Author Topic: What did you buy today? Post your latest purchase!  (Read 2807165 times)
Smokey and 7 Guests are viewing this topic.
Offline PA0PBZ
« Reply #8475 on: July 05, 2019, 06:41:59 pm »
Just do a DuckDuckGo image search on Plitvice to see what I mean.
Oh, that brings back memories! Been there a couple of times with my parents when I was a teenager, it always felt special swimming there with the water snakes! :)
Offline GreyWoolfe
  • NW0LF
« Reply #8476 on: July 06, 2019, 02:57:00 am »
...Sex on a stick!!! ...
Yes, yes it is...
I have 2 sets myself, 1 in the office and 1 in my work tool bag.
Offline tooki
« Reply #8477 on: July 06, 2019, 03:50:53 pm »
Cool design. But how much is the ink?
Totally reasonable. Around $120 for a pack for 200 A6 prints (both ribbon and paper), or $80 for 240 10x9cm prints.
Why do I get a mental image of the walls at your place being plastered over with A6-sized photo-quality prints?  ;D
(Oh, I know.  That's what I'd do.  Tiled images of real and unreal places and stuff, maybe like small windows or ports...  Just do a DuckDuckGo image search on Plitvice to see what I mean.  I wonder how large a rounded icosahedron you could make, with the surface of Mars printed on it, without wasting too much space on those A6 sheets?)
The irony is that I used to do a lot more photography as a hobby, and I have tons of photos that I’ve been intending for 15 years (and counting) to print and frame. I have a great printer, great photo paper... and not one single photo printed and framed. Not one single photo of any kind on a wall! :(
Offline Johnny10
« Reply #8478 on: July 06, 2019, 04:15:23 pm »
My new Raspberry Pi is finally here. It is fast and a little hot!  ;D
What screen is that? And is it a touch-screen?
Cool Purchase!
Offline pigrew
« Reply #8479 on: July 06, 2019, 05:21:33 pm »
I took a chance on an E9300A RF power sensor from eBay "for parts" at about $60. This is a 18GHz dual path diode-based sensor. So far, the connector gaged at 208.8 thou pin depth (seems good, looks like standard N is .208 deep while precision N is .207 deep.) and holds zero within spec, and properly cals. There is no public calibration guide that I can find, perhaps I will compare a siggen's output using another sensor against this one. Comparing to a 8656B siggen at 50 MHz and  950MHz, everything is within 0.2dB from -60 to 10 dBm, so yay, both diodes paths work.
I don't have a N-type cal kit, so I may measure gamma using a calibrated 3.5mm port with port extension as adapter removal. Gamma tables used to be printed on the sensors, but not with the E series. Is there a way to read the cal table from the EEPROM?
EDIT: Nevermind my question, seems like some code to read the EEPROM has been posted.
« Last Edit: July 06, 2019, 07:19:30 pm by pigrew »
Offline gamalot
  • Correct my English
    • Youtube
« Reply #8480 on: July 06, 2019, 05:54:20 pm »
Cool Purchase!
It is a 7-inch 1024x600 IPS display with a capacitive touch screen from Taobao.
https://detail.tmall.com/item.htm?spm=a230r.1.14.37.188a3fc8TSXCcf&id=591214164928&ns=1&abbucket=10&skuId=4065284305433
The following users thanked this post: Mr. Scram
Offline bitseeker
« Reply #8481 on: July 06, 2019, 06:38:09 pm »
I took a chance on an E9300A RF power sensor from eBay "for parts" at about $60. This is a 18GHz dual path diode-based sensor. So far, the connector gaged at 208.8 thou pin depth (seems good, looks like standard N is .208 deep while precision N is .207 deep.) and holds zero within spec, and properly cals. There is no public calibration guide that I can find, perhaps I will compare a siggen's output using another sensor against this one. I don't have a N-type cal kit, so I may measure gamma using a calibrated 3.5mm port with port extension as adapter removal. Gamma tables used to be printed on the sensors, but not with the E series. Is there a way to read the cal table from the EEPROM?
Amazing. I just assume all the "for parts" ones have fried diodes.
Online TheSteve
  • Living the Dream
« Reply #8482 on: July 06, 2019, 06:51:25 pm »
Power sensor gambling!
I have played that game twice and got lucky both times. I don't think I want to play again.
VE7FM
« Reply #8483 on: July 06, 2019, 10:23:27 pm »
Any pictures ? It's always nice to see the devices.   :D
I'll show you mine if you show me yours :)
This my variac, a Grundig RT5A:
And, to be ontopic, this has been arrived two days ago:
The following users thanked this post: Falkra
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #8484 on: July 07, 2019, 07:19:18 am »
Some cheap storage.
Amazon is doing a limited time offer today and Sabrent has a $255 2TB USB 3.1 NVMe SSD for sale, so I grabbed it.
The bare M2 drive itself is $220, also on sale. This is a TLC drive with 3115 TBW endurance, yet the price is comparable with Intel and Samsung's QLC drives.
Not a bad idea for a quiet local backup drive and video scratch disk.
https://www.amazon.com/dp/B07N15HD51
https://www.amazon.com/dp/B07MTQTNVR
How does it perform though...
