Author Topic: Pace ADS200 soldering station  (Read 382052 times)
Offline Cliff MatthewsTopic starter
    • General Repair and Support
Re: Newest Pace ADS200 production station (a JBC killer at $239??)
« Reply #650 on: July 22, 2018, 12:14:21 pm »
Some observations: TC500ACOE is not so costly, it lists as a $2.50 part (est. 1000's price). Date sheet header says designer can trade resolution for speed, but no more than 10sps. Marco Reps investigation shows unbuffered 120hz DC to the tip..
*edit - Opps forgot, here's the index to the point he made: https://youtu.be/erKCA71q7cg?t=843
« Last Edit: July 22, 2018, 12:20:01 pm by Cliff Matthews »
Offline exe
  • self-educated hobbyist
« Reply #651 on: July 22, 2018, 12:35:00 pm »
TC500ACOE
Wait, but that's not ADC. It's an ADC _frontend_. Now it's getting really weird...
You mean 100Hz? (He's in Germany, afaik, so should be 50Hz mains) Uhm, so, I guess, there is no control to fets at all, are they connected like this? https://electronics.stackexchange.com/questions/203315/storing-the-the-charge-from-a-mosfet-bridge-rectifier . But then I wonder why rectifying at all? Why not drive iron from AC?
« Reply #652 on: July 22, 2018, 12:54:41 pm »
There's also an ICL7660A to run +- 5V to that front-end..
Offline alank2
« Reply #653 on: July 22, 2018, 02:00:57 pm »
I don't know too much about these things, but when it comes to temperature regulation and PID loops, wouldn't more resolution/precision offer superior control, irregardless of the display?  Could the ADC resolution be primary there to drive control?  Maybe this is obvious..
Offline labjr
« Reply #654 on: July 22, 2018, 03:09:22 pm »
BTW, consider making a series of "performance tips" with better heat transfer (and shorter tip life). It's a win-win: 1) better performance 2) people will have to buy more tips from you if they want performance 3) less coating material used :)
Another idea: sell the station as a kit. I'd love to assemble one by myself.
I wonder if performance could be improved with a more aggressive ramp-up curve with a bit of overshoot. Or the ability to select different performance curves required for the task.
Kits would probably need too much support.
Offline nanofrog
« Reply #655 on: July 22, 2018, 04:57:34 pm »
In regard to selectable curves, Ersa does that on their i-Con 1/2/4 models.
Kits would be a horrible idea for Pace. Just way too much aggravation, potential damage to their reputation, and increased costs (they're not Heathkit, which is long gone).
Online tooki
« Reply #656 on: July 22, 2018, 06:09:47 pm »
All the i-Con series have that, even the nano and pico. (It’s configured via SD card, using the desktop app.)
Offline exe
« Reply #657 on: July 22, 2018, 07:30:18 pm »
Just watched Marco Reps's video. Afaik, there is no "active" rectification, just mosfets connected in "ideal diode" configuration. Which is fine.
The station switches heater at zero crossing. This means decisions are made at the rate twice the line frequency. So, in the worst case there is a delay of 10ms. Why I'm saying this? Just to say that even a slow SMPS would work just fine (I'm not sure they are really slow as some users report here). But, again, doesn't really matter.
Concerning display and other fancy features. It is true they are not essential for soldering. But noobs like me like them. So, it's just a matter of target market. Also would make possible to change profiles, preset temperatures, etc easier (ersa with configuration on sdcard is a joke).
I personally like rotating encoders with push button. Minimalistic and convenient.
« Reply #658 on: July 22, 2018, 08:15:59 pm »
Not so fast, take a look at 15:25 (https://youtu.be/erKCA71q7cg?t=843 ) bottom left is right under the mosfets. I couldn't get a good enough look at the tiny part number, but Z1 and Z4 could be dual zener's who's tab could be under uC control.
*edit - those are ZXMN4A06G n-ch mosfets, if that makes any sense (it might have been easier with p-ch?).
« Last Edit: July 22, 2018, 08:20:58 pm by Cliff Matthews »
Offline exe
« Reply #659 on: July 22, 2018, 09:13:45 pm »
There are two N-fets and two P-fets (yeah, they are different, hard to see on video, but part numbers slightly different, they are ZXMP, not ZXMN). I wasn't able to trace all the traces, but I think it's this bridge:
Looking at the video, it seems the station has more part than I expected. Still curious how they use adc frontend.
Offline nanofrog
« Reply #660 on: July 22, 2018, 09:21:19 pm »
I wasn't aware the SD card was usable for that.
Seems a bit of a PITA though vs. the rotary encoder with button operated menu system in the bigger siblings.
« Reply #661 on: July 22, 2018, 09:52:34 pm »
You have good eyes! I'm still curious where Vin for the 7805 comes from (it won't boot without it..) The body diodes?
*Edit - In future model updates etc..
If Pace considers a single transformer with dual winding's, they might consider internal wiring only, since a station incorrectly strapped for 120v on 240v would require 80v mosfets and good crowbar to protect (yet again another reason for SMPS as some have suggested).
