Author Topic: changing the rigol DS1052E to DS1102E using USB , the dummy guide  (Read 1693549 times)
0 Members and 46 Guests are viewing this topic.
Offline RetroDan™
Re: changing the rigol DS1052E to DS1102E using USB , the dummy guide
« Reply #1650 on: April 11, 2015, 02:15:23 pm »
I'm having a right devil of a time.  I bought the 1052E as my first scope, and naturally I want to screw the manufacturer out of as much money as is possible through the use of clever workarounds.
My scope came with the 00.04.01 SP7 firmware, and is HardVersion=58.
I downloaded MudMan's hacked firmware, loaded it onto an SD card with a USB SD Hub (none of my flash drives seemed to work for the upgrade), and the '52E recognizes that there is an upgrade on the card, so I upgraded it, and restarted the 'scope when it said to.
However, upon restart, it still says it's a DS1052E, and there doesn't seem to be any difference in functionality.  Is there another step or something that I have missed?
(**A new 3rd Edition** companion is in preparation, expected publication 4Q15: “Learning the Art of Electronics — A Hands-on Approach”)
Offline MudMan
« Reply #1651 on: April 12, 2015, 12:31:27 pm »
With the cracked firmware you will get 1052E as model number, thats ok. Only with the "workaround" in the old FW, with the change of the serial number, the model number will change to 1102E.
A quick check to get the bandwidth; turn the horizontal timebase to minimum and check the value. If the minimum is 2nS your scope has 100MHz bandwidth, if it's only 5nS the crack didn't work and the scope has 50Mhz bandwidth.
Offline RetroDan™
« Reply #1652 on: April 12, 2015, 06:04:11 pm »
Oh, okay.  It does have the 2ns minimum, so I guess everything DID work.  Giggity.
Thanks for the help.
Offline LarsT
« Reply #1653 on: April 21, 2015, 09:31:31 pm »
I bought a new Rigol DS1052E last year with the following Software version: 00.04.01. (That's all it says).
Is it possible to hack this scope to 100MHz as well?
Offline straycat
« Reply #1654 on: April 22, 2015, 04:03:12 pm »
The answer is yes,you should still be able to hack the scope with the 100mhz mod firmware. hope this helps.
Offline LarsT
« Reply #1655 on: April 23, 2015, 11:07:04 am »
Nice! I will try it!
What worries me is that everyone seem to have different versions and different software/hardware etc.
Offline LarsT
« Reply #1656 on: May 21, 2015, 09:05:30 am »
I tried the upgrade but it still displays "Rigol D1052E" during start up and version 00.04.01. However I now can "zoom in" to 2ns, where before I was limited to 5ns.
Is this success?
Offline MickM
« Reply #1657 on: May 22, 2015, 12:20:50 am »
LarsT;
 Yes you have succeeded.
Offline mmatic
« Reply #1658 on: May 26, 2015, 11:13:30 am »
I hacked Rigol DS1052E firmware a few years ago and I got SW version: 00.02.04 SP1. What is procedure to upgrade firmware?
My version:
serial no: DS1EB125116783
installed module:
- FFT
- USB
- P/F
-RS232
Best Regards Matic
Offline straycat
« Reply #1659 on: May 27, 2015, 10:54:01 am »
mmatic......... All you need to do is download gizmo,s modded firmware. Put it on a usb stick,plug it in, it should say newer firmware found,then update.  The scope will still show its a 1052e but you should be able to go down to 2ns=100mhz.Hope this helps. :-+
Offline straycat
« Reply #1660 on: June 05, 2015, 02:50:13 pm »
Hay guys just received latest version firmware from rigol to my work place. Its now 00.04.02.00.00. CAN NOT install if your firmware is less than 00.03.00.00.00 according to data sheet.
version info;released version 00.04.02.00.00
                    released date 11/5/2015
Change log  enhancements,changes that add functionality.
                   modifications,changes to improve performance on existing features.
                    cancellation,removal of function or capability.
« Last Edit: June 06, 2015, 10:18:49 am by straycat »
Offline supermax
« Reply #1661 on: June 09, 2015, 09:37:24 am »
Hello
there's a modify version of 04.02 that support 100MHz of BW ??
Max
Offline straycat
« Reply #1662 on: June 09, 2015, 07:46:44 pm »
Hello
Max
Hi not that im aware of,that there's a modify version of 04.02. Looking through it tho still should be able to mod it.
Yes it can be changed to 100mhz. Just done it.
hope this helps.
Offline straycat
« Reply #1663 on: June 09, 2015, 07:54:49 pm »
Hi guys. For those of you how have changed the ds via the old way ,i.e  usb, changing the model no and serial,. If you put the DS back to its 1052e and correct serial number, when you install the new 00.04.02.00.00 it changes the scope automatically to a ds1102e without modding the firmware.  :-+
PS.. MAKE SURE YOU HAVE 00.03 OR HIGHER FIRMWARE.BEFORE INSTALLING 00.04.02.00.00
« Last Edit: June 09, 2015, 07:58:01 pm by straycat »
Offline MudMan
« Reply #1664 on: June 10, 2015, 05:56:47 pm »
Is there a download link for the original and/or "cracked" firmware?
Offline straycat
« Reply #1665 on: June 11, 2015, 12:47:44 pm »
Hi guys, I have tryed to put a link up for the new firmware,just doesnt seem to work. But will send the firmware via email if anyone wants it or any tips on how to get a link up.I tryed copy and paste does not work.
hope this helps
« Last Edit: June 11, 2015, 12:53:08 pm by straycat »
Offline gofrab
« Reply #1666 on: June 16, 2015, 03:33:45 pm »
Help me make downgrade firmware 00.04.02.00 to 00.02.06.01 to fix bug.
Sorry for my English
Offline gofrab
« Reply #1667 on: June 16, 2015, 03:36:26 pm »
next photo
Offline gofrab
« Reply #1668 on: June 16, 2015, 03:40:34 pm »
next
Offline gofrab
« Reply #1669 on: June 16, 2015, 03:42:41 pm »
next
Offline gofrab
« Reply #1670 on: June 16, 2015, 03:45:49 pm »
the end
Offline gofrab
« Reply #1671 on: June 16, 2015, 04:31:36 pm »
ups
Offline straycat
« Reply #1672 on: June 17, 2015, 10:33:33 am »
gofrab......... send me your email and i will send you a modded firmware that you are asking for.  :-+
Offline gofrab
« Reply #1673 on: June 18, 2015, 03:05:11 am »
was firmware DS1000EUpdate (00.04.02.00)  replaced with firmware DS1000EUpdate (00.02.05 SP2)
 I can not attach large files
thank you
Offline gofrab
« Reply #1674 on: June 18, 2015, 04:34:16 am »
or 00.02.06.01
?????????? ? ????? ALCATEL ONE TOUCH 8008D ????? Tapatalk
