Really, this feels like discussing with a flatearther.
Please don't say that. Don't think for a moment that the feeling isn't mutual.
With both sides feeling like they are debating flat earthers.
And the rest not having a clue what is really being discussed.
In short it is like this.
Lewin: KVL doesn't hold for circuits immersed in a non-conservative electric field, here is the theory to support this claim and here is the demonstration.
McDonald: Your calculations and your experiment are spot-on, Lewin, but don't say KVL doesn't hold because, although it really doesn't describe your circuit very well, I can still use KVL equations to arrive at the same results. Here is the calculations. It is a math trick used to solve various problems in electromagnetism.
Lewin: Yeah. I know many authors use that trick and even call the attention to the fact that you will not find the EMF as a voltage in the circuit, but people don't pay attention to that and try to invent all kinds of unscientific explanations to prove that there is a voltage there hidden, or somehow masked, in the circuit.
McDonald: I agree, this can be misleading sometimes.
Mehdi (intruding on adults' conversation): Hey Lewin, I think you're wrong and I have McDonald's paper to prove it. Your experiment is flawed.
Lewin: Talk to Belcher. I'm retired.
Mehdi: Belcher, please, say I'm right, say I'm right, please, please, please. I'm in desperate need of viewership and I need to convey the idea that I'm an expert electromagnetism.
Belcher: Alright, Mehdi. You're right, BUT, and that's a big BUT, only when it comes to circuits with lumped components and no varying magnetic fields inside the path of the circuit.
Mehdi Woohoo! You see audience? I'm right. Who said that? An MIT professor and the paper by McDonald. Lewin is wrong. Now subscribe, hit the like bottom, pour your sweat money into my Patreon account and buy the sponsor's shit.
People do exactly that and prove how humans failed as a species.
Or maybe it's like this:
Lewin: Hello, hello, hello! Today I am going to show you something amazing! Something so amazing that you will be telling your grandchildren about it!
Lewin: In fact, it is so amazing that this is probably the only time in your entire life that you will see it!
He then presents an air core transformer, which he has incorrectly drawn on the chalkboard, and declares:
Lewin: KVL IS FOR THE BIRDS! All the textbooks are wrong! Only I am the source of truth on this matter, and even my fellow professors think I CHEATED! That shows you what THEY do!! They must be all cheaters! Yes, the whole world is insane but me!
Mehdi shocks himself a few times to see if this newfound knowledge will sink in and make sense. But it doesn't, so like any seeker of truth worth his sparks, he shocks himself a few more times and maybe melts down some clip leads, and then gets busy doing experiments, and finds that Lewin was incorrectly probing.
Mehdi: Professor Lewin, good sir, I tried my best to understand this, but I think you're not probing correctly. What am I missing?
Lewin: FLAT EARTHER! FLAT EARTHER! I do not argue with flat earthers! I won't even watch your video, but you're just wrong! KVL IS FOR THE BIRDS!
Mehdi: Professor McDonald, Professor Belcher, I'm really trying my best to understand this, and my fingers hurt and it smells like burnt clip leads in here. It looks to me like when correctly probing, KVL holds fine. It looks like Professor Lewin did not account for the dB/dt in the loop formed by his volt meter leads, which he did not depict as being magnetically coupled to his loop under test. But he won't even watch my video. What am I missing here?
McDonald: Yeah, he probably can't stand to see you shocking yourself and burning up perfectly good clip leads.
McDonald: Also, Dr. Lewin is as much of a showman as you. He uses diversion and an obsolete version of a "law" to create an apparent paradox.
McDonald: But you are right, Lewin’s circuit is within the range of applicability of Kirchhoff’s loop equations, which
can be used to predict measurements by the “voltmeters” in the experiment.
Belcher: Lewin has fallen for a very common misconception where he thinks that the -L(dI/dt) voltage read by volt meters represents -∫E.dl
through the inductor, but that's false. Feynman is very clear that while -∫E.dl
through a superconductor is zero, the voltage difference
across the inductor is defined as ∮E.dl (which he says is EMF) -- and this is Faradays law -L(dI/dt).
Belcher: According to Feynman's definition, the sum of all the voltage differences around the circuit is zero (that is, KVL holds) +V - IR - Q/C - L(dI/dt)=0, but the first three terms here are the -∫E.dl
through various circuit elements, and the last term has NOTHING to do with the -L(dI/dt) through the inductor, which is the part that Lewin is all hung up on about being zero. The -∫E.dl term is zero, but it's not the only term: The remaining term, -L(dI/dt), is not zero, and he's ignoring that.
Belcher: In that sense, you correctly argue that KVL holds. Just keep in mind that because the inductor is so different from the other elements, it is defined differently. But it's still a unit of volts, it's still a real measurable -- and lumpable voltage for the sake of KVL.
Mehdi shocks himself and burns up some more wires.
Also, Hey, did you see my request to you here? https://www.eevblog.com/forum/amphour/562-electroboom!/msg3820280/#msg3820280Edit: Fixed the link.
