Author Topic: What did you buy today? Post your latest purchase!  (Read 2837424 times)
0 Members and 23 Guests are viewing this topic.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #7000 on: August 21, 2018, 04:32:06 pm »
Found another toy in Akihabara.
Will be handy for testing audio amps after a little TLC. Works well after I replaced the fuse. :D
Looks like it has an ovenised crystal (is that what it's called?) or something, there's a little styrofoam block on something in what looked to be an oscillator section when I took a quick peek inside.
Offline bitseeker
« Reply #7001 on: August 22, 2018, 02:38:18 am »
You are so going to make me go over there! I haven't been to Akihabara for many years. Now, I have lots of incentive. ;D
Offline McBryce
« Reply #7002 on: August 22, 2018, 07:55:29 am »
Then you'll probably be very disappointed. Akihabara today is a far cry from the Akihabara of the past. Much of what made Akihabara great is now gone.
McBryce.
  • Country: jp
« Reply #7003 on: August 22, 2018, 09:54:17 am »
There is still a lot if you know where to look. :)
You want to head a street or two back from the main road, heading away from the electric town exit from Akihabara station..
I recently found two nixie tube based frequency counters. I'll post pics once they are all reassembled from their restorations.
[edit] Another recent acquisition, yet again from Akihabara. I think I might eventually make a clock, or even grab some tubes and see if I can display video, old school style.
« Last Edit: August 22, 2018, 09:59:08 am by TERRA Operative »
Offline McBryce
« Reply #7004 on: August 22, 2018, 10:32:34 am »
Last time I was there I browsed Keisokuki-Land which is quite close to the station, across the main street and heading for the river. Good shop to browse, but no drop-dead bargains. I'm also limited to what I can fit in my case on the way home. There are a few smaller "junk component" shops around that area too, but the sprawling "component fruit markets" of the past all seem to have disappeared.
McBryce.
Offline julianhigginson
« Reply #7005 on: August 22, 2018, 11:51:16 am »
well, damn.... look what showed up today!
it's not often that a package for what I bought is bigger than me.
I'm going to need a bigger office.
  • Country: jp
« Reply #7006 on: August 22, 2018, 02:49:32 pm »
Looks like christmas came early. :)
Offline @rt
« Reply #7007 on: August 22, 2018, 02:59:03 pm »
The story behind this is that it belonged to a friend of a friend, and I always wanted one from the moment I saw it,
and today I got the exact same unit from him.
The best part is it’s practically worthless! :D
Offline bitseeker
« Reply #7008 on: August 22, 2018, 08:15:13 pm »
Depending on how much storage you have available, you might be able to get Open Street Maps onto it.
https://help.openstreetmap.org/questions/22672/reviving-ancient-garmin-streetpilot-iii-with-osm-possible
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #7009 on: August 23, 2018, 12:52:37 am »
I really can't resist such beautiful New Old Stock... Especially on the cheap. Simpson 294.
(Photos are credit of the original seller)
« Last Edit: August 23, 2018, 02:36:32 am by rsjsouza »
The following users thanked this post: Bud
Offline nanofrog
« Reply #7010 on: August 23, 2018, 01:40:58 am »
Nice ^.  :-+
Offline @rt
« Reply #7011 on: August 23, 2018, 02:40:36 am »
It has detail maps from 2007, so my street doesn’t exist :D
But I have used Garmin’s MapSource program with their hiking GPS units, and should be able to get it together.
The open maps usually don’t have routing info, so the unit wouldn’t speak.
I was able, at the time, to load open source maps into MapSource so that both could be loaded o the unit, which I’d love to try with a topographic map.
It’s a serial port, and a data card (prior to SD cards), so I’ll have to rig a makeshift serial cable.
Offline edpalmer42
« Reply #7012 on: August 23, 2018, 04:12:51 pm »
I bought a dead LeCroy 9384L digital scope.  4 channels, 1 GHz, up to 4 GS/s.  Totally dead.  Am I crazy?  Do I enjoy throwing away money?  Do I have nothing better to do with my time than waste it on trying to fix something that's way above my pay grade?
