 on: December 29, 2013, 11:26:03 pm »
tomas123 - you nailed it - all images process without any issues now.  :-+
If it were not for the fact that it's -27C outside with a windchill making it -37C (-35F for the people south of me) and my cold - I would be running around outside making pano's all night! ;D
For now indoor ones will have to do.
Offline tomas123
« Reply #2631 on: December 30, 2013, 08:54:05 am »
another topic,
some informations to lens
What is the relationship between lens f-number and camera performance or NEdT?
http://www.flir.com/cvs/cores/knowledgebase/index.cfm?CFTREEITEMKEY=341&view=37198
By assigning a value of X to variable 1, and Y to the NEdT value of the camera using optic X, then the normalized value (to f/1.0) can be calculated as:  (1.0÷X)² x Y.
As an example, assume a thermal imager with an NEdT of 87mK using an f/1.6 lens.
To normalize its performance to f/1.0, the calculation is:
(1.0÷1.6)² x 0.087; or (0.625)² x 0.087; or 0.3906 x 0.087; equals 0.03398; which is 34.0mK.
This means that a camera with an f/1.6 optic has about 2.5 times less thermal sensitivity than the same camera with an f/1.0 lens.
The E8 FOV calculator is now online
http://flir.custhelp.com/app/utils/fl_fovCalc/pn/63903-0303/ret_url/%252Fapp%252Ffl_download_datasheets%252Fid%252F15
Camera: 63903-0303; FLIR E8
Focal length: 6.6 mm
Resolution: 320 × 240 pixels
Field of view in degrees: 44.80
Close focus: 0.5 m (1.6 ft.)
D0.501.002.005.0010.0025.0050.00100.00m
HFOV0.410.821.654.128.2420.6141.2182.42m
VFOV0.310.621.243.096.1815.4530.9161.82m
DOF near0.320.470.620.760.820.870.880.89m
DOF far1.12InfinityInfinityInfinityInfinityInfinityInfinityInfinitym
IFOV1.292.585.1512.8825.7664.39128.79257.58mm
Legend:
D = Distance to target in meters and feet
HFOV = Horizontal field of view in meters and feet
VFOV = Vertical field of view in meters and feet
DOF near = Depth of field near limit in meters and feet
DOF far = Depth of field far limit in meters and feet
IFOV = Instantaneous field of view (size of one detector element) in millimeters and inches
with http://en.wikipedia.org/wiki/Angle_of_view
I calculate a Flir Ex sensor size of 4,5mm x 3,0mm
« Last Edit: December 30, 2013, 10:08:04 am by tomas123 »
Offline mrflibble
« Reply #2632 on: December 30, 2013, 09:04:04 am »
0   -195,0217282
1   1545,750399
2   3286,522525
3   5027,294652
4   6768,066779
5   8508,838906
6   10249,61103
7   11990,38316
Quite. But I decided not to rub it in (too much) at the time. That never helps for getting a solution. But now that you already fixed it (nice one!  :-+) I can do a told you so!!! ;) ;) ;)
I still haven't had enough time to mess with panorama's but your results look great. So I will surely borrowgrabstealninjabuildupon some of your php code in the future for that. Keep up the good work! :)
Offline daves
  • Country: cz
« Reply #2633 on: December 30, 2013, 06:40:30 pm »
Good job again ! I have also updated batch version here https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg350556/#msg350556
Batch Thermal Images Editor (JPG, BMT, SNP, IRI, ISI, IS2, PGM, TIF, IMG, BMP):  https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg350556/#msg350556
Offline tomas123
« Reply #2634 on: December 30, 2013, 07:17:38 pm »
