Author Topic: xp install bsod on my new pc  (Read 1536 times)
Offline METopic starter
« on: September 16, 2026, 12:02:04 am »
How can i install and boot xp on a ueif bios motherboard, i get a bsod with A5 errors, the board is a asus tuf b450-plus gaming+ running a Ryzen 7 3800x
Offline squadchannel
  • Country: jp
  • deepl translate user
Re: xp install bsod on my new pc
« Reply #1 on: September 16, 2026, 12:10:10 am »
There is no driver for the SATA controller, so you should get a blue screen when the system restarts after the first TUI setup prompt.
I remember it was an error saying something like “Boot device not found.”
I'm pretty sure it worked if I set it to IDE-compatible mode. If that doesn't work, you'll need to load the SATA driver right at the start of the CD boot, but I doubt there's even a driver for XP.
I looked into 0x00000A5, and it seems to be caused by ACPI. Could it be that the driver is missing? Did it can disable the ACPI and installing it?
« Last Edit: September 16, 2026, 12:21:19 am by squadchannel »
« Reply #2 on: September 16, 2026, 12:32:55 am »
so is it possible to fix it , There are no drivers from asuss site for xp for this mb .I need a workaround.
Online wraper
  • Country: lv
« Reply #3 on: September 16, 2026, 12:50:33 am »
Sata is the smallest part of the problem, driver can be easily loaded during install. The real problem is dropped EHCI USB support in Ryzen (you're already screwed even before starting install, unless there is a PS/2 port and DVD drive). On some motherboards it's simpler to get working than than on others. IIRC ASUS motherboards are among the most problematic. There are utilities, (for example from asrock) that intergrade USB xHCI the driver into win xp installer. Did you enable CSM and other legacy support stuff (if available) in the bios settings?
« Last Edit: September 16, 2026, 12:00:55 pm by wraper »
Offline coromonadalix
« Reply #4 on: September 16, 2026, 01:04:18 am »
why not running it in a VM ?   if it is well configured, it can access all host devices / peripherals
Xp can not recognise  GPT partitions, Vista could  but  only as storage, and as stated  xp does not support  nvme drives
windows 7  would be the minimal
why do you specifically need xp ?
EDIT : check this ?
https://winraid.level1techs.com/t/boot-winxp-32-64-bit-on-uefi-32-64-bit/34020
« Last Edit: September 16, 2026, 01:08:59 am by coromonadalix »
Offline abeyer
  • Country: jp
« Reply #7 on: September 16, 2026, 11:33:23 pm »
I have autell diagnostic gear that is expensive and need xp to load diffent software for different car models onto it using xp 32 bit also peugeot plannet and citroen lexia, all needs 32bit xp, i had csm mode enabled but no go.
The following users thanked this post: digsys
Offline digsys
    • DIGSYS
« Reply #8 on: September 17, 2026, 02:19:26 am »
Quote from: ME
I am in a similar boat. I have several XPs / Win7 dual/multi boot PCs and laptops, all with spare MBs etc. Full images of all of them. Luckily, never had a failure.
I have developed many dozens of emulators / dev tools / UPC / MPC / programmers, many machine code level, even modified some kernels, 10s of $1,000s worth.
Happy to retire them once I croak :-) .. Keep ONE win11 laptop for rare cases, rarely need it, there's usually always a way around :-)
Offline Zoli
  • Grumpy old men
« Reply #9 on: September 17, 2026, 05:53:28 am »
Roughly for the same price like asus, you can get a new tested XP computer with warranty:
https://nixsys.com/collections/windows-xp-computers
Online Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #10 on: September 17, 2026, 05:56:38 am »
You're going to need to find some vintage laptop for this.
I recommend searching for some older Dell Latitude E6400 series, we have a few of those for these exact issues.
« Reply #11 on: September 17, 2026, 06:46:58 am »
aaaaaah now it's clear,  yep  find old lappy's for that
i have done that for Suzuki  stuff  ..... and others
sure theses can help
but way overpriced,  you can find many on fleabay  etc ...
and you had some tricks with some VM, you could block clocks / date  etc ...  to prolong  some softwares indefinitely ...
« Last Edit: September 17, 2026, 06:50:11 am by coromonadalix »
Offline thephil
    • Techbotch
« Reply #12 on: September 17, 2026, 10:53:04 am »
As others already said: your best bet is to either run in a vm, or get a machine with hardware of the time. For your particular purpose, an older machine is probably the better solution, because you don't have to mess with hardware passthrough to the vm, in that case.
It's never too late for a happy childhood!
Offline Whales
    • Halestrom
« Reply #13 on: September 17, 2026, 11:16:34 am »
+1 to it probably being an IDE vs AHCI issue.  See if your BIOS has a setting for IDE emulation mode.  Alternatively there are ways of adding the drivers to the install disc, but I don't remember them.
Also see: https://www.vogons.org/viewtopic.php?t=104508
What hardware does the software talk to?  If it's USB then you can "passthrough" whole USB ports to a VM that runs WinXP 32bit, which might be easier for you as you can then use any laptop running any modern Windows or Linux.
