Excellent .... this is what I like about brain storming a problem as a group
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif.pagespeed.ce._JElyJQqdB.gif)
....indeed the shutter could still be the issue. Experimentation with it by only partially moving it across the signal path should show any temp gradient across it as it moves into view by causing non uniformity when the lens is covered by a uniform temperature material.
Partially moving the shutter without physical access to it may be a challenge though ?
I am also wondering what could cause temperature change across the shutter. A warm component beneath it or thermal currents passing over it and out of the solenoid port ? Sadly the lens holder obscures a decent view of the components around the microbolometer FPA.
Its getting late in the UK now so I will have to sleep on this. It would be great to read more thoughts and test results from my fellow forum members across the pond in the USA. All good fun
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/xsmiley.gif.pagespeed.ic.R8GFI-pF6f.png)
If I had a SEEK in my lab right now I would be examining the lens assembly and shutter flag with my FLIR E4, fitted with its best close-up lens. With the right lens you can actually look into the SEEKS lens and see the shutter temperature gradient, if present.
Aurora
