Author Topic: What's this please? (Component Advice)  (Read 1529858 times)
Offline HwAoRrDk
Re: What's this please? (Component Advice)
« Reply #1850 on: August 10, 2023, 06:23:00 am »
Actually, I found it. It's a Diodes Inc SMAJ24CA 24V bidirectional TVS diode. The marking is 'UZ'.
The following users thanked this post: Majorstrain
Offline Majorstrain
« Reply #1851 on: August 10, 2023, 06:31:12 am »
Thanks heaps.  The 24V would make sense, the supply is 24 volts.
Cheers,
Phil
Offline tohtorizorro
Strange tube thingy
« Reply #1852 on: October 12, 2023, 11:06:02 pm »
What might this be?
It was found inside a Pioneer SA-9800 stereo amp, supposedly serving some sort of DIY modification purpose.
The photos show only 3 wires but allegedly a fourth one had come off.
« Last Edit: October 13, 2023, 07:46:42 am by tohtorizorro »
Online Andy Watson
« Reply #1853 on: October 12, 2023, 11:38:58 pm »
A thermally operated relay. Probably functioning as a time-delay, although it could be sensing power.
Offline Mr.B
« Reply #1854 on: October 13, 2023, 01:59:42 am »
Perhaps speaker de-thump at power up?
Re: Strange tube thingy
« Reply #1855 on: October 13, 2023, 07:45:59 am »
Spot on!
Someone managed to dig up this web page confirming what Andy said.
Offline w.v.s.
« Reply #1856 on: October 14, 2023, 10:49:52 am »
Hi, i know what it is, but I would like to know who made it and where I could find a datasheet for it. I hope this is the right thread for this question, nevertheless.
Online ebastler
« Reply #1857 on: October 14, 2023, 11:48:27 am »
Looks like a Fujitsu logo?
And since you didn't tell us: It's a CCD.  :)
The following users thanked this post: w.v.s.
Offline meadiode
« Reply #1858 on: December 21, 2023, 02:09:59 pm »
Got a few of these little guys recently. Apparently pulled out from some equipment, probably military, from the mid 80s. The marking says Plessey GPD340 (or GPD340P). A search for the datasheet came to nothing.
Has anyone come across these displays, or similar? Maybe there's a datasheet, or at least a pinout?
1959006-0
Offline CJay
« Reply #1859 on: December 22, 2023, 05:48:14 pm »
Offline Fryguy
« Reply #1860 on: December 24, 2023, 02:36:03 pm »
Can somebody tell me what this part is ? Found it on a powersupply board of my dead russian benchtop meter . Could be some kind of regulator IC .
Born error amplifier  >.<
Offline Fryguy
« Reply #1861 on: December 24, 2023, 03:10:27 pm »
(Attachment Link)
Those are 2 digit LED dotmatrix smart displays - afaik they have an integrated ascii decoder chip . The HP hdsp-2xxx series (e.g. hdsp-2001) should be very similar .  Take a look at this : https://www.digchip.com/datasheets/parts/datasheet/021/HDSP-2001-pdf.php
I used a couple of these about 15 years ago in a temperature controller : https://mm.digikey.com/Volume0/opasdata/d220001/medias/docus/1/SLx2016.pdf
« Last Edit: December 24, 2023, 03:30:36 pm by Fryguy »
Offline mendip_discovery
« Reply #1862 on: December 24, 2023, 05:29:30 pm »
Can someone help me work out the connector? I have a Bemex TC303 with no power supply so I need a new plug. It is only a 9V supply so not overly hard to get.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Offline meadiode
« Reply #1863 on: December 25, 2023, 12:07:52 am »
Nope, they're not similar - simply there's not enough pins(only 8 ) to apply HDSP-2xxx's driving scheme, which requires at least 9 pins (5 to drive columns, 1 for data-in, 1 for CLK + GND and VCC). There's got to be some more sophisticated serial protocol like in HCMS-29xx series.
