Author Topic: Triton Artificial Gills  (Read 90495 times)
Offline amspire
Re: Triton Artificial Gills
« Reply #150 on: April 10, 2016, 11:07:57 pm »
Nope. LOX. They're nuts.
Saeed knows that currently LOX cannot be taken aboard a plane, but
we will be able to ship it because we will follow the DOT regulations and we are working to develop a insulated container that will be make it possible to bring on a flight, we will also release more information as we go with all regulations and how far we come to solve it, have a great day
He admits the LOX will not last long, so he is talking about a miniature dewar with continuous venting of excess gaseous O2
All he has to do is to change the international airline safety regulations to allow items to be shipped that are venting uncontrolled amounts of pure oxygen into a cargo hold. And he will have no problem getting the international laws changed by December!
Probably for his next campaign, he will work on getting the laws of gravity changed.
And he says that if you are unable to get LOX at your destination, he will refund all your money and you can keep the Triton for free!  :-DD
When asked about the breathing mixture, he seemed to confirm it was pure oxygen.
« Last Edit: April 10, 2016, 11:23:58 pm by amspire »
Offline amspire
« Reply #151 on: April 10, 2016, 11:59:23 pm »
Looked up some data from Dewar manufactures and typical liquid oxygen evaporation rates were 0.2 to 0.8 litres a day. The evaporation and release of the oxygen is essential to keep the remaining LOX cold enough to be liquid.
A miniature dewar would have a very small insulating air/vacuum gap between the walls, so how long could it hold any LOX? Could it manage an hour? It would solve all the shipping problems - by the time the miniature LOX dewar reaches an airport for shipping, it is almost certainly empty.
That miniature dewar has to contain the double stainless steel walls, and a phase separator to separate the gaseous oxygen from the LOX. To let the LOX get as high as -118 degC to minimize the evaporation rate, it has to allow for pressures of 50 atmospheres, so that would mean the inner wall would be a pressure vessel with strong walls. How much room is left for the LOX?
« Last Edit: April 11, 2016, 12:01:33 am by amspire »
Online edavid
« Reply #152 on: April 11, 2016, 01:10:32 am »
It this were real, you would ship the dewars empty, and get a medical oxygen supplier to fill them at the destination.
Offline ChunkyPastaSauce
« Reply #153 on: April 11, 2016, 01:32:28 am »
This is the only cost effective way to get the lo2 I think... but kinda doubt a med supply house will fill a non-medical canister for some random person walking in. I tried several med supply places for syringe bodies, without the needles, and couldn't get them.... and those have zippo regulations.
« Reply #154 on: April 11, 2016, 01:47:03 am »
Also Ill mention, I did a quick hand calculation. I have to double check. But I think there maybe problem with evaporating the lo2 at a sufficient rate since you need thermal transfer to do it. I think it may freeze up the device or water in contact, unless you provide some method for forced convection... especially since most of the cylinder will be supposedly insulated.
Offline TassiloH
« Reply #155 on: April 11, 2016, 02:24:09 am »
What is the problem with LO2 supply? To make 1kg of LO2 from room temp gas (a temp difference of 25 --183 = 207K) one needs 0.91 kJ/(kg*K) * 1kg * 207K = 188 kJ for the specific heat plus 214 kJ for the latent heat, so roughly 400kJ = 400000 Ws.
For a steal of about 16000 US$ one can buy a cryocooler that supplies about 100W cooling power at this temperature (and consumes about 3kW of electricity to do it). So it takes only 400000 Ws/100W = 4000 s. Assuming that half the power is lost due to imperfect insulation, one can make 1kg of LO2 in 3h. Problem solved  :-DD
Offline alsetalokin4017
« Reply #156 on: April 11, 2016, 03:59:25 am »
Either this Saeed guy has absolutely no experience with cryogenic liquified gases, or he is depending on his marks having none.
The following users thanked this post: Kilrah
Offline EEVblog
« Reply #157 on: April 11, 2016, 04:09:30 am »
Thunderf00t is working on an updated video to demolish the new liquid oxygen thing  :-+
The following users thanked this post: ChunkyPastaSauce
Offline amspire
« Reply #158 on: April 11, 2016, 04:43:07 am »
I was going to leave this, but I just noticed a brand new campaign:
This is fantastic news for the people of Sydney. We can not get our Tritons locally now!
