At least I hope it is.
Now to select resistors.
edit: umm, maybe I should explain a bit. This is something I just tossed together in a few minutes to try out OSH Park's "After Dark".
This is supposed to replace system ROMs in 6502 systems and will always return the NOP opcode (x0EA) to force the 6502 to step through its address space at half the clock speed.
For troubleshooting.
What happens when you reach the end of the ROM select range?
Assuming the system has other memory, like RAM, the range select logic would be external and the processor would stop looking at your ROM...
Where did you get the DIP pins from?
I was also going to ask, but they look live salvaged pins from some connectors...
As there doesn't seem to be anything active on this, I'm also wondering how it can cohabit with other chips on the same data bus?
Yeah it's a last resort kinda thing. You remove the other memory on the board or you can remove the decoding logic.
The PC rolls over from 0xFFFF to 0x0000 and keeps going.
The kind of boards I intend to use this on are all 1980s stuff. 74LS and DIP ROM and RAM.
Although with all the 6502s I bought I can just swap the chips.
Like I said, I really wanted an excuse to use the After Dark thing.
Sigh. I don't remember.
Nope!
OK!
Note that you could now design a just slightly fancier one with just an added 3-state buffer (such as 74HCT241) so that you can use it without removing anything else!
