Author Topic: Stock Electronic Image FAILS  (Read 525856 times)
0 Members and 27 Guests are viewing this topic.
Offline AF6LJ
Re: Stock Electronic Image FAILS
« Reply #50 on: August 20, 2015, 11:41:19 pm »
I had to.
I made my own.    :D
Okay this one is in the top five Best.
Sue AF6LJ
Offline Godzil
    • My own blog
« Reply #51 on: August 20, 2015, 11:42:32 pm »
Red Squirrel, there are some monkey missing, and more battery on the table would be better, but I really like it anyway :)
It may be my next desktop wallpaper  :D
When you make hardware without taking into account the needs of the eventual software developers, you end up with bloated hardware full of pointless excess. From the outset one must consider design from both a hardware and software perspective.
-- Yokoi Gunpei
Online wraper
  • Country: lv
« Reply #52 on: August 20, 2015, 11:43:32 pm »
Some soldering absurdity...
This is not absurdity and not soldering, actually there is no soldering iron.
Although this probably is soldering iron, this have nothing to do with soldering. http://artbysusanlenz.blogspot.com/2008/08/teaching-fibers-at-art-museum.html
BTW there are wood burning pens which look like soldering iron but are not. http://www.amazon.com/SE-WP30-Wood-Burning-Pen-Set/dp/B000JT3EZA
e
« Last Edit: August 20, 2015, 11:47:09 pm by wraper »
Offline Red Squirrel
« Reply #53 on: August 20, 2015, 11:48:05 pm »
    Also notice that it's not actually plugged in.  :-DD
I actually didn't even notice.   :palm: I don't have a digital scope. Did you capture it then remove the probe?
Yeah I took two pics then merged them together I basically just cut out the parts where I wanted to see part of the other pic.
And yeah I need a monkey.  ;D
Offline Godzil
    • My own blog
« Reply #54 on: August 20, 2015, 11:49:36 pm »
BTW I could say that your probe is really well calibrated, I can't do better!
-- Yokoi Gunpei
« Reply #55 on: August 21, 2015, 12:02:52 am »
I had to put my tongue at a really weird angle for that one.  ;D
Offline Halcyon
  • Global Moderator
« Reply #56 on: August 21, 2015, 12:03:38 am »
In Soviet Russia, iron solders YOU.
Tac Eht Xilef
  • Guest
« Reply #57 on: August 21, 2015, 01:49:35 am »
Somebody get her a new iron, please! :scared:
I can't believe no one noticed.. Out of all the pictures posted, this kid is the only one who is holding a hot iron right!!!
Kudos to her parents!!!
 :-DD
Ah, memories! I remember building my first 'real' kit - a digital alarm clock, from Delsound if I remember - like that when I was 10 or 12.
Using an 120W electrician's firestick with an 8 or 10mm chisel tip to solder a 1" VFD & 40-pin DIP chip certainly helps you learn a deft touch and a good eye. With a bit of practice you can hold it like a pencil and solder with the board & your elbow on the bench & your hand in the air, and you hardly notice the tip is 8" away from your hand...
Offline Stonent
« Reply #58 on: August 21, 2015, 01:56:13 am »
Just jam that in there and short across several QFP pins.
Checking the resistance between a BGA and a foot of air?
We import third world children to do our repairs.
These were just fun
« Last Edit: August 21, 2015, 02:11:05 am by Stonent »
The following users thanked this post: Electro Detective
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #59 on: August 21, 2015, 04:25:51 am »
Yeah, but did you have the cleavage that they offer? :D
That should be a column added to the meter comparison sheet.
Don't ask a question if you aren't willing to listen to the answer.
Offline EEVblog
« Reply #60 on: August 21, 2015, 04:37:06 am »
Yep, it gets my vote.
Offline pickle9000
« Reply #61 on: August 21, 2015, 04:55:43 am »
One of the images with an older guy shows him using a marking tool. It's a carvers tool.
Offline steve30
    • Stephen Coates' Homepage
« Reply #62 on: August 21, 2015, 05:11:13 am »
I love the ones with the miniature men on the PCBs. I've seen various people do that before and it always looks fun. Here's a good one on an Amiga 1200 PCB: http://olhares.sapo.pt/mudar-o-chip-foto5999333.html
Offline Stonent
« Reply #63 on: August 21, 2015, 06:12:47 am »
This thread is giving me a headache how did we get from where this thread started to feminism homosexuality and the rest of this crud?
