Author Topic: Stock Electronic Image FAILS  (Read 506543 times)
0 Members and 22 Guests are viewing this topic.
Offline R005T3r
Re: Stock Electronic Image FAILS
« Reply #250 on: December 28, 2017, 10:27:33 am »
Not electronic related, but.
The following users thanked this post: Solomon_3055
Offline Falcon69
« Reply #251 on: December 28, 2017, 04:18:21 pm »
Some gas is not flammable. But if that is acetylene and oxygen, that guy is a dumb ass.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #252 on: December 28, 2017, 09:17:12 pm »
Neither looks like an acetylene cylinder and they're a fair distance away, but nonetheless, I would try to shoot my grinding sparks in a direction other than right at them...
-Pat
Offline floobydust
« Reply #253 on: December 29, 2017, 11:45:19 pm »
Flux inductor ?
It's for Liliput. Alligator clip the size of ma finger, DPAK's sticking up in the air, might need a CPU :palm:
Offline Cyberdragon
« Reply #254 on: December 30, 2017, 12:18:10 am »
Flux inductor ?
None of those things are necessarily a problem, and you may remove the CPU if you suspect it may overvolt. The real problem is that all of the DMM indicators are on, which is clearly not normal operation. :-DD
EDIT: ...and the fact that you would get no continuity on either of those inductors since the wire is enamled and if it was damaged you'd probably need to replace them anyway. :palm:
« Last Edit: December 30, 2017, 12:22:19 am by Cyberdragon »
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline tszaboo
« Reply #255 on: January 23, 2018, 02:49:36 pm »
I just found this gem.
Yes. You have 1999 HIGH VOLTS on a CAT II  :-DD 1000V  :-DD meter, and it also shows the only way probes dont work.
Offline The Soulman
  • The sky is the limit!
« Reply #256 on: January 23, 2018, 02:58:16 pm »
Actually the 10 A input provides a perfect low impedance path to the COM terminal so it would work, funny nonetheless.  :P
Offline MT
  • Country: aq
« Reply #257 on: January 23, 2018, 03:21:28 pm »
The following users thanked this post: fourtytwo42
Offline MT
  • Country: aq
« Reply #258 on: January 23, 2018, 03:45:03 pm »
heey! Im  just repaired my HD with a hotgun and i didnt burn my hand, im superman!
The following users thanked this post: Towger, fourtytwo42
Offline kjr18
« Reply #259 on: January 23, 2018, 04:17:14 pm »
No wonder, it's not even turned on.  :-DD
Offline MT
  • Country: aq
« Reply #260 on: January 23, 2018, 04:18:33 pm »
He is a true superman! :D
Offline mcinque
  • I know that I know nothing
« Reply #261 on: January 27, 2018, 04:44:11 pm »
This stock image was ok and has been used on a book:
But when our national electric provider must choose and edit an image to use for the "request an inspection" page on their website a new image fail is born.
In the best scenario, she should be doing something like piercing the case with the probes to touch the screws.
I did not expect this kind of things from a national provider :palm:
« Last Edit: January 27, 2018, 04:51:30 pm by mcinque »
Offline Sehsuan
  • Country: sg
« Reply #262 on: January 29, 2018, 04:21:08 am »
I really like this new solder wire dispenser, but these new lead free solder compounds takes ages to melt:
that card looks immaculately designed - I'll make a guess it's a Matrox. I still have a couple of their older cards for keepsakes, and their array of resistors are always arranged perfectly in a grid-like layout.
This gem accompanied a newspaper article today:
(here is the article: http://spravy.pravda.sk/ekonomika/clanok/413847-zlacnenie-elektriny-zavisi-od-isticov-v-dome/ - it talks about electricity prices being dependent on the size of the circuit breakers in the home)
Gotta love that cheapo meter. Oh and the guy forgot to turn it on as well ...
he's using his fingers to PROBE the problem....
