Author Topic: Server Error Reports  (Read 961067 times)
0 Members and 47 Guests are viewing this topic.
Offline voltsandjolts
Re: Server Error Reports
« Reply #750 on: July 20, 2025, 04:07:50 pm »
On Apple stuff, the iCloud 'Private Relay' (aka VPN) service may be blocked by recent forum changes.
Offline EEVblog
« Reply #751 on: July 21, 2025, 12:18:50 am »
Can anyone else confirm this?
Offline gnifTopic starter
  • Views and opinions are my own
« Reply #752 on: July 21, 2025, 12:42:43 am »
The IP reported by bicycleguy was incorrectly flagged as belonging to a major data center, it has been rectified.
Doubtful, no apple owned IP ranges had been blocked. Can you please DM me with the IP of your system when you have this issue while on the Apple VPN
« Reply #753 on: July 21, 2025, 06:04:44 pm »
IP provided by @voltsandjolts belongs to CloudFlare which had to be blocked, it was one of the worst offenders and will not be unblocked.
The following users thanked this post: EEVblog, voltsandjolts, Kean
Offline EEVblog
« Reply #754 on: July 21, 2025, 11:00:27 pm »
Using Cloudflare as some sort of VPN?
« Reply #755 on: July 22, 2025, 12:44:08 am »
Seems so, looks like they offer a VPN service to large companies.
Offline tubularnut
« Reply #756 on: July 24, 2025, 05:08:00 pm »
I use Apple Private Relay on 2 Mac devices, and an iPhone, I ca't access EEVBlog on any of them from home or when away, unless I turn off Private Relay.
The following users thanked this post: voltsandjolts
« Reply #757 on: July 27, 2025, 03:02:17 am »
Please stop replying to this thread unless you have an actual server error to report. Blocked VPN networks are not server errors and have only been blocked due to abuse originating from these networks.
Offline themadhippy
« Reply #758 on: December 08, 2025, 05:39:54 pm »
Is the site on a go slow or is the problem  somewhere else? Seems to only be  this site ,at least from here .Apparently theres 142569 Guests viewing the site so i guess that may slow things down a bit.
The following users thanked this post: MK14, The Soulman
Offline MK14
« Reply #759 on: December 08, 2025, 06:03:12 pm »
Same here.
Also, sometimes getting (probably related):
502 Bad Gateway
nginx
« Reply #760 on: December 08, 2025, 06:55:34 pm »
Yep record hits are growing daily....173827 online now.....the EEVblog servers are struggling under the strain.
Avid Rabid Hobbyist
Online pcprogrammer
« Reply #761 on: December 08, 2025, 07:25:55 pm »
Struggling to say the least.  |O
It takes seconds to load a page. Started this afternoon already. My time, which is Paris/Amsterdam time. Now 20:25 still slow as hell.
Offline Benta
« Reply #762 on: December 08, 2025, 08:19:44 pm »
Long response times here as well.
Is it AI harvesting or what's up?
The following users thanked this post: Uunoctium
Offline TimFox
« Reply #763 on: December 08, 2025, 08:22:03 pm »
Same here, much worse than normal.
Offline Stray Electron
« Reply #764 on: December 08, 2025, 08:26:52 pm »
  X2.  Posting anything or loading a page is VERY slow.
Online PA0PBZ
« Reply #765 on: December 08, 2025, 08:35:50 pm »
138901 Guests, 270 Users
Totally insane, I guess gnif has to block some ip ranges again but I fear this will be a lost battle soon.
Maybe only allow logged in users in the near future? It's a bad idea but what else can be done?
Offline MK14
« Reply #766 on: December 08, 2025, 09:13:35 pm »
Then the AI, can create user(s) (as many as needed, perhaps hundreds of new ones), just to do the web-crawling, so that wouldn't necessarily work.
I thought there were already rate limits (per time period, such as hourly), per IP address, to control/limit web-crawling and similar from loading/slowing this website by too much.
Edit: Typos
« Last Edit: December 09, 2025, 12:50:11 am by MK14 »
Online PA0PBZ
« Reply #767 on: December 08, 2025, 09:28:29 pm »
Maybe the AI created users are easy to spot and delete? If there is a rate limit it doesn't seem effective, and AFAIK these crawling thingies are changing IP constantly.
Offline EEVblog
« Reply #768 on: December 08, 2025, 09:40:57 pm »
The great part about the forum is that it's heavily indexed for public searching.
The following users thanked this post: tooki, MK14
Offline TimFox
« Reply #769 on: December 08, 2025, 09:43:00 pm »
I noticed that the peak number of guests today set a new record.
Offline EEVblog
« Reply #770 on: December 08, 2025, 10:35:02 pm »
Still showing a 135,000 guests, but forum response is now instant again. Must be a stats lag there.
Offline TimFox
« Reply #771 on: December 08, 2025, 10:57:00 pm »
Shortly after that post, things looked good, but now it’s slowing down again.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #772 on: December 08, 2025, 11:19:09 pm »
Can confirm, super slow process to log in and pages hesitate when loading.  :-\
The internet is busted.   :-BROKE
Offline EEVblog
« Reply #773 on: December 08, 2025, 11:34:31 pm »
gnif is on the case...
The following users thanked this post: MK14, pcprogrammer
Offline Benta
« Reply #774 on: December 08, 2025, 11:41:06 pm »
Last 5 minutes it's been wonderfully fast...
