Author Topic: Server Error Reports  (Read 937407 times)
Offline gnifTopic starter
  • Views and opinions are my own
Re: Server Error Reports
« Reply #700 on: February 06, 2024, 04:36:59 am »
Heading this off before people report it. There was an unexpected power interruption at the Data Centre that brought the servers down that are hosting this website. Things are fully back online, and we are seeking information from the DC as to what the reason for the outage was.
The following users thanked this post: EEVblog, Ed.Kloonk, SeanB, Kean
« Reply #701 on: February 06, 2024, 09:53:50 am »
Just a heads up.
In the next 30 minutes or so there will be some disruptions while issues from the outage today are rectified. I will as always, post here when this work is complete.
Edit: Still in progress. sorry for the long outage, we are still having issues with data consistency across the cluster. We had the failed drive replaced and the fault moved to another disk, so we have been carefully bringing things back into a consistent state before allowing the DC to mess around with things futher.
« Last Edit: February 06, 2024, 04:53:49 pm by gnif »
Offline ifrythings
« Reply #702 on: February 06, 2024, 05:11:18 pm »
Just a heads up.
Would this cause the 502 bad gateway error and random “file not found” error that will load after several refreshes?
« Reply #703 on: February 06, 2024, 05:13:45 pm »
Yes, one of the servers in the cluster was having issues with accessing content on the disk.
The following users thanked this post: The Soulman, Nominal Animal
« Reply #704 on: February 07, 2024, 02:49:26 am »
Services have returned to normal.
The following users thanked this post: EEVblog, IanB, xrunner, Kean
« Reply #705 on: April 22, 2024, 01:29:53 am »
Seems there was some kind of outage at the data center again, both of our servers were rebooted. Services are back online, but may be a bit slow while the servers caches warm back up.
The following users thanked this post: EEVblog, Kean, Brumby, MK14
Offline Simmed
« Reply #706 on: April 05, 2025, 08:41:58 am »
FYI encountered 502 and 504 screen about 1 - 2hrs ago
The following users thanked this post: SuperSVGA
« Reply #707 on: April 05, 2025, 09:27:20 am »
Yes, we are still not fully operational but working on it.
The following users thanked this post: Kean, watchmaker
Offline Kean
    • Kean Electronics
« Reply #708 on: April 05, 2025, 09:39:11 am »
I am getting the occasional "file not found" error, and some other weirdness (error thanking posts, missing images).
I hope that whatever caused the problem, it doesn't take too much time out of your weekend.
The following users thanked this post: Foxxz, 5U4GB, Analog Kid
Offline hexbus
« Reply #709 on: April 05, 2025, 04:32:41 pm »
Same here.  I had to refresh several times while trying to attach and post just now.
Offline PA0PBZ
« Reply #710 on: April 05, 2025, 06:16:10 pm »
If I remember correctly there is a load balancing system with 2(?) servers and it looks like one of the servers is not playing nicely which gives the 'file not found' message. So refreshing the page until you land on the good server solves it for now. I'm sure gnif will be able to solve it once they are awake over there.
Offline EEVblog
« Reply #711 on: April 06, 2025, 01:12:49 am »
Test.
Yeah, file not found images missing etc.
« Reply #712 on: April 06, 2025, 01:18:03 am »
Things should be back to normal shortly, the second node had a failure with the clustered storage and was removed from the storage group. The re-sync has completed and now I am just in the process of bringing the other services on the server back up and online.
The following users thanked this post: EEVblog, Kean, MK14
« Reply #713 on: April 06, 2025, 01:24:58 am »
All services have been returned to normal.
Offline EEVblog
« Reply #714 on: April 06, 2025, 01:39:59 am »
TEST.
Everything seems fine now  :-+
What was the exact initial cause?
« Reply #715 on: April 06, 2025, 01:47:18 am »
I will email you on this as it's a security risk to expose details of your configuration
« Last Edit: April 06, 2025, 02:02:23 am by gnif »
Offline MK14
« Reply #716 on: May 27, 2025, 03:05:19 pm »
Perhaps 10% .. 50% of the time (but it can be fine, for many minutes on the trot), maybe on 10+ occasions, in the last few minutes (longer now, since I edited the post), I'm getting database errors, on this forum.
E.g. 'Show new replies to your posts.', but I'm seeing it in other place(s) as well.
Database Error
Please try again. If you come back to this error screen, report the error to an administrator.
Back
« Last Edit: May 27, 2025, 03:10:27 pm by MK14 »
The following users thanked this post: Xena E
Offline Simmed
« Reply #717 on: May 27, 2025, 03:15:13 pm »
when click forum home orange button
it displays error (randomly)
the normal forum page does not appear
« Last Edit: May 27, 2025, 03:19:03 pm by Simmed »
Offline themadhippy
« Reply #718 on: May 27, 2025, 03:17:44 pm »
Same here as wot MK14 is getting
The following users thanked this post: MK14
Online Xena E
« Reply #719 on: May 27, 2025, 03:25:57 pm »
+1
« Reply #720 on: May 27, 2025, 03:56:01 pm »
Yep.
They need to feed the hamsters running on the generator wheels more
« Reply #721 on: May 27, 2025, 11:26:49 pm »
I'm looking into it
The following users thanked this post: Andy Watson, MK14
« Reply #722 on: May 28, 2025, 12:04:23 am »
Seems there was a substantial traffic spike that may have been the cause, unfortunately due to a configuration error the logs during that period are not very useful (reverse proxy IP logged instead of real IP). The traffic looks quite unusual and may have been either a DoS attack, or some super aggressive crawler. We will simply have to wait and see if it occurs again.
« Last Edit: May 28, 2025, 12:08:36 am by gnif »
The following users thanked this post: EEVblog, Kean, MK14, Xena E
Offline EEVblog
« Reply #723 on: May 28, 2025, 01:11:40 am »
Another new AI bot sucking up everything perhaps?
« Reply #724 on: May 28, 2025, 01:24:58 am »
That's my guess
