The only thing that gives me the willies about using it now are the 720kB 5.25" floppies. I wish there was as SSD or flash replacement for 'em.
You just need to stock up on media and make lots of copies!
I thought that was an available product, "floppy emulator", pulls images off a USB drive and acts like a floppy drive on the other end.
Definitely pre-ATA... I think most CP/M machines used a Shugart-standard interface, no?
... I have 5.25'' floppy disks (some as old as from 1985) and still working OK (only rarely used).
For a backup, I've seen many projects for floppy disk unit (FDU) emulators...
For a backup, either find an old PC motherboard...
If you don't find any, there was a tool named Kermit, for CP/M...
Another option would be to search for existing backups on the Internet...
1st pic is anechoic magnitude and phase vs frequency of a tweeter on a test baffle.
2nd pic is an 3D "waterfall" display (energy vs time vs frequency) of a speaker system.
No idea what methods are used to measure those in the audio industry, so the ways I'll try to measure such params would be one of these:
- either slowly sweep the frequency with a sinusoidal signal while continually measuring the amplitude and phase relative to the source signal (so analog phase and amplitude measurements logged while sweeping the frequency)
- or send a single square pulse, digitize the response waveform with an ADC, then turn the recorded time-domain response into a frequency-domain response with the help of Fourier
For either method, I think a single output signal should be enough, but I've seen on the back panel both sin and cos outputs, so I wonder why does the instrument needs both.
Do you have any hints how the instrument measures, please, or why does it has quadrature outputs?
It is possible... I have seen some folks adapting an interface for SD-CARDS
using a custom based I/O attachment fixture... even possible it they (already have)
are also capable to offer S-100 (Altair 8800)....
Although I have seen this for sale for PCs the Z80 I/O is very close to 8085/8080 if not identical in this particular case.. someone with will and time should be able to interface a Z80...
Those graphics written in Assembly are a work of art..
Will and time, that is the key...
I have a Pick and Place machine that runs Windows 95, and used a 3.25" floppy for data exchange. I got a device mostly sold for use with music synthesizers that makes a USB memory stick (thumb drive) look like a bunch of 1.44 MB floppies. I'm not sure that would work for your 720KB disks, but maybe somebody makes one of these that will do 720K. What I have is the Gotek-SFR1M44-U100.
