dannyf, the problem with your libertarian view of environmental politics is that fails to account for negative externalities, ie when the problem doesn't stay within your "tomato patch". When you and million others drive around in gas guzzlers, the CO2 is absorbed into the atmosphere and causes a problem in a different location, at a later point. (Unless perhaps you reject the evidence for anthropogenic climate change.)
Likewise, I bet a lot of the people in that village never asked for, approved of, or even are well educated enough to make an informed decision about, it becoming a dumping ground for electronics. Now, as a result, the village is lacking clean air and ready access to clean drinking water. I bet that the "tyrannical majority" in that village would have said no to it, if they understood that heavy metals and other toxins would eventually penetrate the soil and end up in the ground water.
