Author Topic: Siglent SDS2000X-E  (Read 21255 times)
Offline oeweanTopic starter
  • Country: no
    • Adroit.no
Siglent SDS2000X-E
« on: December 05, 2018, 01:58:18 pm »
Siglent will release the SDS2000X-E on 10th December.
Will come in two flavors, 200MHz and 350MHz...
Norwegian distributor of test and measurement equipment....
Adroit.no
Offline tautech
Re: Siglent SDS2000X-E
« Reply #1 on: December 06, 2018, 02:52:08 am »
Added from later info:
All info is now available:
https://int.siglent.com/products-overview/sds2000x-e/
https://siglentna.com/digital-oscilloscopes/sds2000x-e/
https://www.siglenteu.com/digital-oscilloscopes/sds2000x-e/
And many of the same features offered in SDS1004X-E.....
Bode plot
MSO option
AWG option
WiFi option
Waveform search
Navigate/History/Sequence
1Mpt FFT
Web browser etc etc
But plus:
2 GSa/s sampling
28 Mpts memory
50 ohm inputs
« Last Edit: September 16, 2019, 09:02:42 am by tautech »
Online tv84
  • Country: pt
« Reply #2 on: December 06, 2018, 10:50:40 am »
What are the main differences for the 1000X-E?
Offline rf-loop
« Reply #3 on: December 06, 2018, 01:16:03 pm »
You need split thinking to two separate pathway.
SDS1002X-E
SDS1004X-E
Even when SDS2xx2X-E is 2 channel it is not evolution of SDS1002X-E
It is better imagine it is more like half channel SDS1004X-E mutation- evolution (lot of similarities except BW samplerate and due to double samplerate memory is doubled so it is proportionally same.)
It is - imho - not any kind of big jump to up or side. Only more choices for customers  in the current product range at approximately the same level.
SDS5000X ... it is totally different case. It's proportionally big step out of the current product portfolio.
« Last Edit: December 06, 2018, 01:18:42 pm by rf-loop »
Offline BillB
« Reply #4 on: December 06, 2018, 01:50:27 pm »
I wonder why this is only offered as a two channel, and not four channel?  How much more popular are the two channel units vs. the four channel ones overall?
Online tv84
  • Country: pt
« Reply #5 on: December 06, 2018, 02:42:17 pm »
SDS1002X-E
SDS1004X-E
So, it's a 1004 with 2 channels, more BW and memory. Other features are the same, so it takes advantage of their maturity (or lack of). I bet it has network security issues, bla, bla, bla...   :D
I don't find it bad. It widens the entry portfolio.
I'm waiting for the SDS5000 but now there are also the Rigols...   :-\
Offline tautech
« Reply #6 on: December 06, 2018, 06:29:47 pm »
This ^ and at a good price too, a 2ch 200 MHz 2 GSa/s DSO.......under $650 !  :o
Online tv84
  • Country: pt
« Reply #7 on: December 06, 2018, 07:19:58 pm »
Or 350 MHz...  ::)
Online Performa01
  • Country: at
« Reply #8 on: December 06, 2018, 10:41:34 pm »
Apart from everything else, I can assure you that a 100MHz square wave looks very different on a true high bandwidth scope from what has been shown in the MSO5000 hacking thread. ;)
The following users thanked this post: JPortici, 2N3055
Offline rhb
« Reply #9 on: December 07, 2018, 02:53:28 am »
With a 100 MHz square wave there isn't much time for the ringing  from a fast edge to die down.
IMHO Leo Bodnar's  10 MHz, <40 pS rise time square wave pulser is more appropriate for torturing scopes into confessing.  I've subjected an MSOX3104T and an RTM3104 to it.  The "1 GHz" Keysight had a 436 pS rise time with 7% overshoot.  I sent it back.  An RTM3104 demo unit had a 350 pS rise time and 3% overshoot.  Until I installed the 1.300 FW update.  At which point it had 10% overshoot.  Reverting to 1.100 did not restore the 3% overshoot.  I shall let the reader draw their own conclusions.  I was quite shocked as my experience calibrating a Tek 465 led me to expect no more than 3% overshoot. So I went from delighted to horrified in a week.
