Author Topic: ODB++ sample files  (Read 11815 times)
Offline LukasTopic starter
    • carrotIndustries.net
ODB++ sample files
« on: March 30, 2020, 11:09:46 pm »
Hello Everyone,
I've getting requests to add ODB++ export to Horizon EDA (see https://www.eevblog.com/forum/eda/horizon-eda-version-1-0/new/!) mainly for export to SI/PI analysis software that can only read ODB++. Fortunately, the ODB++ specification is publicly available these days: https://www.odb-sa.com/wp-content/uploads/ODB_Format_Description_v7.pdf Not as straight forward as gerber, but appears to be doable. The Valor ODB++ viewer is also available free of charge. The only thing missing are some ODB++ sample files since learning by example works quite well. Unfortunately I haven't been able to find any ODB++ board files for download on the internet (e.g. eval boards).
Since quite a few altium users seem to hang out here, could someone export a small project to ODB++ and post the archive? Doesn't need to be complex, but should contain all the usual stuff like packages, tracks, filled areas, etc.
Thanks
Lukas
Offline tycz
Re: ODB++ sample files
« Reply #1 on: March 31, 2020, 02:31:52 am »
You could download either Diptrace or Pulsonix trial versions. They can both output ODB++ format and come with example projects.
Offline Gribo
« Reply #2 on: April 02, 2020, 07:52:37 pm »
You should download version 8 of the specifications from Mentor Graphics.
I am available for freelance work.
« Reply #3 on: April 02, 2020, 09:40:15 pm »
I found out about the version 8 spec as well shortly after posting.
Thanks for the suggestion, the pulsonix trial works as intended.
« Reply #4 on: February 15, 2022, 08:46:15 am »
I checked the ODB++ homepage the other day and looks like they just recently added an ODB++ 8.1 sample file: https://odbplusplus.com/design/our-resources/