I have actually never really used any TLC or QLC drives. All my SSD's, especially the better ones, uses MLC. I have heard that TLC and QLC has longevity problems and are much slower than SLC and MLC devices.
Offline exe
  • self-educated hobbyist
« Reply #8485 on: July 07, 2019, 07:40:42 am »
Wow, congratulations! I thought they are unobtanium.
Offline gamalot
    • Youtube
« Reply #8486 on: July 08, 2019, 03:59:37 am »
Using a Noctua 40mm cooling fan here seems like an overkill, even though I slightly overclocked it to 1.6GHz.
« Last Edit: July 08, 2019, 04:14:01 am by gamalot »
Offline Mr.B
« Reply #8487 on: July 08, 2019, 04:31:30 am »
@gamalot,
That’s not the first time I have seen that very nice little RH+T display in your posts.
Initially I wrote them off as some sort of free giveaway from Sensirion.
After a quick search on Mouser… I just ordered a couple.   >:D
I approach the thinking of all of my posts using AI in the first instance. (Awkward Irregularity)
Offline djos
« Reply #8488 on: July 08, 2019, 04:52:47 am »
After destroying my cheap Jaycar bench mat, while removing SMD components with my Hot air gun on the weekend, I finally ordered a hopefully decent mat from Amazon:
Bertech 2059T-18x30BKT ESD High Temperature Rubber Mat Kit with A Wrist Strap and A Grounding Cord, 18" Wide x 30" Long x 0.08"
Offline gamalot
    • Youtube
« Reply #8489 on: July 08, 2019, 04:57:48 am »
@gamalot,
Which manufacturer will send samples to unemployed people?  :-//
Fortunately, it is not very expensive.  :-DD
Offline McBryce
« Reply #8490 on: July 08, 2019, 07:06:41 am »
I didn't really buy this, rather it was in a box of random devices that I bought. Monacor FSI-117 - An SWR Meter / Dummy load with a few other tricks up its sleeve for the 11m enthusiast. It seems to work fine, but I don't do any radio and have no other uses for it, so it's just going to be a pretty ornament for now unless someone here wants it.
The picture isn't my one, but is in the same condition.
McBryce.
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #8491 on: July 08, 2019, 10:34:41 am »
Nice stash of fakes...
« Reply #8492 on: July 08, 2019, 11:17:13 am »
I got them from the same source where we examined one and they turned out to be genuine.
Offline JxR
« Reply #8493 on: July 08, 2019, 10:56:21 pm »
So I tried one of those places that can print and deliver a book to you from whatever you provide them.  I know one can get this particular PDF for free, but sometimes I just enjoy having a hard copy.  I'm very happy how it came out, and it was only about $15 + shipping.
Offline Mr.B
« Reply #8494 on: July 08, 2019, 11:46:45 pm »
Thats a pretty decent price.
But, why are the page numbers on the spine side of the page  >:D
Offline JxR
« Reply #8495 on: July 09, 2019, 12:01:56 am »
Haha, didn’t even notice that. It was just printed straight from the pdf document, so no editing was involved.  Tektronix probably wouldn’t like me editing their IP anyways, but just so I don’t try and sale copies of it, I doubt they care that I made a book from it.
Offline gnavigator1007
« Reply #8496 on: July 09, 2019, 01:34:44 am »
Would you mind sharing who you used for that? Can they bind as hardback too?
Offline JxR
« Reply #8497 on: July 09, 2019, 02:00:53 am »
It was: https://www.prestophoto.com
As to the hardback, I'm unsure. This particular one was printed as a "Textbook". When I originally looked at the Textbook options, there was one for hardback.  But after I uploaded the PDF and was  ready to check out, the hardback option was no longer there.  So, unsure if the PDF I uploaded didn't meet some kind of size/length requirement or what.
The following users thanked this post: gnavigator1007
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #8498 on: July 09, 2019, 04:37:47 am »
If you ever reprint that book, if you insert a single blank page (The old "This page intentionally left blank") at the start of the PDF (not a whole leaf, just a single page), it'll push the pages along one and put the numbers at the outer edge. ;)
The following users thanked this post: blueskull, gnavigator1007, JxR
Offline JxR
« Reply #8499 on: July 09, 2019, 07:14:56 am »
That is a good catch, but after examining the book closer, you do need more than one inserts before certain sections.  Sections 1/2 are fine (but only because I used second page as back cover), section 3/4 needs an insert, and section 5 is fine.  I just happen to take a picture from section 3 I think.  Also probably why I didn't immediately notice the page thing, since it looked fine from my first glance (and I just opened to a random page to snap a pic).
If that site would let me print a hardcover in A4, I might consider redoing it, but looks like 6"x9" is as large as they offer for "Textbook" printing. Just not interested in a smaller size. I looked at a couple alternative sites, but one was wanting ~$100 for a single printing.
Regardless the book has section headings on the outer-edges for nearly every page, so it really is a non-issue for me. If I consider printing another PDF though, I will be a bit more careful about the page numbering.
« Last Edit: July 09, 2019, 07:16:34 am by JxR »
