Author Topic: Selecting fitted components of the current variant in pcb in AD25  (Read 2609 times)
Offline jgorskTopic starter
I'd like to use "Find Similar" functionality in pcb to highlight only components that are fitted
in the current variant. Functionality similar to what's in the 3D view but I'd like that in the 2D
view. I'd like to be able to use it for manually building prototype boards.
Is there a way to achieve that?
Offline thm_w
  • Non-expert
Re: Selecting fitted components of the current variant in pcb in AD25
« Reply #1 on: February 10, 2025, 09:39:52 pm »
You can show them in the Variant manager: https://www.altium.com/documentation/altium-designer/variant-management-dialog#display-of-variant-management-dialog-data
And visually see them in the schematic (click the tab at the bottom of the schematic sheet beside Editor).
But I can't figure out a way to select them like that.
« Reply #2 on: February 10, 2025, 10:10:18 pm »
You can also see the fitted parts in the 3D view but it's not very handy for building prototypes
since not fitted and fitted parts are highlighted by 'find similar' functionality. Not fitted parts
have their 3D models are hidden.
Offline thm_w
  • Non-expert
« Reply #3 on: February 10, 2025, 10:21:53 pm »
If its for building prototypes have you looked at: https://boastools.com/
There is also an altium equivalent.
Offline tszaboo
« Reply #4 on: February 10, 2025, 10:42:09 pm »
Probably best way to do this is with an exported interactive PDF.
Or with the draftsman, all the not fitted parts are crossed out red on an assembly view.
« Reply #5 on: February 11, 2025, 01:43:51 pm »
Boastools solution looks interesting, but I can't use for work.
Draftsman won't do what I need. I need to be able to highlight (in the pcb editor) only the parts of each type that are fitted.
Offline thm_w
  • Non-expert