for fans of calibration values I collected Planck values of 21 Flir E4 Cameras from this forum
the values are good to estimate the valid range
$ exiftool -cameraserialnumber -cameramodel -camerapartnumber -Planck* -T  * | sort -u
63900644 FLIR E4 63901-0101 14020.368 1382.9 2.5 -7342 0.02656248
63902276 FLIR E4 63901-0101 16100.758 1423.8 2.5 -7565 0.027524546
63902871 FLIR E4 63901-0101 13065.324 1362.1 2.5 -7426 0.026384041
63902926 FLIR E4 63901-0101 14616.754 1395.2 2.5 -7634 0.027545726
63903757 FLIR E4 63901-0101 15424.458 1411.1 2.5 -7669 0.027808052
63903771 FLIR E4 63901-0101 15623.854 1414.9 2.5 -7683 0.02773639
63903946 FLIR E4 63901-0101 15258.479 1407.9 2.5 -7484 0.027325163
639047xx FLIR E4 63901-0101 14469.053 1392.2 2.5 -7489 0.026838331
63905144 FLIR E4 63901-0101 15565.878 1413.8 2.5 -7702 0.028072728
63905150 FLIR E4 63901-0101 14366.53 1390.1 2.5 -7424 0.026818641
63905373 FLIR E4 63901-0101 13906.795 1380.5 2.5 -7472 0.027203841
63905649 FLIR E4 63901-0101 14911.534 1401.1 2.5 -7619 0.027500641
63906373 FLIR E4 63901-0101 14957.009 1402 2.5 -7386 0.026861623
63906375 FLIR E4 63901-0101 15038.183 1403.6 2.5 -7572 0.027612705
63906504 FLIR E4 63901-0101 14631.607 1395.5 2.5 -7614 0.027706234
63906582 FLIR E4 63901-0101 14871.23 1400.3 2.5 -7575 0.027825247
63906738 FLIR E4 63901-0101 15119.786 1405.2 2.5 -7652 0.027600825
63906800 FLIR E4 63901-0101 14187.615 1386.4 2.5 -7541 0.027075034
63906811 FLIR E4 63901-0101 14221.295 1387.1 2.5 -7543 0.027224826
63907847 FLIR E4 63901-0101 14454.367 1391.9 2.5 -7504 0.027200488
63908691 FLIR E4 63901-0101 13780.099 1377.8 2.5 -7324 0.026437858
and a fast google picture search:
$ exiftool -cameraserialnumber -cameramodel -camerapartnumber -Planck* -T  ../google/* | sort -u
63900032 FLIR E8 63904-0101 15206.969 1406.9 2.5 -7453 0.027209383
63900279 FLIR E8 63903-0303 13181.149 1364.7 2.5 -7297 0.026171871
63900287 FLIR E6 63902-0202 24583.551 1546.9 1 -8056 0.030313723
63900288 FLIR E8 63903-0303 23907.283 1538.5 1 -7877 0.02959899
63900327 FLIR E5 63905-0501 14187.615 1386.4 2.5 -7322 0.026472446
63900337 FLIR E4 63901-0101 14513.211 1393.1 2.5 -7355 0.026683211
63900344 FLIR E6 63902-0202 14926.68 1401.4 2.5 -7461 0.027109843
63903538 FLIR E4 63901-0101 15597.475 1414.4 2.5 -7520 0.027363654
63904401 FLIR E4 63901-0101 14395.749 1390.7 2.5 -7534 0.027263179
63905648 FLIR E4 63901-0101 14557.501 1394 2.5 -7524 0.027254194
63908674 FLIR E4 63901-0101 14671.283 1396.3 2.5 -7578 0.027321232
63908976 FLIR E4 63901-0101 14459.261 1392 2.5 -7533 0.027230503
interesting, there  are two cams with Planck F = 1.0 on Flir Shopping Site (s/n 63900287 and 63900288):
(images from preproduction model?)
- http://www.revizeshop.cz/fotky29448/fotos/_vyrd11_329FLIR0016.jpg
- http://www.tequipment.net/FlirMSXMulti-SpectralDynamicImaging.html with E8_Transformer_mounted_on_ceiling.jpg
Planck constants:
http://u88.n24.queensu.ca/exiftool/forum/index.php/topic,4898.msg23972.html#msg23972
boundary condition:
     object distance = 0
     external optics transmission = 1.0
T = B / ln(R1/(R2*(S+O))+F)
T = object temperature in Kelvins
S = 16 Bit RAW value
R1  Planck R1 constant
R2  Planck R2 constant
B   Planck B constant. Value range 1300 - 1600.
F   Planck F constant. Value range 0.5 - 2.
