Author Topic: How to select specific pad number in altium  (Read 482 times)
Offline ali_asadzadehTopic starter
« on: February 09, 2026, 12:54:06 pm »
I have a PCB in Altium Designer 26 with around 50 connectors, all using the same footprint. Unfortunately, I only have the PCB file — there is no schematic.
I need to disconnect pin 5 of all these connectors. Currently, pin 5 on each connector is assigned to the 12V net, and I want to set those pins to No Net.
I’ve tried using the PCB Filter and Find Similar Objects, but I can’t filter by pad number / pin number — there is no PadNumber or equivalent field available to select pin 5 across all connectors.
To make it more complicated, the 12V net is also connected to many other pins, including pins on a 100-pin connector, so I can’t simply select everything on the 12V net.
SO the question is How to select all pad 5s and edit all of them at once!
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: How to select specific pad number in altium
« Reply #1 on: February 09, 2026, 05:51:45 pm »
(ObjectKind = 'Pad') And (Name like 'J*-5') AND (Net = '12V')
« Last Edit: February 09, 2026, 05:53:45 pm by Pseudobyte »
“They Don’t Think It Be Like It Is, But It Do”
The following users thanked this post: ali_asadzadeh, tooki
« Reply #2 on: February 10, 2026, 12:36:52 pm »
Thanks for the feedback