 Someone PLEASE find some more of these goofy pictures.
+1.  Countdown to thread being locked soon ...
Anyway, I did a search for "stock photo multimeter" and it led to
http://www.shutterstock.com/s/multimeter/search.html
The number of mistakes is funny.  Meters with a reading on the lcd display, but rotary switch set to off.  People taking measurements, but meter is turned off and lcd display is blank.  People measuring mains with black probe in V/ohm jack and red probe in A jack and rotary switch set to DCV. I quit looking after page 1.
If you google stock photo multimeter, I have the exact one in the first picture.  Someone gave it to me because they don't use it.  Neither do I, but it's around somewhere.
Offline Stonent
« Reply #64 on: August 21, 2015, 06:14:58 am »
Oh RetroSeteve, you never cease to prove your handle. :)
Offline Agent24
  • I see dead caps
« Reply #65 on: August 21, 2015, 10:18:49 am »
I also like to warm up my screwdriver before I work, it helps get the screws out faster!  :-DD
Offline rickselectricalprojects
« Reply #66 on: August 21, 2015, 11:14:19 am »
i think it might be dangerous to measure a high voltage disposable camera capacitor charger circuit when the DMM is switched to the resistance range...
Offline Psi
« Reply #67 on: August 21, 2015, 11:44:02 am »
You'd think Mythbusters would know better. but no.
They still have a shot in the intro sequence of someone trying to solder a high density BGA style pcb with a horrible iron and making an awful mess
« Last Edit: August 21, 2015, 11:46:48 am by Psi »
Offline AF6LJ
« Reply #68 on: August 21, 2015, 01:16:24 pm »
Looks like they are using plumbers solder, and my first soldering iron to boot....
Sue AF6LJ
Offline Godzil
    • My own blog
« Reply #69 on: August 21, 2015, 01:38:25 pm »
You are joking, but in some situation, heating a screws can help to remove it, especially if it was rusty
-- Yokoi Gunpei
Offline amyk
« Reply #70 on: August 21, 2015, 01:52:32 pm »
Do people actually pay for these?  It seems to me it would be cheaper in the long run to get a DSLR and make your own.
I suppose this is a case of supply being much greater than demand, with people thinking "I have a decent camera, why not take random pictures of various things and try to sell them."
It's strange though, as you say those who are in the industry would likely take the pictures themselves and wouldn't make such ridiculous mistakes. (E.g. if you were advertising computer repair, would you really use a photo of a wrench being used to remove a CPU...?) Those who aren't, are unlikely to need such pictures. Maybe these are for domain squatters and other scammy types looking to find a vaguely relevant image.
Did anybody else notice that Fungus has posted pictures of three different women, with watermarks from three different hosting sites, all supposedly working on the SAME motherboard?  What's with that?
I did and thought it was rather funny. There must be a lot of those motherboards out there.
Looks like one I bought from New Egg on close out and had to return because it was defective.
It's an MSI MS-7525. Very low-end board for prebuilt HP/Compaq ssytems.
Offline TerraHertz
    • It's not really a Blog
« Reply #71 on: August 21, 2015, 02:39:43 pm »
Awww, I'm hurt no one remembers my contribution to soldering iron stock(y) images.
https://www.eevblog.com/forum/chat/i-am-waiting-for-the-eevblog-exclusive/msg719540/#msg719540
Anyway, for contrast a few woman soldering shots that are more the real thing.
That SexyCyborg from Shenzen again.
Note I said 'real thing', not 'real things.' The latter would be inaccurate.
Offline AF6LJ
« Reply #72 on: August 21, 2015, 03:24:55 pm »
Amazing, Simply Amazing.
Long Long ago there use to be a television show called Hawaii 50, the main character had a habit of talking into the back of the microphone in his police vehicle. I use to get a good laugh out of that.
Sue AF6LJ
Offline Falcon69
« Reply #73 on: August 21, 2015, 05:13:50 pm »
That is also a Right Handed screw driver she is holding in her left hand.
The following users thanked this post: jancumps
Offline Agent24
  • I see dead caps
« Reply #74 on: August 21, 2015, 11:30:49 pm »
I did not think of that - have never done it. I suppose you would want to heat a rusty screw directly though, rather than heating the screwdriver first.