I'm very skeptical of the Rigol DS1000E/Z  hacks as I've never seen any step responses.  Logically with a DSO, you build it, then you measure the AFE performance and apply a correction for component tolerances.  After that, if you want software BW updates you apply a 2nd digital filter.  The 1st filter is calibration  for that instrument.  The 2nd filter is a license option.
I recently bought a refurbished 485 on eBay.  I've not yet done the full cal procedure which is *very* long, but I plan to adjust it to under 1% overshoot, rise time be damned.  I don't care if it's only  300 MHz  at -3dB.  I want to be sure that any ringing is the DUT or user error.
My LeCroy DDA-125/LC684DLX has a <250 pS rise time and 20% overshoot. I plan to correct that with sensible anti-alias filters.  750 MHz for 4 channel mode and 1.5 GHz for 2 channel mode.
My Rigol DS1102E is 3% and my Instek MSO-2204EA is 5% both with rise time = 0.35/BW.  And an Instek GDS-2072E hacked to 200 MHz exactly matches the 2204EA both at full BW and at 100 MHz.
There's a long thread about Leo's pulser  here:
https://www.eevblog.com/forum/projects/yet-another-fast-edge-pulse-generator
with lots of screen shots on a wide variety of instruments.  And each unit comes with a printout of the step response on a very high BW scope.  It beats the pants off the Tek 106s  I bought to calibrate my 465 and Dumont 1060.
The following users thanked this post: tv84, JPortici
Offline MrW0lf
  • Country: ee
    • lab!fyi
« Reply #10 on: December 07, 2018, 08:56:17 am »
Just a word of caution for generic reader - if plan to poke actual DUTs with x10 probes then it may make sense to get probe => BNC M & BNC F-F adapter and stick Leo's pulser on the end of probe [possibly with additional 50Ω load], not directly on scope BNC with ext or int 50Ω.
Online Performa01
  • Country: at
« Reply #11 on: December 07, 2018, 11:56:11 pm »
EDIT: Be aware that this is from a high bandwidth scope and of course not from an SDS2000X-E!
I thought I should back up my claims by showing an example:
Square 100MHz_Z2ns+FFT
This is a 100MHz square wave with <<100ps transition time.
Main timebase is 100ns/div in order to get a sufficiently detailed FFT from DC to 2GHz.
Zoom timebase is 2ns/div in order to get a detailed Y-t view.
Automatic measurements:
FOV = Overshoot after a falling edge.
ROV = Overshoot after a rising edge.
Rise & Fall times are not accurate because of limited scope rise time and also time measurement resolution limited to 20ps at that timebase.
« Last Edit: December 08, 2018, 01:33:36 am by Performa01 »
Online 2N3055
  • Country: hr
« Reply #12 on: December 08, 2018, 12:40:14 am »
Hello!
That is a nice square. What is the generator if I may ask?
And scope handles it quite well.. Frontend looks very decent here....
Take care!
Offline JPortici
« Reply #13 on: December 08, 2018, 10:03:01 am »
was that the 5000? nice interface.
Looks like someone actually learned from their masters  ;)
The layout, the font sizes, the proportions, the choice of colours
« Last Edit: December 08, 2018, 10:05:27 am by JPortici »
Online Performa01
  • Country: at
« Reply #14 on: December 08, 2018, 12:23:08 pm »
Since I don't want to further derail this thread, I've placed a similar post under the associated topic:
https://www.eevblog.com/forum/testgear/at-last-siglent_s-sds5054x-touchscreen/msg2023294/#msg2023294
  • Country: no
    • Adroit.no
« Reply #15 on: December 09, 2018, 11:48:39 pm »
Tried to upload datasheet for the SDS2000X-E series, but file exceeded file size limit..