O   Planck O (offset) constant. Its a negative value.
ln() natural logarithm
calibration:
- sample for low temp. https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg348622/#msg348622
- Excel sheet https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg350457/#msg350457
manual of GenICam ICD FLIR AX5 Camera
http://www.workswell.cz/manuals/flir/hardware/Ax5_models/ICD_GenICam_ICD_FLIR_Ax5_Camera_PC.pdf
Temperature (in Kelvin) = B / log(R / (S - O) + F)
S is the 14-bit digital signal value.
log(x) is the base-e logarithm of the x parameter.
R Planck R constant
B Value range 1300 - 1600.
F Value range 0.5 - 2
O (offset) constant
« Last Edit: December 30, 2013, 11:33:14 pm by tomas123 »
Offline tomas123
« Reply #2635 on: December 30, 2013, 08:44:12 pm »
here comes the analysis
The tolerance of sensors are relatively little versus errors in measurement
This does not explain the large measurement errors of Ex at temperatures below 0 degrees.
see discussion
Today I took a look at the datasheet for the E4 and it says as follows.
Measurement
Object temperature range–20°C to +250°C (–4°F to +482°F)
Accuracy ±2°C (±3.6°F) or ±2% of reading, for ambient temperature
10°C to 35°C (+50°F to 95°F) and object temperature above +0°C (+32°F)
and
There has been some discussion on the accuracy (or lack thereof) of the E4 at low temperatures.
I just found the pictures I took some time ago when we had a nippy spell here in the UK. The temperature on the evening when the pictures were taken was +2 Degrees Celsius. I measured the concrete slab and wall with a thermocouple and an IR thermometer. Both confirmed a true surface temperature of +2.5 Degrees Celsius on the wall and  and +2.0 Degrees Celsius on the slab.
As can be seen from the pictures, the E4 was somewhat confused in its measurement of the brick wall and concrete slab Temperatures. Both surfaces were dry and clean.
https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg348761/#msg348761
« Last Edit: December 30, 2013, 10:52:57 pm by tomas123 »
Offline olsenn
« Reply #2636 on: December 30, 2013, 08:54:10 pm »
Can someone please tell me what progress has been made since the 3b resolution hack and taucher's beta2 mod? I saw reference to a zoom function etc. Are these features going to be added to the menu hack?
Offline daves
  • Country: cz
« Reply #2637 on: December 30, 2013, 11:08:30 pm »
Well, I though cameras were calibrated in ambient 20°C. But it is not working either.
Now outside is somewhat -5°C, digital thermometer on swimming pool wall is reading +2°C and it can be true, since water in is not freezed.
When I am with camera inside, in 22°C and just slide a door a little, point it out at pool, it says -7°C and when I point on any other thing, it says like -13°C.
So I though error is caused by low temperature of camera, but this seems not be true.
Why should we replace calibration values with better ones, when camera should be calibrated from factory ? Any explanation ?
Offline OrBy
« Reply #2638 on: December 31, 2013, 12:46:04 am »
Just feel like posting a quick pano image. I cannot thank everyone enough for how much awesome has come out of this thread.  :-+
Offline Fraser
« Reply #2639 on: December 31, 2013, 01:00:13 am »
Did someone say the panoramic feature in FLIR Tools+ is not very good  ?
I ask because I have Tools+ but have yet to load it. The Panoramic feature was one that I was looking forward to using. So is it cr*p and in what respects ? Any insight appreciated.
Offline tomas123
« Reply #2640 on: December 31, 2013, 01:13:19 am »
Flir Tools is a great software, but the panorama function is extremely bad if you have more then 4 images (multi row, correction of distortion, cross-fade)
try the free 30 day trial Tools+ (a part from Flir Tools)
here is a sample (stitched from 8 images , see my tutorial https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg348715/#msg348715 )
Flir Tools+ (original size)
see the ghosts images at second columns head and the balustrade
and the same images resized and converted with the free Panorama Software MS ICE
this is a relative good result for FlirTools+ (I shoot the images with tripod)
If you have rotated images like OrBy's engine bay then FlirTools+  :--
Flir want sell cameras with large sensors and not software solutions.
The imprint of the color scale and a logo in an original E4 image with 80x60 sensor pixels is cheating
« Last Edit: December 31, 2013, 11:27:58 am by tomas123 »
Offline Fraser
« Reply #2641 on: December 31, 2013, 01:52:19 am »
Thanks tomas123,
That was exactly what I was asking for. I now understand the issue a little better  :)
I already have FLIR Tools+ as FLIR were kind enough to gift me the upgrade after I sent them feedback on my cameras and the Tools software. I have been using the standard Tools software and have not got around to upgrading it to the + version yet. It will be nice to have the recording facility as well.