« Last Edit: July 22, 2018, 10:12:11 pm by Cliff Matthews »
Online Alex Eisenhut
  • Place text here.
« Reply #662 on: July 23, 2018, 12:50:04 am »
I don't like how small the sponge cubby is. Solder blobs fly out all the time. The sponge is half the size of the Hakko 936's.
Really don't like this.
Offline Bud
« Reply #663 on: July 23, 2018, 01:23:50 am »
JBC sponge is also tiny.
  • Place text here.
« Reply #664 on: July 23, 2018, 01:25:55 am »
I probably wouldn't like it either.  :-DD
Offline Shock
« Reply #665 on: July 23, 2018, 01:44:36 am »
No brass wool holder on the Hakko 936 stand, so 90s ;)
Offline nanofrog
« Reply #666 on: July 23, 2018, 02:39:23 am »
If you'd rather use a sponge only, then why not just remove the brass wool box so you can install a larger one?
Or is there some technical reason preventing this that I'm not seeing in the photos?
  • Place text here.
« Reply #667 on: July 23, 2018, 11:02:58 am »
I don't know what came over me to do this this morning, but here we are. I'll finish up later.
Offline nanofrog
« Reply #668 on: July 23, 2018, 06:23:44 pm »
As promised, I got it today, but it looks like someone else is enjoying it ATM...
Finally uploaded a few photos. Here in the Post a picture of a cat! thread.
Offline KL27x
« Reply #669 on: July 23, 2018, 08:17:06 pm »
A company that does not have experience with encoders should not be using them for this. Months or years later, when the encoder wears in and the device becomes buggy or even unusable is too big a liability for this. Additionally, a rotary encoder just keeps spinning. A pot, you don't have to look at, which the pot is much preferable to me for a soldering iron control. (Absolute encoders are a thing; a very expensive thing). And finally, no matter how fast is your fancy micro, if you turn a given encoder too fast, it is going to miss steps.
Another problem is the issue of when the encoder actually fails. The parameters of an electric encoder are very specific, and they must be accounted for in the software. If the part can no longer be sourced 10+ years down the line, your station could turn into a paperweight, for practical purposes. Replacing with a different encoder even with the same number of detents could prove problematic due to different bounce characteristics and whatnot. Barring hours of tweaking and debugging and hacking. It may be possible to account for this in the software, in the first place, at least if your micro has speed and resources to dedicate to this. But considering how many devices I own where the designer can't even get the originally specc'ed encoder to work, properly, this is not realistic to just assume as a given. Having tinkered with encoders, myself (with less than 100% reliability, admittedly), I suspect to account for wider range of replacement parts, it might require significant compromise, such as in regards to max rpm that can be detected (at least without user interface to change parameters, which not only takes "work" for the user, but is going to be difficult to do when the only user input is not working).
Save encoder for navigating menu that is more complicated than temp up or down. It might look cool when Marco Reps does it. But anyone who were to rely on that station will eventually curse the design choice.
This is not a TS-100; nor is the TS-100 the future of soldering irons.  :)
« Last Edit: July 23, 2018, 08:50:27 pm by KL27x »
Offline exe
« Reply #670 on: July 23, 2018, 08:53:26 pm »
[skip]
I think you are exaggerating problems. Anyway, you can say the same about pretty much everything, including buttons. They can become obsolete, they miss pushes, you have to look at it, etc. Just buy parts with standard footprint from a reputable supplier, that's the secret. Reliability data is to be found in the datasheet.
BTW, there are other components that can become obsolete. Like, that ADC, etc.
That must be a really bad engineer not to be able to repair/replace the encoder. Such people shouldn't buy soldering stations :).
PS Do you propose to build all the equipment only with push buttons and 7-segment leds? Otherwise I don't really see the point. Most tools on my bench have screens, etc. I see no point replacing them with something without screens and encoders.
  • Place text here.
« Reply #671 on: July 23, 2018, 10:17:59 pm »
The Alex Edition. Not bad huh?
Warranty void, huh?
Offline PACE-Worldwide
    • PACE Worldwide Website
« Reply #672 on: July 23, 2018, 10:20:24 pm »
Warranty void, huh?
YEP, I'm tellin' on you ...!  ;)
Online tooki
« Reply #673 on: July 23, 2018, 10:23:01 pm »
I think it’s on purpose, so that in production it can’t be dicked around with.
This post (which is actually a reply from me to you in another thread! :p)  has a screenshot of the software for the nano/pico so you can see the options.
[Edit: corrected URL]
« Last Edit: July 24, 2018, 12:14:41 am by tooki »
Offline nanofrog
« Reply #674 on: July 23, 2018, 10:37:46 pm »
Warranty void, huh?
:-DD
Much nicer solution than splicing the ISB cable.  :-+
Perhaps PACE could sell an extension cable for those that need it?
Could well be the reason they went that way vs. a USB port.
No explanation of Energy that I saw in the screenshot, but I presume there's a README file that comes with the software and/or thoroughly spelled out in the manual.
