Author Topic: Stock Electronic Image FAILS  (Read 232780 times)
Offline Red Squirrel
Re: Stock Electronic Image FAILS
« Reply #225 on: November 17, 2017, 05:23:03 pm »
That's just temporary glue for when the cpu goes through the reflow oven so it can be soldered to the socket.  >:D
Offline Mr. Scram
  • Display aficionado
« Reply #226 on: November 17, 2017, 05:29:07 pm »
WHY?!
That's one hurts a but. You can remove the glue from pretty much any part of the motherboard without much issues, but those pins will be seriously messed up when hotglued.
Offline Cyberdragon
« Reply #227 on: November 17, 2017, 05:51:54 pm »
They're not gluing the pins, they're gluing the bypass caps, which is pointless.
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline Mr. Scram
« Reply #228 on: November 17, 2017, 05:56:26 pm »
You haven't worked with hot glue, I suppose ;D. That stuff gets everywhere.
Though I just realized you could reflow the tin on the bypass caps, if you're really in a pickle. Like a in a war, besieged, with this computer being between you and being saved, and no other tools than a hot glue gun pickle.
Offline james_s
« Reply #229 on: November 17, 2017, 07:31:36 pm »
Isopropyl alcohol works pretty well to remove hot glue. The stuff does bond really well to certain surfaces though.
Offline Mr. Scram
« Reply #230 on: November 17, 2017, 07:36:38 pm »
Removing isn't the issue in itself, as glue typically peels off surfaces, it's the force that requires when combined with pins that bend when looked at sideways.
Online NiHaoMike
    • Facebook Page
« Reply #231 on: November 17, 2017, 09:41:36 pm »
That reminds me of how extreme overclockers would fill the socket with something nonconductive to prevent condensation when using dry ice or liquid nitrogen, but they generally don't use hot glue for that.
Offline Mr. Scram
« Reply #232 on: November 17, 2017, 09:44:42 pm »
Putty, which they put on most of the board :)
« Reply #233 on: November 19, 2017, 03:12:40 am »
Sometimes ram can be hard to get in!
Offline rx8pilot
« Reply #234 on: November 19, 2017, 03:14:46 am »
 :-DD :-DD :-DD :-DD
Offline Cyberdragon
« Reply #235 on: November 19, 2017, 03:21:40 am »
Look, it's Bob the Builder! Can he fix it?
No...not like that.
*BZZZZZZAAAAAP*
Offline Mr. Scram
« Reply #236 on: November 19, 2017, 10:19:40 am »
Is that the infamous Row hammer attack?
https://en.wikipedia.org/wiki/Row_hammer
The following users thanked this post: amyk
Offline Brumby
« Reply #237 on: November 19, 2017, 02:21:51 pm »
Some of these are so painful to look at....   :palm:
... I'm splitting my sides with laughter.   :-DD
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #238 on: November 20, 2017, 03:42:01 am »
Percussive maintenance!
-Pat
Offline trophosphere
« Reply #239 on: November 20, 2017, 03:55:31 am »
In the past, I've seen a person take a dremel to a new RAM stick because it wouldn't fit into the RAM slot of their motherboard. This was back in the early 2000s when the new fangled DDR2 SDRAM was introduced but DDR was still mainstream.
Offline lowimpedance
  • Watts in an ohm?
« Reply #240 on: November 20, 2017, 04:09:41 am »
A hammer to insert and pliers to extract.  :-DD.
That picture has made my day  :-+.
Offline AF6LJ
« Reply #241 on: November 21, 2017, 07:40:14 pm »
Someone should teach that boy how to hold a hammer. :D
Sue AF6LJ
The following users thanked this post: f1rmb
Offline Bashstreet
« Reply #242 on: November 21, 2017, 07:44:13 pm »
Lmao :D
Offline rrinker
« Reply #243 on: November 21, 2017, 08:00:56 pm »
Here's one from the digikey "catalogue":
https://www.digikey.com/product-detail/en/panasonic-electronic-components/ECW-U1102JX5/PCF1348CT-ND/353833
Look closely at the picture of the capacitor.
 Give you a good one to photograph?!?!?! We're not going to waste money that way, just take a picture of this reject.
Offline Mr. Scram
« Reply #244 on: November 22, 2017, 04:03:11 pm »
It could be worse.
"What you do you mean, reject?"
Offline james_s
« Reply #245 on: December 03, 2017, 06:29:41 pm »
From a 1973 NRI advertisement for electronic technician training.
Offline Cyberdragon
« Reply #246 on: December 04, 2017, 02:37:50 am »
I've already destroyed this computer, now to destroy this phone with my screwdrivers!
Rockaby baby in the tree top *SIZZLE* "OH SHIT!"
I can't even look at my terrible soldering
he finally found what he was going to solder! :clap: wait a minute...
And finally, today's message
*BZZZZZZAAAAAP*
Offline Electro Detective
« Reply #247 on: December 04, 2017, 04:30:46 am »
ok, the hammer may get the job done if no sledge available
but the thin pliers won't grip the ram properly for extraction in case it's in the wrong way
DIY-ers should really take note of those ram line up tabs, and invest in vice grips...    ::)
 :-DD
« Last Edit: December 04, 2017, 04:53:32 am by Electro Detective »
The following users thanked this post: fourtytwo42
Offline Gyro
« Reply #248 on: December 04, 2017, 01:20:03 pm »
Pah, everyone knows that if you've got a decent grip, it smells like Pork!  ;D
Best Regards, Chris
Offline Lord of nothing
  • Country: at
« Reply #249 on: December 04, 2017, 03:50:26 pm »
Made in Japan, destroyed in Sulz im Wienerwald.
