Author Topic: What did you buy today? Post your latest purchase!  (Read 2806766 times)
« Reply #12875 on: February 16, 2024, 01:38:11 am »
seems to have done the trick, I took it off the bench supply at 18.3V (still drawing 2Amps) and put it on the charger - success, charging ok - showing 2 LEDs on battery.
I'm now more surprised that Makita brick their batteries?
... and less annoyed with Milwaukee, Screwfix and Badadaptor :palm:
Every pack has a unique ID and when some chargers fail to start charging after 3 insertions of a pack they lock it out.
The trick is to know about boosting the one cell that gets drawn down by the battery circuitry to a level the charger can like and accept it to charge.
Many tradies moved from Makita lithium tools because of this.
Offline armandine2
« Reply #12876 on: February 16, 2024, 07:33:18 am »
Does that mean that another Makita charger [not ones that have had those 3 insertions] would charge my unique id battery if its cells were brought back into the correct voltage levels?
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
The following users thanked this post: Ed.Kloonk
« Reply #12877 on: February 16, 2024, 08:30:40 am »
I believe so however not 100% sure on that as the charger might flag the cell.
My son invested in Milwaukee tools to leave these issues behind and now his Makita gear is relegated to home usage.  :horse:
Ask Mr Google.
Online thm_w
  • Non-expert
« Reply #12878 on: February 16, 2024, 10:17:00 pm »
Not for the one I tried, it was locked out from any charger.
Offline Alex Eisenhut
  • Place text here.
« Reply #12879 on: February 17, 2024, 03:46:07 am »
Found this tonight while thrifting, always wanted one, but not for the 300$ US with shipping from eBay. I love this styling, a mish mash of '60s-'70s color schemes and '70s-'80s rectangles , and the all important dbx logo.
All works correctly, the tape type sensor works, the thingy lights up behind the cassette, very stylish, just needs a dusting and pots need cleaning, that's it.
Offline RAPo
« Reply #12880 on: February 17, 2024, 12:04:36 pm »
A Siemens D1010 20MHz Oscillarzet with adequately shielded X-ray radiation.
Offline cosmicray
« Reply #12881 on: February 17, 2024, 12:31:55 pm »
Look at those clamps!
For all you kelvin clip fanboys...
I'm mentally trying to think ... can I extend that concept for 1206, 0805, or even (shudder) 0603 ?
it's only funny until someone gets hurt, then it's hilarious - R. Rabbit
Offline pqass
« Reply #12882 on: February 17, 2024, 01:44:24 pm »
Maybe something with pogo pins?  See attached.
It's from IMSAI Guy video #1700.
Offline pqass
« Reply #12883 on: February 17, 2024, 06:14:14 pm »
More 4-wire foolishness...  This time with SMD!
1210 on the clip with 0805 and 0603 below for reference (lower left photo).
I'll need to break-out the sewing needles for the latter two.   ;D
« Last Edit: February 17, 2024, 06:57:03 pm by pqass »
The following users thanked this post: Victorman222
Offline Jackster
    • PCBA.UK
« Reply #12884 on: February 18, 2024, 12:50:17 am »
I'm here for a fun time, not a long time  :-DD.
  • Place text here.
« Reply #12885 on: February 18, 2024, 01:12:51 am »
That looks awesome!
Online SiliconWizard
« Reply #12886 on: February 18, 2024, 02:28:15 am »
Nice.
Offline gamalot
  • Correct my English
    • Youtube
« Reply #12887 on: February 20, 2024, 08:56:33 am »
A used Fluke 52-II thermometer.
Offline Black Phoenix
  • Country: hk
« Reply #12888 on: February 20, 2024, 01:03:59 pm »
Nice.
Offline armandine2
« Reply #12889 on: February 21, 2024, 08:19:24 pm »
Just bought a lot of transistors, in a 750 piece Bojack  8) kit from Amazon - very promptly delivered - and I have confirmed in my feedback that the kit was as described.
Of course, I don't believe that statement totally - but obviously in an enough of a way to tick that box  :palm:
Offline gamalot
    • Youtube
« Reply #12890 on: February 22, 2024, 05:39:15 pm »
I was going to do a teardown of it, but after searching I found that a well-known forum member Ilya (TiN) had done a perfect one ten years ago.
https://www.eevblog.com/forum/testgear/fluke-5x-ii-series-thermometer-tear-down-and-hacks/
Offline TopQuark
  • Country: hk
« Reply #12891 on: February 24, 2024, 11:23:03 am »
Got a working set of Tek 1103 power supply and P6245 active probe. Finally have an active probe setup for the lab.  ;D
Offline RAPo
« Reply #12892 on: February 26, 2024, 04:31:02 pm »
A voltcraft digi scop converter 500.
Offline RAPo
« Reply #12893 on: February 28, 2024, 03:31:35 pm »
That old device works also on a digital one:
Offline AndrewNorman
« Reply #12894 on: February 28, 2024, 11:37:38 pm »
Picked up a pneumatic solder dispenser.
2041997-0
Was meant to have a 24V external adaptor, but the unit I got was unit that took 240V with an internal transformer.
Built quality was pretty good overall, pneumatics inside were solid and fixed well. 99.9% of the internal wiring was decent with wire that was rated well above the operating current.
The only problem was the internal earth wire was a 1mm (maybe a little smaller) wire that was soldered to the fused input socket and then the other end floating around the transformer housing. Replaced that with a decent wire and verified all the metal work was earthed.
Unit works well with no air leaks.
« Reply #12895 on: February 29, 2024, 05:32:47 am »
A Rohde & Schwarz NGL 35:
A Metcal MX-500P with a soldering iron, a desoldering tweezer and two stands:
A HP 4329A TOhm meter:
The following users thanked this post: pdenisowski
Offline wkb
« Reply #12896 on: February 29, 2024, 07:14:46 am »
You will love the Metcal!  :-+
The following users thanked this post: Smokey, BU508A
Offline zapta
« Reply #12897 on: February 29, 2024, 08:07:11 am »
The schematics of the Metcal MX-500 is a piece of art.
  • Country: hk
« Reply #12898 on: March 01, 2024, 02:33:58 am »
An Arduino UNO R4 WiFi just dropped in my pouch:
« Last Edit: March 01, 2024, 02:42:14 am by Black Phoenix »
Offline zapta
« Reply #12899 on: March 01, 2024, 03:20:42 am »
An Upduino 3.1 FPGA board and I2S amplifier and I2S microphone. I plan to play with microphone arrays and this seems to be a good fit. Also look for free verilog tool chains and landed hapyly on Apaio, easy installation and easy operation.
