Author Topic: Fun for nerds  (Read 355808 times)
Online themadhippy
Re: Fun for nerds
« Reply #775 on: August 14, 2025, 02:04:32 pm »
https://www.youtube.com/shorts/5FLIy6rEF9E
A poor attempt to copy one of the masters of word play
The following users thanked this post: lycralout, BrianHG
Offline Neilm
Re: Fun for nerds
« Reply #776 on: August 15, 2025, 06:25:25 pm »
In my mind one of their best sketches. Too bad it has dated so badly
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline RoGeorgeTopic starter
Re: Fun for nerds
« Reply #777 on: August 16, 2025, 11:36:43 pm »
Scientists Just Found Why Electrified Drops DON'T Splash
The Action Lab
 :o
Offline BrianHG
    • LinkedIn
Re: Fun for nerds
« Reply #778 on: September 06, 2025, 02:40:51 am »
Offline BrianHG
    • LinkedIn
Re: Fun for nerds
« Reply #779 on: September 18, 2025, 07:35:11 pm »
Movie recommendation for AI fanatics.
1970 -> Colossus The Forbin Project
https://www.imdb.com/title/tt0064177/
No action, all scifi...  Or is it?
You need to enjoy the really slow boring type of movies to enjoy this one.
Re: Fun for nerds
« Reply #780 on: September 21, 2025, 05:34:58 am »
Chickens Are Weirder Than You Thought
The Action Lab
 ;D
The following users thanked this post: SeanB, BrianHG
Offline coppercone2
  • √Y√... 📎
Re: Fun for nerds
« Reply #781 on: September 27, 2025, 06:27:00 am »
Re: Fun for nerds
« Reply #782 on: September 27, 2025, 04:25:27 pm »
How One Drop of Water Cools Your Phone
Know Art
 :o
Offline BrianHG
    • LinkedIn
Re: Fun for nerds
« Reply #783 on: September 28, 2025, 01:50:18 am »
 :scared: 20 Million Frames Per Second captures of gun shots into glass...
Re: Fun for nerds
« Reply #784 on: September 29, 2025, 10:54:29 am »
Earth's magnetic field Rotation apparatus
xofunkox-scientific experiments
 :D
Re: Fun for nerds
« Reply #785 on: September 30, 2025, 05:54:35 am »
Zooming out from Earth to the Observable Universe
ScienceClic English
 :o
Re: Fun for nerds
« Reply #786 on: October 02, 2025, 07:21:44 pm »
China's largest megaproject - The Three Gorges
Lifeder
 :o
Re: Fun for nerds
« Reply #787 on: October 05, 2025, 01:02:16 pm »
Making a Deformable Mirror
Huygens Optics
 :o
The following users thanked this post: BrianHG
Offline eutectique
Re: Fun for nerds
« Reply #788 on: October 06, 2025, 02:17:30 pm »
Re: Fun for nerds
« Reply #789 on: October 06, 2025, 03:19:05 pm »
20 MOST GUARDED Places on Earth You Cannot Visit
Uncharted Mysteries
 :scared:
Re: Fun for nerds
« Reply #790 on: October 09, 2025, 05:24:51 pm »
WE Spent 48 hours in the WORLD'S most advanced city 🇨🇳
Joel and Emilia
 :o
Offline BrianHG
    • LinkedIn
Re: Fun for nerds
« Reply #791 on: October 17, 2025, 03:23:20 pm »
Just watch this, you'll laugh your head off:
The Most Important Device in the Universe - Blinking Tubes Without Function New Compilation (Part 1)
Re: Fun for nerds
« Reply #792 on: October 17, 2025, 07:28:24 pm »
The Liquid That Can "Smell" and Chase Other Drops
The Action Lab
Re: Fun for nerds
« Reply #793 on: October 21, 2025, 08:22:41 am »
What the Books Get Wrong about AI [Double Descent]
Welch Labs
Re: Fun for nerds
« Reply #794 on: October 24, 2025, 10:51:19 am »
Remote Viewers Confirm 3I ATLAS Is An Alien Mothership
The Conspiracy Bureau
 ;D
Offline coppercone2
  • √Y√... 📎
Re: Fun for nerds
« Reply #795 on: October 26, 2025, 08:12:48 am »
You can make a functional, durable concrete satellite dish by using an umbrella as a mold for the perfect parabolic shape
. This DIY project can be used for amateur satellite tracking or other radio antenna applications.
