Author Topic: Wanted Circuit Design Ideas To Construct CC CV Power Supply  (Read 5689 times)
Offline audioTopic starter
  • Country: in
« on: March 17, 2021, 12:54:48 pm »
Hi to all,
               In my previous Thread I have asked Replacement component for General purpose power supply design published by NI. It is  really Hard to construct of such high current. So I decided to construct Variable power supplies of lower Ratings(1.2V to 30 V and Minimum Current to 1 Amps). Hence maximum power obtained from the RPS 30Watts and Maximum power dissipation rather would be 30W.
                      I went through the websites for Regulator datasheets which could solve my Problem. I found 317 IC could be used up to 40V.
but the problem is how to control current with these three terminal voltage Regulators?
                               Ideas given in data sheet require lower resistance between adj and vout terminal. such low resistance variable pot of High wattage is required to control current . What could be the better alternative for this Problem? How to control Current in three terminal Voltage regulators? Thank you all..
Offline Zero999
  • 0999
Re: Wanted Circuit Design Ideas To Construct CC CV Power Supply
« Reply #1 on: March 17, 2021, 02:58:05 pm »
Using the LM317 is a bad idea. The current limiting circuit requires a voltage overhead of at least 4V, which is added to the usual 3V, of the voltage regulator.
Use the LT3081 which doesn't have any of these limitations and the current limit adjustment potentiometer doesn't pass the load current.
https://www.analog.com/media/en/technical-documentation/data-sheets/3081fc.pdf
The following users thanked this post: audio
  • Country: in
« Reply #2 on: March 17, 2021, 03:38:40 pm »
what should be the power rating of 1 ohm resistor in the circuit?
Offline WattsThat
« Reply #3 on: March 17, 2021, 04:12:14 pm »
P = I^2 * R so max dissipation is about 1.2 watts.
Since this is a current sensor, you want the resistance to be as stable as possible so your current limit does not drift when you’re working with higher current/power. That power dissipation means temperature rise so a larger resistor with a low temperature coefficient is desired.
I’d go with a 1%, 10W part with +/-50ppm TCR.
https://www.digikey.com/en/products/detail/vishay-dale/RS0101R000FE73/1166364
  • Country: in
« Reply #4 on: March 18, 2021, 05:07:12 am »
I came through web about classic 723 which could do both voltage and current regulations. But the datasheet doesn't contain any circuit which could control voltage and current control. Is there any method to construct to control 2 to 30v and minimum current to 1 amps?
Offline Zero999
  • 0999
« Reply #5 on: March 18, 2021, 09:24:05 am »
The LM723 has the same problem as the circuit in your original post: the current sense resistor needs to be variable. It also has very rough current limiting, which is dependant on the VBE drop of an internal transistor, which varies with temperature.
The circuit you posted in your second reply is the right way to do it. Use a 2W 1 Ohm resistor, so it doesn't get too hot.
Offline mvs
« Reply #6 on: March 18, 2021, 10:56:52 am »
LT3080/LT3081 are quite expensive components, LM723 is obsolete...
Look for a discrete solution with separate voltage reference, error amplifiers and pass element.
  • Country: in
« Reply #7 on: March 18, 2021, 11:40:35 am »
Yes. Truly Said, cost of LT3080 is much Higher than transformer.
It would be better to check with Opamp based design for Example 358 ,Dual Opamp. One would be used for Voltage Regulation and other opamp would be for current regulation. Similar to my previous Thread.
You can share design ideas with Opamp based CC CV power Supply circuit..
Thank you..
Online Kleinstein
« Reply #8 on: March 18, 2021, 11:50:08 am »
The LT3080 and LM317 are voltage regulators meant to power a fixed circuit. They have a limited accuracy because the power dissipation heats up the circuit and reference. In addition they have limitations on the load impedance and may oscillate with the wrong output capacitance / load, which can be annoying for something like a lab supply where you don't know upfront what is connected.
For better accuracy it is preferred to have the power transistor(s) and control separate, like with the LM723. There is no much magic inside the LM723 and one can as well use 2 OPs and a voltage reference for a similar circuit. There are plenty of circuits out there in the web - just too many poor ones, so that it is not that easy to find a working one.
AFAIK the xx723 are not yet fully obsolete - just some manufacturers and versions.
Don't get fooled by first page numbers: they often don't apply at the same time and only under favorable conditions. So no 40 V and 1 A from the LM317, and the LM723 has 37 V maximum input voltage (not output) which makes 30 V out already not so easy.
Offline xavier60
« Reply #9 on: March 18, 2021, 11:57:48 am »
Thank you..
Is your memory really that short?
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
  • Country: in
« Reply #10 on: March 18, 2021, 12:04:53 pm »
Exatly, This was in my head.
many Circuit were present but to find the one which is working needs skill with opamp circuit.
Choosing 723 IC is better but Variable Current limiting will be a problem .
Offline xavier60
« Reply #11 on: March 18, 2021, 12:15:49 pm »
The LM723 has an opamp inside which needs compensation like any other opamp.
The LM723's opamp does not work properly with its input close to ground voltage, meaning that PSU design wont regulate down to zero volts
without having to add tricks to the circuit.
 For good CV/CC operation, two opamps are needed. There is a circuit about that has a pair of differential transistors tacked onto the LM723 for CC.