 :-DD
I never thought I would see a gaff like this from the ARRL....
good grief! a lark's head to secure the back D ring on a harness... no no!
but she's got REALLY strong right biceps to hang on in this position to use a walkie talkie...  |O
Using Hyelec/Peakmeter PM8236 & PM2128 currently
Offline Halcyon
  • Global Moderator
« Reply #263 on: January 29, 2018, 05:50:47 am »
This little gem made the news here recently. It's just one of many, many failures which is Australia's National Broadband Network (NBN).
For those with a keen eye, it appears the girls torso just disappears under the controller. Then there is a controller itself, now I'm not a gamer, but apparently that PlayStation controller was from the mid-2000's and didn't come with a micro USB port (it has been photo-shopped in to replace the cable).
But, what else would we expect from a Government-owned company who thinks that in 2018, using old, corroded copper phone lines for broadband is perfectly fine. Their idea of "fast internet for everyone" is misleading, apparently 25 Mbps downstream is enough for anyone (and that's if your shitty phone lines can support such blazing speeds!)
« Last Edit: January 29, 2018, 05:52:31 am by Halcyon »
Offline amspire
« Reply #264 on: January 29, 2018, 06:06:56 am »
I think the NBN photo is fine - it is just the result of the distortions caused by a wide angle lens close to the face. It is just a normal couple of Aussie kids happy because another packet of bytes has finally arrived via the NBN. They have probably been waiting days for it.
Offline Urs42
« Reply #265 on: January 29, 2018, 06:12:34 am »
 :-DD
No, look closer, he is using two CAT III rated S-ATA probes  :wtf:
Offline Red Squirrel
« Reply #266 on: January 29, 2018, 06:49:20 am »
Also never seen meters where the probes connect UNDER it lol.
The following users thanked this post: AF6LJ, SingleBitError
Offline timelessbeing
« Reply #267 on: January 29, 2018, 07:16:46 am »
This reminds me of "Women Struggling to Drink Water"
https://www.thehairpin.com/2011/11/women-struggling-to-drink-water/
also common is "Woman Laughing Alone With Salad" and "Women Resisting Delicious Cakes and Pies"
The following users thanked this post: Bud
Offline Naguissa
    • Foro de electricidad, electrónica y DIY / HUM en español
« Reply #268 on: January 29, 2018, 12:11:18 pm »
Salads explain really good jokes, don't do it?
Enviado desde mi Jolla mediante Tapatalk
« Last Edit: January 29, 2018, 03:37:27 pm by Naguissa »
Offline oldway
« Reply #269 on: January 29, 2018, 03:32:48 pm »
Who said acetylen is dangerous ?
Safety first....
Acetylen generator.
Offline Bud
« Reply #270 on: January 29, 2018, 03:57:51 pm »
If your Jeep gets stuck in jungles, this car mechanic will be your only hope  :scared:
Offline AF6LJ
« Reply #271 on: January 29, 2018, 04:35:57 pm »
I love these pictures...
There is no limit to Stupid in the Universe. :D
Sue AF6LJ
Offline kjr18
« Reply #272 on: January 29, 2018, 05:11:13 pm »
Can someone tell me where I can find a soldering iron like these? Looks practical and easy to use :-DD
Offline oldway
« Reply #273 on: January 29, 2018, 05:35:04 pm »
Thanks, I rather do the repair myself....
Happily, my jeep don't need a car mechanic.
Nb: truly my horse...!
« Last Edit: January 29, 2018, 06:37:25 pm by oldway »
Offline IanMacdonald
    • IWR Consultancy
« Reply #274 on: January 29, 2018, 08:48:59 pm »
It's think that smoke must be some really strong drug that eliminates pain...
Well, as a real solderer female told me, never wear tights and a miniskirt when soldering. (Not that I've tried it) That is a sure recipe for YIKES!!! and prancing round the room in pain.  :scared:
I find it amusing that the Victorians, one of the most prudish societies ever, based a lot of their culture on one of the most sexually perverted societies ever. Of course the naughtier examples of Greek pottery etc were kept hidden from the view of all but a few knowledgeable historians. That, and the Victorians thought the Greeks loved the cool look of marble architecture. In fact, they used it for its structural properties and painted it bright colours. :wtf:
« Last Edit: January 29, 2018, 09:01:39 pm by IanMacdonald »
