Author Topic: FLIR E4 Wifi Resolution and Menu Hack Thread  (Read 444112 times)
Offline Theremin
Re: FLIR E4 Wifi Resolution and Menu Hack Thread
« Reply #1300 on: December 14, 2023, 05:05:13 pm »
It was a new camera, did you charge the battery before using?
Things you can try:
Unplug the battery for 1 min, plug it again. Connect the wall charger to the camera. Push Left and Right keys together. Do you see the screen showing battery charging? What is charge level? Let the battery charge. If charge level is low, leave the camera charging for a few hours. You can monitor charge level on the screen.
I charged it for a few hours before turning it on the first time and saw the battery icon then. Nothing showing now after doing what you said and pressing the buttons. Maybe the battery just died. Although I remember reading somewhere that it should get enough power from USB to start the recovery, but I'm not sure, could have been for some other model.
The calibration date on the included information card says June 2019, so it likely has been sitting in some warehouse for fours years in who knows what environmental conditions. Perhaps time to RMA it.
Offline DaveWBTopic starter
« Reply #1301 on: December 14, 2023, 05:15:17 pm »
I bet the internal battery is dead
Offline Bud
« Reply #1302 on: December 14, 2023, 07:01:26 pm »
If the camera even not charging and not enumerating in USB while powered off that is certainly a hardware failure....
And you also tried to connect it to USB with the battery removed, correct?
Offline Theremin
« Reply #1303 on: December 18, 2023, 08:57:04 am »
I tried with the battery removed, no change. I'll send it for repair.
Offline Theremin
« Reply #1304 on: December 21, 2023, 09:50:03 am »
Turns out the camera was shipped from Flir too long ago and doesn't even have warranty anymore, so I'll get a full refund. The dealer offered to sell E5-XT for the same price. I read from the previous page that someone had successfully liberated that model as well, but would you say it's still wiser to get the E4 model just to be on the safe side? No idea with what firmware version either one comes with at this point. And liberating the E5-XT could mean losing the extended temperature range anyway from what I read.
« Reply #1305 on: December 21, 2023, 11:17:11 am »
Taking the E5 would be totally fine and same process
The following users thanked this post: Theremin, Leak Detector
Offline smaultre
« Reply #1306 on: January 21, 2024, 12:40:43 am »
Hello. I need a full dump of Flash  IC TC58BVG1S3HTA00
Please!!!
Mine goes bad, and device won't boot.
Start a new life here!!!
Offline Mikiej007
« Reply #1307 on: February 11, 2024, 04:10:36 pm »
I'm looking to liberate my (non-WiFi) E4 after it was gifted to me as part of a redundancy and company shut down.
I believe that it has never been upgraded and is still on very old firmware.
Model  E4 1.0
Part Number  63901-0101
Software  1.19.8
Looking though the thread, it is recommended to leave 1.19 as is, but I would really like to unlock the higher resolution and any menu/functionality improvements.
What would be the best way to go forward. Can I just use Buds procedure, or should I do an intermediate update first?
Thanks, in advance.
Offline Bud
« Reply #1308 on: February 11, 2024, 04:33:27 pm »
For Bud's procedure you should check the WiFi thread for compatible firmware version numbers.
Offline Mikiej007
« Reply #1309 on: February 11, 2024, 06:42:42 pm »
Yeah I did a search but 1.19 doesn't really get mentioned much, hence my question about the possible need to update to a different standard firmware and then do the hack?
« Reply #1310 on: February 11, 2024, 06:45:44 pm »
Just upgrade to 3.16.0 and go from there, all the hardware versions can be upgraded.
Offline SWAGGYD
« Reply #1311 on: March 12, 2024, 03:19:11 pm »
Hi
I juts upgrade my E4 3.16, every think is ok but I don't know how to turn off RNDS. Can someone help me?
