Author Topic: Siglent SVA1015X and SVA1032X 1.5, 3.2GHz Spectrum & Vector Network Analyzers  (Read 200545 times)
Online Bicurico
  • Country: pt
    • VMA's Satellite Blog
Unless someone does it through the serial terminal...
Offline Ghislain
Best if you just use the Cal kit you have and do the calibration and save it with a name that suits you.
Some tips in the Help file:
VNA>Meas setup>Calibration
Process is:
Select VNA mode.
Enter Calibration.
Select Cal kit>Next
Select User 1 or 2 and follow calibration steps.
Enter File menu.
Set to browse file.
Change View and Save type to Cal.
Press Save on the front panel and use the keypad to name your Calibration.
Example attached.
In use, Correction = ON
Am I correct in assuming that in such case, after the user calibration (OSLT) has been successfully performed, the status in the upper left of the screen would have to change to Cor (=calibrated)?
Now it shows --- regardless of what I do.
According to the user manual on page 76:
3.5.6 Calibration
Set calibration related items. The calibration status is displayed in the upper left corner of the screen.
The calibration status and display are as follows:
No calibration data --- (displayed in gray)
Calibrated Cor (displayed in blue)
Correction Off Off (displayed in gray)
Need to re-calibrate C? (displayed in blue)
Offline Noy
OK now backup script worked for me with another USB stick freshly formated fat32 with gparted and dd for .ADS ccopy..
Offline tv84
  • Country: pt
New telnet script for SVA1000X with latest FW.  TESTED OK
Port is 10101.
Edit: Should work with SVA1015X, SVA1032X and SVA1075X.
« Last Edit: February 08, 2021, 08:19:52 pm by tv84 »
The following users thanked this post: RoV, Ruthenium
Offline tubularnut
Can someone test this telnet script on SVA1032X with latest FW?
Port is 10101.
Yes , it works !!!  :D
The following users thanked this post: Ruthenium
Offline tv84
  • Country: pt
So simple...  |O Siglent changed the ProductID to 11410.
When I shared the NSP_config_upgrade_info.xml file with @nive I noticed the contents but it didn't sink into me. Then when I saw @techneut msg I had a flashback!
 :popcorn:
Offline tubularnut
Another beer I owe you  :-+
Offline tv84
  • Country: pt
What is most interesting is that now (with V3.2.2.4.0 FW), all the models SVA1015X, SVA1032X, SVA1075X have the same ProductID = 11410 !!!   ::)
Does that mean we can upgrade them all to 7.5GHz?!?  (Who wants to try?)
Does it mean they will differentiate them through other means?!?
Offline tautech
Check datasheets first.  ;)
Offline tv84
  • Country: pt
One thing is certain, from now on there will be only one FW package version for release.   :)
Online techneut
Could it be that they made the change in FW V3.2.2.4.0? That somewhere there is a type definition based on the ProductID before the software update and ID change?
Offline borjam
  • EA2EKH
Nah, I am sure they have different components, not just the RF circuitry. I think someone did a teardown of the SVA1032X comparing it to the SVA1015X?
Unless they release a new unified hw revision to simplify the supply chain? But I doubt it.
Offline tautech
Yep, 3 models in the SVA range each with different specs and even different instrument weights.
While flashing one to another may be possible it certainly won't meet datasheet spec.
Playing with fire certainly.  :scared:
Offline tv84
  • Country: pt
From now on, there won't be any more "flashing one to another" as the FW will be the same. If the HW allowed it, the only difference would be in a BW license.
The following users thanked this post: EE4all
Offline EE4all
If someone has crossflashed before this version though, it will still stick though, right?
Offline Ruthenium
Many thanks,  tv84  :-+  I just tried it on a SVA1015X,  all options unlocked.  FW 3.2.2.4.0.r2
Ony issue I can see is that there seems to be no spectrum display in RTSA mode?    That said it might be operator error.  Other modes are working fine.
Offline tv84
  • Country: pt
RTSA is not a SVA option. You see it because you "hacked" it.
The following users thanked this post: luudee, Ruthenium
Online techneut
New software:
SVA1075X Firmware – V3.2.2.4.0R2 (Release Date 02.08.21 )
SVA1015X Firmware – V3.2.2.4.0R2 (Release Date 02.08.21 )
SVA1000X Firmware RevisionV3.2.2.4.0R2 2021/2/09
Notice:This  firmware  must  be  upgraded  from  V2.1.1.1.12a  or  later.  If  your  SVA1000X  has  an  earlier version, please update to V2.1.1.1.12a first and then proceed to update to the latest version.
•This version can not be rolled back•
Fix the VNA option license error on some SVA1015X and SVA1075X units
The following users thanked this post: tautech, tubularnut
Offline EE4all
I am deciding between a SSA3021X+ and SVA1015X, and note that from my distributor they are within 100 dollars of each other right now. So the obvious choice is the SVA1015X. Is there any reason to even consider the SSA then? I will be playing around with it in telnet, features and 3G.
I am coming from an SSA3021X (non +), and a sdrkits VNA. I could consolidate to the one device.
« Last Edit: February 09, 2021, 07:42:28 pm by EE4all »
Offline tautech
1.5 GHz models are a different HW platform and therefore have some different specs.
For SA use you will be giving up some of the TG capability your SSA3021X has.......study the SVA datasheet.
Offline EE4all
Thanks for the heads up Tautech. I must need to find a better set of pages to look at, because SiglentNA lists tracking generator as standard for the SVA.  :-//
I only see that the SSA has a better DANL.
« Last Edit: February 09, 2021, 08:15:19 pm by EE4all »
Offline Pitrsek
  • Country: cz
Hi there, any idea why is the dynamic range for S21 measurement 20dB worse for SVA1032X than for SVA1015X? This is rather puzzling, especially since DANL is just a hair better for SVA1032X.
Offline tautech
SSA3015X Plus and SVA1015X have a different TG spec to all other models...did you not see that ?
5 MHz minimum TG and for SVA1015X VNA mode has a 10 MHz min frequency limitation whereas for all other models it is 100 KHz for both TG and VNA modes.
This can be a no go for some and not everyone spots it whereas I'd prefer them to all be the same but HW differences don't permit it.  :(
Better you know now and make good choices armed with this knowledge otherwise the instrument might not fully suit your needs.
https://int.siglent.com/u_file/document/SVA1000X_DataSheet_DS0701X_E04B.pdf
« Last Edit: February 09, 2021, 08:58:54 pm by tautech »
Offline tv84
  • Country: pt
That's a no-brainer: get the SSA.
Offline tautech
SSA Plus version.  ;)