Offline meadiode
« Reply #1864 on: December 25, 2023, 12:14:28 am »
Looks like it's this thing - KPS104G
https://www.radiomuseum.org/tubes/tube_kps104g.html
Offline Fryguy
« Reply #1865 on: December 25, 2023, 02:11:16 pm »
That's it , thank you   :-+   Interresting part - a twin N-FET , never seen that before   :)
What about the Osram SLx2016 ? This one is also a bit different - only 4 digits and less pins  . . . maybe your 2 digit models need even less pins ?  :-/O
At least it's a place to start . But you could be right about a serial interface  :-//
You do not have the instruments they were taken from ? At least one to do some reverse engineering ?
« Last Edit: December 25, 2023, 02:16:04 pm by Fryguy »
Offline meadiode
« Reply #1866 on: December 25, 2023, 07:54:16 pm »
No, nothing whatsoever, that's why I'm asking here.
So far, I've not found any info/schematics/similar models from other manufacturers on the internet. So it seems, shooting in the dark with driving schemes is the only option to display something on them.
« Last Edit: December 25, 2023, 07:56:11 pm by meadiode »
Offline patrik96
  • Country: hu
« Reply #1867 on: December 28, 2023, 08:50:32 am »
Dears, May someone able to identifiy that component (from OWON frontend) it will big help because it need to be repair.
As I know the component start H1K is between the VGA and ADC , what start VUBI is somehow a power suply the ST3FF may also some power supply
Thanks
Online gamalot
  • Correct my English
    • Youtube
« Reply #1868 on: December 28, 2023, 11:52:37 am »
Thanks
First one: https://www.ti.com/product/TLV62130
Second one: https://www.analog.com/en/products/ada4932-1.html
« Last Edit: December 28, 2023, 12:05:49 pm by gamalot »
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
Offline patrik96
  • Country: hu
« Reply #1869 on: December 28, 2023, 12:28:29 pm »
Thanks
Thanks, is is strange because the TLV62130 diven a TPS723 (T08I) what is neg regulator...
Online gamalot
    • Youtube
« Reply #1870 on: December 28, 2023, 12:40:32 pm »
Thanks
Read the datasheet, page 25.
"The TLV62130 can be used as inverting power supply by rearranging external circuitry as shown in Figure 40."
Offline patrik96
  • Country: hu
« Reply #1871 on: December 28, 2023, 04:06:07 pm »
Thanks
Thanks your are right,
Offline samuelharris55@gmail.com
« Reply #1872 on: December 30, 2023, 10:03:12 pm »
hello!! trying too find a chromebook ic bios chip too a chromebook 11mk ee! the bios chip is Winbond ic bios chip W25Q64JWIM do anyone have a copy!! :-/O thank you very much!! if you can help!! Thanks!!!
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #1873 on: February 12, 2024, 11:11:34 pm »
Any ideas what this buck controller IC may be? It is a ~100V input voltage buck, with 12V output.  Seems to be the typical "floating controller" topology, however it has a rather not typical differential voltage sensing (see the two identical 121K - 3K9 voltage dividers looking at the output voltage). Sry, the schematic is a mess, just as I drawn it from the PCB.
Pinout of the IC is now clear. Marking not so much, someone has scared it with some abrasive tool, so we can be only sure about the first letter, S. Next letter may be L, but it may also be not. No idea how would one search for this. Turned whole LCSC upside down, looking for some SLxxxx chip that would match, found nothing even remotely close. The bottom 4 digits is likely just a date code.
Thank you for any ideas.
Offline w.v.s.
« Reply #1874 on: March 27, 2024, 10:43:38 pm »
Hello everybody,
today, I'm searching for connectors for two generations of mitutoyo touch signal probes. I'll start with the newer version. Does anybody know that connector type or has an idea, which similar connector could be modified easily to make a suitable counterpart?
« Last Edit: March 27, 2024, 11:08:58 pm by w.v.s. »