If interested you can download it from:
https://www.adroit.no/siglent-sds2202x-e-200mhz-2-kanals-oscilloskop.html#productattach
Adroit.no
Offline tautech
« Reply #16 on: December 10, 2018, 12:04:43 pm »
http://www.siglent.com/ENs/pdxx.aspx?id=2644&T=2&tid=1
https://www.siglentamerica.com/digital-oscilloscopes/sds2000x-e/
SDS2202X-E 200 MHz 2ch USD 619
SDS2352X-E 350 MHz 2ch USD 839
Options
USB AWG
USB WIFI
16ch MSO
« Last Edit: December 10, 2018, 12:24:33 pm by tautech »
Offline tautech
« Reply #17 on: December 10, 2018, 12:16:43 pm »
no 4 channel model because?
;D Exactly what I've asked.
You might guess by the front panel layout, one is coming.....
About that, I have zip info.  :(
« Last Edit: December 10, 2018, 12:18:34 pm by tautech »
  • Country: no
    • Adroit.no
« Reply #18 on: December 10, 2018, 01:30:54 pm »
Been told there is not going to be a 4 channel.
But who knows, if there is a demand?
Adroit.no
Offline colorado.rob
« Reply #19 on: December 10, 2018, 08:59:16 pm »
Are the MSO/LA signals available via LXI/SCPI?  Is serial decode still restricted to just what is on screen?  The 2000X series scope is a bit hobbled by the fact that the logic analyzer (digital signals, serial decoders) is not exposed via SCPI.  And serial decode is limited to just what is on screen.
Offline tautech
« Reply #20 on: December 11, 2018, 02:18:37 am »
They are in the current 2kX programming guide:
https://www.siglentamerica.com/wp-content/uploads/dlm_uploads/2017/10/Programming-Guide-1.pdf
P58
Depends on how you use it.....use the Zoom mode where you can have seconds of data stream on the main window and just a tiny portion in the Zoom window where you can still scroll to any of the packets in the main window.
Only Decode as outlined above. Currently none of the Siglent DSO's apparently are able to access Decode via SCPI.
The same applies for Bode plot in the SDS1004X-E models as there is no SCPI command set to enable that.
It will require firmware changes to get  the SCPI command sets installed.
Offline blacksheeplogic
« Reply #21 on: December 11, 2018, 03:14:39 am »
Options
16ch MSO
Maybe I'm missing it and it's in plain sight, but what is the sample rate on the digital channels?
« Reply #22 on: December 11, 2018, 03:25:04 am »
P58
Thanks for sending that.  It has been a while since I looked for an update to the SCPI manual.  I also see that I have missed a couple firmware updates in the past year.
It says "D[X] — Digital channel. Only valid for SDS1000X-E series."  (Page 179, WAVEFORM command.)  Yes, one can control the MSO, but the digital waveforms cannot be retrieved from a 2000X for external analysis.  This means that only the 4 analog waveforms can be used in tools like sigrok -- and, as a 2000X owner, that makes me sad. :(
But that's certainly good news for the 1000X-E users.  And hopefully that means it works on the 2000X-E series as well.
Offline tautech
« Reply #23 on: December 11, 2018, 03:28:50 am »
Options
16ch MSO
It's in the datasheet: P3 and 14.
Maximum waveform capture rate up to 1GSa/s, Record length up to 14 Mpts/CH
https://www.siglentamerica.com/wp-content/uploads/2018/12/SDS2000X-E_DataSheet_DS0102E-E01A.pdf
The 16 digital channels are provided with an external module, the same as used for SDS1004X-E models, the SLA1016 that connects into the front Sbus connector.
https://www.siglentamerica.com/accessory/sla1016/
Offline tautech
« Reply #24 on: December 11, 2018, 03:39:41 am »
P58
Check:
Read Waveform Data of Digital Example
P251
Will that work for you ?