« Last Edit: March 18, 2021, 12:18:53 pm by xavier60 »
Offline exe
  • self-educated hobbyist
« Reply #12 on: March 18, 2021, 12:18:48 pm »
Well, the datasheet for lt3080 has performance curves. Looks like reference current is is ~600ppm/c, which is about 2.5% for 50C raise. I'd say it's fine for an analog power supply.
As of oscillation and stability, what makes lt3080 special? Just put 10uF ceramic cap to the output. LT3080 is a very fast regulator, so I can imaging stability issues may happen (got that with a DIY load), but that's the price to pay for speed.
LT3080 is expensive, but if you take into account time and effort engineering a cheaper circuit it's actually not that bad. Unless taking an existing design. Also, I bet there will be much more parts.
PS this is my LT3080 power supply https://www.eevblog.com/forum/beginners/please-critique-this-linear-psu/ , and this is a picture of it: https://www.eevblog.com/forum/testgear/show-the-homemade-equipment-you-are-using-now/msg1984904/#msg1984904 . It has a horrible temperature drift thanks to voltage set circuitry. The problem is not with lt3080, but with lm334 which has a horrible drift. It is so bad that the datasheet proposes to use lm334 as a temperature sensor...
  • Country: in
« Reply #13 on: March 18, 2021, 12:20:08 pm »
"Their is a circuit about that has a pair of differential transistors tacked onto the LM723 for CC" ,where could i find the circuit on WEB????
Offline xavier60
« Reply #14 on: March 18, 2021, 12:22:48 pm »
I saw it in a thread on this forum lately.
Offline xavier60
Offline themadhippy
« Reply #16 on: March 18, 2021, 01:16:36 pm »
Might be worth while watching daves series on designing a power supply
https://www.youtube.com/playlist?list=PLBF35875F73B5C9B5
Offline exe
« Reply #17 on: March 18, 2021, 01:28:01 pm »
BTW, if you want circuit ideas, you can check this thread: https://www.eevblog.com/forum/projects/how-to-design-fast-bench-supply-with-cc-and-cv/ .
If I was building a power supply, I'd go with xavier60's power supply: https://www.eevblog.com/forum/projects/how-to-design-fast-bench-supply-with-cc-and-cv/msg3010016/#msg3010016 . Or any other power supply from a reputable forum member :).
You can design your own power supply, but beware that proper design takes a lot of efforts and knowledge. Esp. when it comes to performance and stability. Beware of many broken and unsafe circuits on the net. Incl. on this forum. So, make sure the design is reviewed by a skilled analog engineer. Of course, skilled engineers are opinionated, but a good opinionated power supply is still a good power supply :)
PS Dave's power supply doesn't touch upon stability and compensation (afaik). So, while it can be inspiring to design an own power supply, you have to learn a lot more to do that. That was my experience 5 years ago when I tried to make my own PSU based on his educational videos.
The following users thanked this post: Electro Fan
Offline MikeK
« Reply #18 on: March 18, 2021, 01:58:35 pm »
To answer OP's original question:
40V. but the problem is how to control current with these three terminal voltage Regulators?
The datasheet for the LM317 contains a simple circuit for a "precision current limiter".
Offline mvs
« Reply #19 on: March 18, 2021, 02:51:50 pm »
The problem with skilled analog engineers is that they don't bother with basic designs. You can look for instance on PSL3604. It is a very good supply, but also very overloaded with features. At least used parts are more or less generic and cheap.
https://www.eevblog.com/forum/projects/diy-bench-power-supply-psl-3604/
Offline Zero999
  • 0999
« Reply #20 on: March 18, 2021, 07:34:10 pm »
But it's crappy, as mentioned above.
The original poster should just go for the LT3081. It's not cheap, but is much better than faffing around. It's possible to do it with a few op-amps, but it's difficult to stabilise.
Here are a couple of threads about this. There are many more.
https://www.eevblog.com/forum/projects/oscillation-in-psu-simulation/
  • Country: in
« Reply #21 on: March 19, 2021, 07:01:39 am »
Just Check this Circuit For CC CV Circuit.
Will it work as intended????
Offline xavier60
« Reply #22 on: March 19, 2021, 07:35:47 am »
It can be made to work. It will have poor load regulation because the B-E drop of Q1 and the drop across R3 are outside of the CV regulation loop.
CC wont work properly at low output voltage. The CC opamp needs a voltage reference and maybe some compensation.
The following users thanked this post: BrokenYugo
Offline Zero999
  • 0999
« Reply #23 on: March 19, 2021, 01:03:18 pm »
As you only need 1A, do away with Q1.
Connect the top of RV3 to a 1.2V reference and make R3 1.2 Ohm. If it's not critical, the LM317L can be used as a cheap voltage reference.
Add a -5V negative power supply rail for the op-amp, so its output voltage can go below zero.
Offline rstofer
« Reply #24 on: March 19, 2021, 03:15:42 pm »
It could be that supplies designed by analog engineers might actually work whereas most of these low-parts-count DIY supplies have fairly large warts.
The PSL3604 linked above is way up on the parts count scale.  I'm guessing that it actually works as intended.
Look at one of Dave's teardown videos and see how many components are in a commercial supply.  Dave did a teardown of the Rigol DP832 for example.  Look at the parts count!
Don't worry about 30V at 3A, see what happens at 1V at 3A given a 36 VDC source and a linear design.  Commercial supplies use custom toroidal transformers for this very reason.  It is unlikely that the hobbyist is going to source such a transformer.