Thanks again for taking the time to answer my question with those very informative pictures.  :-+
« Last Edit: December 31, 2013, 01:54:48 am by Aurora »
Offline OrBy
« Reply #2642 on: December 31, 2013, 03:05:50 am »
My new ebay micro USB cable came today.
To address the poor placement of the USB port and the chance to damage it since it's not re-enforced that well I picked up a cable with a 90 degree bend in it.
Fits nice and stays flush and there is only a fraction of force being put on it from the rubber flap now.
Now recording video with vdub does not feel like as much of a gamble, and since it's a 6ft'er I am not so tied to the PC.
« Last Edit: December 31, 2013, 03:12:54 am by OrBy »
Offline Fraser
« Reply #2643 on: December 31, 2013, 11:42:51 am »
I bought one of those leads as well. The down side for me was that it was quite hard to get a grip on the plug to remove it, thanks to the recessed socket. I was actually concerned that I was placing more force on the socket in my efforts to remove the right angled plug  :( Is your particular cable easy to unplug from the camera ?
Offline OrBy
« Reply #2644 on: December 31, 2013, 01:02:48 pm »
Mine is very tight as well but I was thinking that adding a zip tie as a small pull tab may help. I am going to try later today.
Offline Fraser
« Reply #2645 on: December 31, 2013, 02:01:42 pm »
Good idea. I found I was pulling on the strain relief too much and that caused lateral force on the socket. It really is a great pity that the E4 design team chose such an awful connector but we must do what we can with what is provided. I looked at making a micro to mini USB adapter that would permanently sit in the socket recess. Sadly there is not enough depth for  the plug and sockets that I found. I have decided that if my micro USB socket fails I will do some surgery on my E4 and fit a decent connector.... it does not have to be a standard USB type so other options are available.
My FLIR PM series cameras use quality LEMO connectors but they have the down side of being VERY expensive  :( Quality costs  ;D
Offline madshaman
  • ego trans insani
« Reply #2646 on: December 31, 2013, 02:13:13 pm »
A bit OT, but a fun game to play with a hacked E4 is thermal hide and seek.  Have the hider(s) wear bare feet, start where you are, then close your eyes and give them the count of ten to hide.
Their feet will leave behind big bright footprints for you follow :-)
I played this with my better half until she started tip toeing and hiding behind heat sources.
To be responsible, but never to let fear stop the imagination.
Offline OrBy
« Reply #2647 on: December 31, 2013, 05:02:28 pm »
Zip tie pull tab helps a good bit - and if angled correctly adds more strain relief/bracing against the housing while still not coming into contact with the rubber flap!
Offline edavid
« Reply #2648 on: December 31, 2013, 09:52:28 pm »
The print view of this topic now renders a blank page, guess it got too big for SMF as well.  Shame. Apart from easy in browser searching the print view is also useful for saving a local copy.
gnif was nice enough to fix this... thanks!
Offline pomonabill221
« Reply #2649 on: January 01, 2014, 01:25:43 am »
I wrote about the correct syntax of zoom enable in menu. There is a change in Mike's E4-Hack required.
Look at my footer for my post about this. Since this time I deleted the (at time) unused stuff from the file "toolbar-config_z3.xml", for clarity.
It is the actual and final hack status for me. Interesting future features are (for me) image resolution enhancement (like at zoom images) and a higher frame rate.
If you want details, please ask me.
After countless coldstarts there were malfunctions. It is recommendable to reset device settings to factory default. Then and since everything is working properly.
And after my E4 now is better than a E8, I have named E9 (in EEPROM)!
YEAH!!!!!  Thanks TONS for the zoom feature!!!!  SUPER EASY!!!!
I had installed the e8 hack previously and the zoom entries were already there, but the .xml file had the menu item commented out (disabled), so all I had to do was edit the <toolbar name= (etc) to enable the zoom menu item, and VIOLA!!!!!  I got's the zooommmm stuff!
EXCELLENT!!!  Thanks tons!
