I have recently returned my P200 that I initially bought beginning of the last year. P200 size and nice UI were major selling points for me. Also for some experiments I am usually to lazy and also a bit afraid to use more expensive Siglent SPD3303X-E. Almost from the very beginning I was receiving "Input spike!" errors occasionally. I thought it has something to do with regulation of my mains. But then when I made really nice silicon shielded coords for my Pinecils I learned that it cannot power this switching portable soldering iron, because its AC-DC simply does not like the switching and it is AC-DC causing "spikes" that then 2nd DC regulation module complains about. I managed to reproduce this "spike" with 20V and 5R power resistors, that otherwise should work perfectly fine since 4A 80W is below max of this unit.
So I realized this power-supply cannot do anything, but simple battery charging tasks. Also the minimum CC setting of 500mA is absolutely too high to do anything more sensible, such as checking the circuits slowly raising current limit. So in the end it is far from something I'd recommend. Also my ToolkitRC never responded to my ticket regarding "Input spike!". Since I bought it from really good seller in Switzerland, I was able to return it with full money refund with minimal questions asked.
Reading and watching some other reviews I now use Gophert PPS-3205 32V 5A switching power supply as my 2nd bench unit. It is a little bigger than P200, but still very small / portable. It is completely passively cooled, has reasonable ~40mVpp noise on load (as for a switching unit). And ~$60 with shipping price is ok. It works well, although obviously the it nowhere near with 1-2mVpp of my Siglent linear PS. It also clicks a bit when used with Pinecil. I suspect loose coils may be the culprit. So I will keep using USB-C plugged to wall adapter for soldering.
