Author Topic: Moderation reports  (Read 629039 times)
Re: Moderation reports
« Reply #675 on: November 09, 2020, 10:39:27 pm »
Still seeing more new reports of the "Your attachment has failed security checks and cannot be uploaded. Please consult the forum administrator." popping up around the place, like here: https://www.eevblog.com/forum/beginners/unable-to-post-images-any-longer/?topicseen
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #676 on: November 10, 2020, 12:16:25 am »
Offline S. Petrukhin
  • Country: ru
« Reply #677 on: November 10, 2020, 12:20:47 am »
I have images added without problems.
And sorry for my English.
Offline Fraser
« Reply #678 on: November 10, 2020, 03:30:44 pm »
Just added a whole load of images and PDF's to a thread and only noted that the number of attachments is now down to 10 from 25 and the maximum file size is 4MB instead of 5MB. All worked fine for me.
https://www.eevblog.com/forum/thermal-imaging/two-new-patients-inbound-)-scott-eagle-attack-firefighting-cameras/
What is annoying is the bug in the forums URL interpretation that messes them up, as demonstrated above ! (It ignores part of the URL if certain characters are present)
Fraser
Update : URL difficulties fixed thanks to help from knowledgeable forum members  :-+
« Last Edit: November 10, 2020, 10:58:59 pm by Fraser »
Offline PA0PBZ
« Reply #679 on: November 10, 2020, 04:33:57 pm »
Fraser
Not sure why but it shows up as:
[ u r l=https://www.eevblog.com/forum/thermal-imaging/two-new-patients-inbound-]https://www.eevblog.com/forum/thermal-imaging/two-new-patients-inbound-[/url])-scott-eagle-attack-firefighting-cameras/
(spaces added by me)
If the closing / u r l is at the end of the line I'm sure it works:
[ u r l]https://www.eevblog.com/forum/thermal-imaging/two-new-patients-inbound-)-scott-eagle-attack-firefighting-cameras/[/url]
The following users thanked this post: Fraser
Offline tautech
« Reply #680 on: November 10, 2020, 06:48:16 pm »
Fraser
Yes, SMF has always been this way and there are many links not working because of characters in the URL line that it doesn't automatically accept as part of a URL.
The workaround is to Modify your post and highlight the URL you want to use then use the Insert Hyperlink button.
This places the URL flags entirely over your URL and disregards what characters are in it just as PA0PBZ points out.
Avid Rabid Hobbyist
Offline Fraser
« Reply #681 on: November 10, 2020, 10:54:16 pm »
Thanks chaps  :-+
This has had me scratching my head on many occasions !
Fraser
Offline tautech
« Reply #682 on: November 13, 2020, 08:48:10 am »
Just had one of these ^ with an image I've posted without issues before.  :-//
It was taken with an iPhone and compressed with MS Picture Manager where iPhone images are always 90o off correct rotation yet always post correctly.  :-//
However the JPEG filename for this chap had the dreaded [1] in it signifying that it had been saved before. Renaming it wasn't enough to get it accepted by SMF however opening it in MS Paint, rotating it and saving it as a .png had SMF forum SW happy and it was posted.  :phew:
Avid Rabid Hobbyist
Offline nctnico
« Reply #683 on: November 27, 2020, 09:10:48 pm »
So likely there is a check in SMF which somehow doesn't accept all JPEGs. I went back to using Flickr instead of uploading pictures to the forum. The ability to put attached pictures inline in posts seems to have stopped working as well.
Offline PlainName
« Reply #684 on: November 27, 2020, 09:52:49 pm »
I wonder if it's anti-NSFW or similar checking. If so, there could be a switch to turn it off.
Offline tautech
« Reply #685 on: November 27, 2020, 10:40:22 pm »
Who TF knows, SMF seems to have more bugs than some certain brands of scopes.  ::)
This JPEG bug is not hard to work around as you just need open the file in a pic editing program and save it in another format like PNG.....30s of your time.
Well yes and you should know how to work around this too and do it as we historically had to before Dave enabled inserting images directly within a post.
I never found it comfortable to use as it didn't always give the result I needed so have always uploaded thumbnails onto the EEVblog server then edited the post to place the thumbnail URL within IMG flags and anywhere in the post that suits. Normally I post with a place keeper that relates to the image I need to insert later in editing like im2, im5 or whatever and delete it after the post is fully edited before saving the edit.
Sure it's a bit of stuffing around but works like a charm as it has always done.
That the first attachment box is also troublesome in SMF adds another level of fun to posting although skipping it and ONLY using subsequent attachment boxes from (more attachments) works perfectly without issue.
Like a crappy piece of equipment we learn to work with what we have to get the result required.  :horse:
Avid Rabid Hobbyist
Offline nctnico
« Reply #686 on: November 28, 2020, 01:39:14 am »
Nahh. Flickr is just way easier. Select a bunch of images/photos, click upload, browse through them and you can get preformatted links to resized images which are perfect to copy&past into your post. I'm not going to dick around with stuff which only works half; I have better things to do.
« Last Edit: November 28, 2020, 01:42:44 am by nctnico »
