Author Topic: "NOP generator" for 6502-based systems with DIP ROMs  (Read 2410 times)
Online Alex EisenhutTopic starter
  • Place text here.
« on: March 25, 2020, 12:29:55 pm »
At least I hope it is.
Now to select resistors.
edit: umm, maybe I should explain a bit. This is something I just tossed together in a few minutes to try out OSH Park's "After Dark".
This is supposed to replace system ROMs in 6502 systems and will always return the NOP opcode (x0EA) to force the 6502 to step through its address space at half the clock speed.
For troubleshooting.
« Last Edit: March 25, 2020, 03:28:33 pm by Alex Eisenhut »
Online KrudyZ
Re: "NOP generator" for 6502-based systems with DIP ROMs
« Reply #1 on: March 25, 2020, 05:06:21 pm »
What happens when you reach the end of the ROM select range?
Assuming the system has other memory, like RAM, the range select logic would be external and the processor would stop looking at your ROM...
Offline NivagSwerdna
« Reply #2 on: March 25, 2020, 05:19:16 pm »
Where did you get the DIP pins from?
Online SiliconWizard
« Reply #3 on: March 25, 2020, 05:45:07 pm »
I was also going to ask, but they look live salvaged pins from some connectors...
« Reply #4 on: March 25, 2020, 05:46:54 pm »
As there doesn't seem to be anything active on this, I'm also wondering how it can cohabit with other chips on the same data bus?
  • Place text here.
« Reply #5 on: March 25, 2020, 05:52:00 pm »
Yeah it's a last resort kinda thing. You remove the other memory on the board or you can remove the decoding logic.
The PC rolls over from 0xFFFF to 0x0000 and keeps going.
The kind of boards I intend to use this on are all 1980s stuff. 74LS and DIP ROM and RAM.
Although with all the 6502s I bought I can just swap the chips.
Like I said, I really wanted an excuse to use the After Dark thing.
Sigh. I don't remember.
Nope!
Online edavid
« Reply #6 on: March 25, 2020, 06:00:15 pm »
Matthew D'Asaro used to sell the pins - not sure if he still does, but you could ask.
http://www.dasarodesigns.com/product/batten-and-allen-ba3760-dill-leadframe-dip-pcb-edge-clip-pins/
« Reply #7 on: March 25, 2020, 06:25:50 pm »
Sadly he has some conditions, i.e. no re-sale
« Last Edit: March 25, 2020, 06:58:11 pm by NivagSwerdna »
« Reply #8 on: March 25, 2020, 07:12:17 pm »
OK!
Note that you could now design a just slightly fancier one with just an added 3-state buffer (such as 74HCT241)  so that you can use it without removing anything else!
Online edavid
« Reply #9 on: March 25, 2020, 08:10:29 pm »
Where do you see that?
  • Place text here.
« Reply #10 on: March 25, 2020, 08:35:47 pm »
I think he means re-sell one of his products that uses the pins
"Building one of my products yourself (remember: personal use only without my prior consent)"