The following users thanked this post: TheAmmoniacal
« Reply #159 on: April 11, 2016, 05:00:00 am »
So does IGG not check anything at all or something?
Offline amspire
« Reply #160 on: April 11, 2016, 05:11:05 am »
It is against their rules, but so is starting a campaign that is technically impossible.
Offline Kalidor
« Reply #161 on: April 11, 2016, 07:20:38 am »
It's not the same guy, someone that calls himself Bassam Meraby copy pasted the campaign bit by bit. fraud^2
https://igg.me/at/nE9NBTSWkGI/x/10280792
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual.
Offline Khendrask
« Reply #162 on: April 11, 2016, 12:45:56 pm »
There was a third campaign too, ( https://www.indiegogo.com/projects/triton--5#/ ) that IGG actually did shut down... Or at least it is "Under Review by the Safety and Trust Team"... /laugh.
For anyone really interested in this mess, on of the reddit folk wrote a bot to tweet every time a negative Triton post was deleted from the campaign board.
You can find it here: https://www.reddit.com/r/shittykickstarters/comments/4e0zra/i_just_made_a_bot_that_tweets_the_comments/
Offline EEVblog
« Reply #163 on: April 11, 2016, 01:44:57 pm »
I had my uCurrent Kickstarter campaign copied on IGG, it happens all the time.
Offline Kilrah
« Reply #164 on: April 11, 2016, 02:22:48 pm »
And it even has backers too  :palm:
While we're on the humor topic, why not a guaranteed loss instead of a guaranteed loss but with no hope-you-need-to-force-yourself-to-get?  :-DD
https://igg.me/at/DONOTUSE
May or may not take inspiration from the topic at hand...
« Last Edit: April 11, 2016, 02:24:30 pm by Kilrah »
Offline Nerull
« Reply #165 on: April 12, 2016, 01:59:06 am »
While we're on the subject of shipping LOX to consumers without cryogenic liquid training:
http://www.elcosh.org/document/1676/d000585/Liquid%2BOxygen%2BCylinder%2BExplosion.html?show_text=1
Offline hayatepilot
« Reply #166 on: April 12, 2016, 06:34:07 am »
Somebody made a debunk/scam alert campaign:
https://www.indiegogo.com/projects/triton-world-s-last-artificial-gills-scam#/
I hope that saves some people from throwing their money out of the window.
« Last Edit: April 12, 2016, 06:38:40 am by hayatepilot »
Offline Khendrask
« Reply #167 on: April 12, 2016, 10:56:59 am »
It probably won't, but I applaud the effort (and tossed in a Euro as well).
Offline Kilrah
« Reply #168 on: April 12, 2016, 12:56:50 pm »
2nd from me. Can't wait to get my nothing!
Offline Kalidor
« Reply #169 on: April 12, 2016, 02:47:20 pm »
and here are the tweets
https://twitter.com/TritonDeleted
Offline Kilrah
« Reply #170 on: April 12, 2016, 06:05:02 pm »
That bot is genius!
Offline Khendrask
« Reply #171 on: April 13, 2016, 10:04:28 am »
Wait, did you ask for two nothings?
I feel cheated already!
Offline Kilrah
« Reply #172 on: April 13, 2016, 03:56:43 pm »
Yep and he's offering me the 2nd one! But then he bought one from me again, so don't be jealous  ;)
Offline Kilrah
« Reply #173 on: April 14, 2016, 04:19:51 pm »
Aww damn, just got a refund, his campaign has been closed by IGG it seems...
Ironic how they'll close "safe" campaigns for being copies, but leave obvious scams untouched  :-//
« Last Edit: April 14, 2016, 04:21:26 pm by Kilrah »
Offline Khendrask
« Reply #174 on: April 14, 2016, 04:50:06 pm »
Not to worry, it is back:
https://www.indiegogo.com/projects/triton-world-s-last-artificial-gills-scam/x/13639189#/
Just without the "Patented" graphic.
And txt29 says he had over 2200 views before it was pulled, then restored.
The following users thanked this post: Kean, Kilrah
