Hi there,
a few days ago I mentioned a problem with my E4. It still exists as I do not get access to it. I now need a hint how to proceed best:
What I did:I renamed accidentely the folder FlashBFS/System/ui.d/presets.d
AND (dumb as I was) I switched USB from RNDIS to the option at the top (very probably MSD)
Now, when I start the camera a message appears that Appcore.exe has crashed (I assume because it does not have access to presets.d).
The camera powers up (behind the crash message the thermal picture is visible). But I cannot use any of the buttons - the E4 is not reacting, so I cannot set it back to RNDIS to correct my mistake.
I do have USB connection (= I can see the DCIM directory) but I do not get a connection through FLIRInstallNet.exe after installing the FlirDeviceDrivers. Why not? Probably because I selected MSD and not UVC at the USB menu.
I know I now should be able to enable RNDIS through the serial interface (by sending the command "usbfn RNDIS") and using the FTP program to add the missing directory, but this would mean getting a 0.5mm cable first and then opening the E4. I would like to avoid this.
Is there any other way heal my mistake without opening the E4?
E.g. copy the missing files to the directory with some autostart file. Or a hint to disable all measurement features of the display (such as box, hot spot etc.) because without anything on the screen the camera should not need the access to the folder "presets.d" thus allowing me to enable RNDIS again.
Thanks!!
