Author Topic: What's this please? (Component Advice)  (Read 1240981 times)
0 Members and 16 Guests are viewing this topic.
Offline kizzap
« Reply #300 on: April 29, 2013, 08:19:18 am »
Heh, yeah I know they were suss (or a con. take your pun ;) ). Replaced the six of them, and the monitor the board was pulled from works!   :-+ :scared:
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Offline G7PSK
  • It is hot until proved not.
« Reply #301 on: April 29, 2013, 12:29:33 pm »
Thats a good abbreviation for suspect condensers.
Telequipment
  • Guest
« Reply #302 on: May 13, 2013, 01:45:23 pm »
 most likely a Infrared sensor (infra red sensor- infra-red sensor- IR sensor). For use with PICAXE circuits to detect infra-red signals from a TV style remote control or another PICAXE chip. 2.7V to 5.5V operation.
Offline c4757p
  • adieu
« Reply #303 on: May 27, 2013, 04:21:27 pm »
I've got an insultingly simple one - what's the name of this? I bought them from god knows where on eBay, just called "2.54mm headers", and I want a name to put them in my component library under. They're ridiculously common, so someone's got to know a proper name for them!
duskglow
  • Guest
« Reply #304 on: May 27, 2013, 04:23:29 pm »
I dunno, I'd think "header" would be a perfectly appropriate name for it.
Offline c4757p
  • adieu
« Reply #305 on: May 27, 2013, 04:28:02 pm »
Would a "shrouded header" be enough? I didn't want to use 'header' because it's bigger than an unshrouded one, so it needs a bigger courtyard and thus a different footprint.
Offline orbiterTopic starter
  • -0 Resistance is Futile
« Reply #306 on: May 27, 2013, 05:05:28 pm »
Is it not just referred to as a 2.54mm Molex connector?
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
« Reply #307 on: June 02, 2013, 08:11:00 am »
http://www.jst-mfg.com/product/pdf/eng/eXH.pdf
JST "XH" connector. Spacing is 2.5mm (close enough to 2.54 that it doesn't matter unless you have a high pin count connector)
Offline wraper
  • Country: lv
« Reply #308 on: June 04, 2013, 10:40:14 am »
Does anyone know the name of this connector? Never seen that before. Guy from my work said that they received PH electrodes with such connectors but without any wires. I think it's some surplus, damn cheapskates. Now they don't know what to do with them.
Offline vk6zgo
« Reply #309 on: June 04, 2013, 02:45:24 pm »
It looks a bit like a Siemens coax connector.
Offline G7PSK
« Reply #310 on: June 05, 2013, 01:41:05 pm »
Any one know what this is please, the one on the left in the photo. with the sil pad, it says D288 on top and Y-920 at the bottom, one leg appears to be open and I am not sure if its a transistor or back to back diode, its from a scope power supply. Google does not come up with it but does with BD288.
« Last Edit: June 05, 2013, 01:49:28 pm by G7PSK »
Offline dr_p
« Reply #311 on: June 05, 2013, 02:01:56 pm »
http://www.svntc.com/TPDF/1272.pdf
When in doubt, add "2S" before the name of what looks like a transistor
Offline peter.mitchell
« Reply #312 on: June 17, 2013, 12:17:24 pm »
Anyone know what package this bridge rectifier is in?
I have a whole bunch of the I got a few years ago, decided to make something with them.
Offline madires
« Reply #313 on: June 17, 2013, 12:37:49 pm »
I think it's called GBJ. Really!
« Reply #314 on: June 17, 2013, 02:34:05 pm »
Holy crap, i thought that was part of the part number! I mean, you never see transistors in to-220 packages with to-220 written on them ect! I feel dumb :(
Offline madires
« Reply #315 on: June 17, 2013, 02:51:13 pm »
It's also part of the part number. Those bridge rectifiers are so common that the manufactures simply use the package, amps and voltage as part number.
Offline G7PSK
« Reply #316 on: June 20, 2013, 02:00:43 pm »
I need some tac switch extensions, but I do not know what they are called. I have a board which has a number of tac. switches on it that I want to mount in a case. I have seen these devises which mount on the case to make contact with the board mounted switches but no idea where to look as I do not know the correct name.
Offline Len
« Reply #317 on: June 20, 2013, 03:20:53 pm »
They seem to be called "extenders" or "plungers". Here's one:
http://www.digikey.com/product-detail/en/2S09-05.0/679-2201-ND/2034757
and here's a bunch more (not all for tact switches):
http://www.digikey.com/scripts/dksearch/dksus.dll?pv184=2918&pv184=469&pv184=2608&FV=fff40011%2Cfff80054&mnonly=0&newproducts=0&ColumnSort=0&page=1&quantity=0&ptm=0&fid=0&pageSize=25
DIY Eurorack Synth: https://lenp.net/synth/
Telequipment
  • Guest
« Reply #318 on: June 30, 2013, 05:05:04 pm »
Hello , I have this component here not sure what it is code is ITT RA15,it long glass tube, with two wires out of the base, there looks to be a filament, don't think it's a bulb, could it be a fuse,i first thought perhaps it is a reed relay, but the one's I have the wires are either end Help. ITT RA15
« Last Edit: June 30, 2013, 05:07:23 pm by Telequipment »
« Reply #319 on: June 30, 2013, 05:47:43 pm »
It is a thermistor unit, and is normally used in self heating mode to provide stabilisation of analogue circuits. They are commonly used in Wein oscillators to keep the loop gain constant and so generate a constant amplitude sine wave.
Another use is as a temperature sensor in amplifiers to keep the bias constant with external temperature changes.
http://www.murata.com/products/catalog/pdf/r44e.pdf
http://www.avx.com/docs/masterpubs/ntctherm.pdf
for more info.
Telequipment
  • Guest
« Reply #320 on: July 01, 2013, 05:03:51 am »
Thank you Sean, wondered what it was
« Reply #321 on: July 01, 2013, 04:29:53 pm »
I was going to use one when I made an ESR meter, but instead used a 28V grain of wheat leaded lamp instead as a PTC. Still have a few around in a box somewhere. I just had to look thorugh the box of assorted leaded lamps and test a few of the mixed ones to sort out a 28V one. Took 3V from 2 AA cells and tested lamps to find those that did not glow ( the glowing ones were the 5V ones) then tested the dark ones on 12V to get the non glowing again ( 12V lamps0 and finally checked them on 24V to see if they still worked. Took the first one and used it and put the rest back in the box mixed as before.
Offline G7PSK
« Reply #322 on: July 07, 2013, 09:20:15 am »
Hi I have a TO220 package on a chinese PWM motor controller labeled STPS205100CT,  G40N2 and CHN305 I have tried Google but cannot find any info on this device, in fact all it seems to bring up is dodgy Russian web sites with links to other even more dodgy Russian porn sites. Any one have an idea as to what this device is please.
Offline romovs
  • Country: il
    • My Personal Blog
« Reply #323 on: July 07, 2013, 09:51:37 am »
A ST power shottky diode?
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