How to use an umbrella to create a concrete satellite dish
    Select the right umbrella. Choose a large umbrella or a photographic reflective umbrella with many ribs to ensure the most accurate parabolic shape for reflecting radio waves. A cheap rain umbrella will have a less precise curve.
    Cover the umbrella with plastic. Completely wrap the open umbrella with a plastic sheet, such as a garbage bag or painter's plastic, to prevent the concrete from sticking to the fabric. You may need multiple layers for durability.
    Mix the concrete. Using a high-strength, fine-particle concrete mix, combine the concrete with water until it reaches a thick, oatmeal-like consistency. Add the water gradually to avoid a runny mixture.
    Create the support structure. Insert a PVC pipe or other lightweight, rigid material through the center of the umbrella's base. This will become the dish's central mounting point and cable conduit. You may need to create a simple stand out of wood to keep the umbrella's pole and the central pipe plumb while the concrete cures.
    Pour and shape the concrete. Carefully pour the concrete over the plastic-covered umbrella, filling it evenly. You can also press the concrete onto the mold by hand.
    Smooth and eliminate air bubbles. Use a small trowel or 2x4 to smooth the concrete surface. Gently shake the mold or poke the concrete with a stick to release air bubbles.
    Cure the concrete. Cover the concrete and let it set and cure for at least a few days. Keeping the concrete damp during the curing process will make it stronger and help prevent cracking. Follow the curing instructions on the concrete mix packaging.
    Remove the mold. Once the concrete is fully cured, remove the plastic and the umbrella skeleton from your new concrete dish.
Considerations for making a functional antenna
A concrete dish alone will not receive satellite signals. The following steps are necessary to build a complete system:
    Create the antenna feed. The signals are reflected by the dish and gathered at a "feed," the receiver located at the dish's focal point. For L-band satellite reception, for example, a simple feed can be made from a pie tin and a coil of wire.
    Mount the feed. Use a tripod, boom arm, or other stable structure to suspend the feed precisely at the focal point of the concrete dish. The focal point can be calculated based on the dish's shape and size.
    Connect the equipment. You will need to connect the feed to a low-noise amplifier (LNA) and a software-defined radio (SDR) receiver to pick up signals.
    Aim the dish. Use satellite tracking software and a compass to correctly aim your dish at the desired satellite. Be aware that satellite signals are easily blocked by clouds and rain, especially at higher frequencies.
I assume it wants me to use metal paint for a reflector surface.
« Last Edit: October 26, 2025, 08:16:55 am by coppercone2 »
Offline David Hess
  • DavidH
Re: Fun for nerds
« Reply #796 on: October 26, 2025, 01:16:49 pm »
You can also make a flat *refractor* satellite antenna with plywood by cutting circular slots in it and placing the antenna feed behind the plywood.  This design is pre-internet so nothing about it is available online that I have seen.  It was covered in Radio-Electronic magazine in the 1980s.
Offline coppercone2
  • √Y√... 📎
Re: Fun for nerds
« Reply #797 on: October 27, 2025, 08:58:53 pm »
fascinating. sounds like a meta material. I forgot how to cut wood. perhaps a reason to do so
« Last Edit: October 27, 2025, 09:03:00 pm by coppercone2 »
Offline eutectique
Re: Fun for nerds
« Reply #798 on: October 28, 2025, 12:06:30 pm »
The thing is called Fresnel zone antenna.
Re: Fun for nerds
« Reply #799 on: October 29, 2025, 06:00:29 pm »
Bob Lazar Was Holding Back.. - DEBRIEFED ep. 09 feat. ‪ProjectGravitaurOfficial‬
Area52
 :D