Wait.................... what? .................... seriously? ..................... damn! .........Ha!  Knew it all along!  8)
The problem turned out to be a trivial issue with a power supply connector that had overheated and wasn't making good contact.
Ed
« Reply #7013 on: August 23, 2018, 04:37:08 pm »
Ed
Nice catch, its always lovely when it turns out to be something simple like that.
Offline AF6LJ
« Reply #7014 on: August 23, 2018, 09:46:15 pm »
Good Deal!!
Sue AF6LJ
Offline Kjelt
« Reply #7015 on: August 23, 2018, 11:17:57 pm »
That's very  8)
Might be interested myself.
Did you buy it new or 2nd hand , ballpark figure if you want to share that is, or did you discuss this some other topic before?
The following users thanked this post: julianhigginson
Offline bitseeker
« Reply #7016 on: August 24, 2018, 01:23:57 am »
Wow, nice score! Congrats on the easy fix.
Offline basinstreetdesign
« Reply #7017 on: August 24, 2018, 01:31:38 am »
Ed
 :-+ :clap:
STAND BACK!  I'm going to try SCIENCE!
Offline edpalmer42
« Reply #7018 on: August 24, 2018, 04:25:32 am »
Yeah, at first I didn't believe my luck.  Now I have to figure out how to use the beast.  I've already got a new fan on order to replace the existing howler.  Same size, same CFM, half the RPM, 10 dB lower noise, half the power.  I'll believe it when I see it!
Ed
Offline DC1MC
« Reply #7019 on: August 24, 2018, 05:29:01 am »
I've got from  >:Dbay an Agilent 6000 series oscilloscope calibration kit for ca. 9EUR but I wasn't sure that it works, so I've also got an Agilent MSO 6054A to test it  :P.
The poor scope was never calibrated or updated, the last (and probably the first) calibration was performed in July 2005  :palm:, now after the kit did its magic (observe the pictures), the scope is freshly calibrated   ^-^.
A bit pricey the calibration kit testing device, but now I can recommend it, it works  8) !!!
 Cheers,
 DC1MC
Offline capt bullshot
« Reply #7020 on: August 24, 2018, 05:36:19 am »
Did you also get a new flat, to store all the stuff ;)
Offline DC1MC
« Reply #7021 on: August 24, 2018, 05:56:14 am »
Next on the list  :-DD
« Reply #7022 on: August 24, 2018, 09:56:13 am »
That's very  8)
it was 2nd hand.
the factory test/packing sheet that it came with says 1998! so, it's 20 years old.
It came from a company that had been using it to do their own electronics manufacturing, but offshored recently.
one of the two parts platters it came with still had components in it from the work they last used it for!
There are still companies selling new versions of it (or at least still list them in their catalogue)
https://www.fritsch-smt.de/en/manual-pick-place/
http://dimasmt.com/complete-system/
the fritsch one looks ridiculously similar to my 20 year old unit.
The following users thanked this post: Kjelt
Offline TheDeuceII
  • Compliance Software Architect and Data Shepherd
« Reply #7023 on: August 25, 2018, 12:49:52 pm »
Greetings, I’m relatively new here, but Ive been an avid follower/lurker of the Channel and the forum... Guess this thread gets to pop my post-cherry
I just happened upon this thread, the morning after I made my FIRST scope purchase. Never had a fair/decent/reasonably-fully-functional one before. I currently have use a Sainsmart DDS120 and it’s pretty awful. Recently started a project and found out I need gooder one. Scoped (no pun intended) out the GW Instek 1000-series, the Tek 1000 series, and the highly regarded Rigol 1000-series. And alas, I decided on the Rigol DS1054Z— too bad it won’t ship until Monday. For now let’s settle for the invoice, shall we  8)
Also decided to finally upgrade the insulated-with-cheap-ass-pvc test leads that Came with my Fluke 179 DMM. Hooray for silicone, hooray for buying genuine!
« Last Edit: August 25, 2018, 01:36:33 pm by TheDeuceII »
Offline kripton2035
« Reply #7024 on: August 25, 2018, 02:20:28 pm »
