Author Topic: Stock Electronic Image FAILS  (Read 510413 times)
0 Members and 52 Guests are viewing this topic.
Offline Cyberdragon
Re: Stock Electronic Image FAILS
« Reply #525 on: September 09, 2019, 07:56:38 pm »
Actually, a stethascope can come in handy to diagnose mechanical issues with hard drives, fans, or anything else with moving parts that could have bearing wear or whatnot.
*BZZZZZZAAAAAP*
Voltamort strikes again!
The following users thanked this post: NiHaoMike, tooki
Offline mc172
« Reply #526 on: September 09, 2019, 08:24:09 pm »
I prefer to use a long screwdriver with my thumb pressed on the handle end, and put the knuckle of my thumb on my ear, pressing against that little flap to close the ear canal. Works really well. ;)
Offline maginnovision
« Reply #527 on: September 09, 2019, 08:50:24 pm »
Usually you want a mechanics stethoscope. Similar to a screwdriver but little more sensitive.
Offline magic
« Reply #528 on: September 09, 2019, 09:41:22 pm »
The lightbulb was a distraction from the real fail - I/O shield of some wrong motherboard version was used :--
She doesn't seem clueless, how do you assume this from the picture? Insulting!
Simple, she brought screwdriver to a toolless rack :D
The following users thanked this post: Naguissa
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #529 on: September 09, 2019, 10:22:51 pm »
Maybe some gorilla socked those captive thumb screws down with a pair of vise grips...
-Pat
Offline Mr. Scram
  • Display aficionado
« Reply #530 on: September 09, 2019, 10:33:40 pm »
Try removing that filler plate without a tool.
Offline NiHaoMike
    • Facebook Page
« Reply #531 on: September 10, 2019, 12:42:49 am »
Oh and the titles they give to these images...  :wtf:  ??? For example, look at this one:
https://www.123rf.com/photo_82601848_young-sexy-woman-in-the-data-center-server-room-didn-t-know-what-to-do.html
Yes, it's "Young sexy woman in the data center server room didn't know what to do".  :-DD  She doesn't seem clueless, how do you assume this from the picture? Insulting!  :-DD
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Offline FreddieChopin
  • Country: ua
goatse
« Reply #532 on: September 10, 2019, 06:00:33 pm »
Offline tooki
« Reply #533 on: September 12, 2019, 11:53:38 am »
That's called the tragus, by the way!
Online EEVblog
« Reply #534 on: September 15, 2019, 12:10:45 pm »
I never go on the job without my no name dial-o-luck multimeter.
Offline HwAoRrDk
« Reply #535 on: September 15, 2019, 01:16:43 pm »
Maybe that's not a function dial, but rather it's the world's first wind-up clockwork multimeter. :D
Offline PA0PBZ
« Reply #536 on: September 15, 2019, 01:20:16 pm »
Worlds first?
https://www.sterling-power-usa.com/SterlingPowerWindupmultimeter.aspx
Offline edy
    • DevHackMod Channel
« Reply #537 on: September 15, 2019, 03:06:25 pm »
Worlds first?
I don't get it. Yes I understand it may have a use case but seriously, why complicate the situation with a mechanical system that is prone to breakage and adds weight and bulk to the item? I mean, how often are you changing batteries in your multimeter? I don't think I change mine once every 5 years even? Am I special or did I miss something? I get a hand crank for a flashlight... you drop it in an emergency toolbox and never worry about it again. But a multimeter, I'm not sure it is worth it.
Offline Bud
« Reply #538 on: September 15, 2019, 03:29:58 pm »
What if apocalypse will last more than 5 years Edy?...  ::)
Offline NiHaoMike
    • Facebook Page
« Reply #539 on: September 15, 2019, 05:19:40 pm »
It's not hard to find a solar panel more than 5 years old that still works great.
Offline edy
« Reply #540 on: September 15, 2019, 11:12:35 pm »
I would get it if it had the option to also output the generator voltage on the leads... then you could also try to power the item during the Zombie apocalypse.   :-DD
Offline Cyberdragon
« Reply #541 on: September 16, 2019, 01:04:23 am »
Unless it's the Revolution universe where there's evil nanites everywhere that consume all electrical charge for themselves unless you have the "magic devices" to turn them off. ::) ;D (which of course all makes no sense and also getting rid of lightning that causes natural forest fires would simply increase the collapse of the environment till there was nothing left but nanites and rocks).
You can also just use normal rechargeable batteries in your multimeter or make one like Kasyan did.
*BZZZZZZAAAAAP*
Offline tooki
« Reply #542 on: September 16, 2019, 03:23:29 am »
Worlds first?
As an aside, that meter does do one thing that I'm surprised isn't common (no pun intended): different color jacks for the A and mA jacks. (Unfortunately, they didn't do the obvious thing of matching the jack color to the knob position label: they use yellow for all the current ranges, instead of yellow for A and green for µA and mA!)
I mean, I understand the logic of matching the jack color to the lead color as essentially all meters do, but there would be some logic in using additional colors.
Online Red Squirrel
« Reply #543 on: September 16, 2019, 04:04:27 am »
This just made me realize... I don't think anyone makes a solar powered multimeter (with fake solar cell of course). I think someone should start a kickstarter.  >:D
The following users thanked this post: Vovk_Z
Offline Bud
« Reply #544 on: September 16, 2019, 04:29:56 am »
Then you won't have a voltage to measure in the first place.
Not a concern! When apocalypse comes having a multimeter will be the least of your worries.  >:D
Offline floobydust
« Reply #545 on: September 16, 2019, 04:41:16 am »
Photoshopped or not, that multimeter is famous, it appears in many stock photos as if one studio bought it.
Online EEVblog
« Reply #546 on: September 16, 2019, 05:06:43 am »
Is that an orange COM jack?  :o
Offline bsfeechannel
« Reply #547 on: September 16, 2019, 06:15:38 am »
And speaking of photoshopped multimeters...
I guess the reading should be OL. EDIT: Or 0.00 A, considering that the range switch is in the A position.
« Last Edit: September 16, 2019, 06:34:19 pm by bsfeechannel »
Offline McBryce
« Reply #548 on: September 16, 2019, 07:07:41 am »
Technically not a multimeter, but not exactly new either...
McBryce.
Offline edy
« Reply #549 on: September 16, 2019, 04:25:08 pm »
Right, when the apocalypse comes you will want something that shoots LEAD rather than measuring LED. You might also be hacking everything in site, so a multimeter would come in handy, but then again so would an energy source. Unless, of course, you are running purely on petrol like Mad Max with no generators.  :-DD
