Author Topic: What did you buy today? Post your latest purchase!  (Read 5260498 times)
0 Members and 78 Guests are viewing this topic.
Offline G7PSK
  • It is hot until proved not.
« Reply #6900 on: August 01, 2018, 08:27:36 pm »
I just took delivery of a brand new Pace WJS with instant set back station, turned it on so far and tinned the tips and that's all so far not tried any soldering yet.It  is at least twice the weight of the circuit specialists unit that I have been using to date, but it is nearly twice the wattage.
Offline tautech
« Reply #6901 on: August 01, 2018, 11:09:44 pm »
I bagged this on Ebay today, will require a lit bit of cleaning but it all seems to be working just fine.
Can't wait now for it to be delivered now so I can set to and bring it back to its original condition.
It'll probably clean up well with just warm soapy water and a very gentle scrub.
If you pull the knobs you can clean them in a basin but watch not to get any water inside the front panel with them off.
« Reply #6902 on: August 01, 2018, 11:27:23 pm »
Had a quick look at the specs for the 1002 and it mirrors the 210 until you get to the automatic measurements and the screen brightness, the 1002 offers slightly more in both areas but will run slightly hotter because it consumes another 10W. was it really worth the redesign or is the circuitry significantly better and more reliable as a result I wonder? :-//
Offline tautech
« Reply #6903 on: August 02, 2018, 12:30:05 am »
There was a time when there must've thousands of 1002's in EDU use, I'll ask you why that might have been ?  ;)
« Reply #6904 on: August 02, 2018, 12:35:09 am »
Because the old scopes that they were using prior may have been analogues and they just made the decision to swap over to DSO's at the end of their planned life and that just coincided with the release of the 1002 model? :-//
Offline nanofrog
« Reply #6905 on: August 02, 2018, 03:47:39 am »
Tektronix is also known for pushing their wares heavily in the education market. So that may have had something to do with it as well.
Offline Zucca
  • EE meid in Itali
« Reply #6906 on: August 03, 2018, 07:10:56 am »
the print time counter had only 7 hours on it.
It should then works for the next 7 hours at least...
Hope your fix will last.  :D
Offline pigrew
« Reply #6907 on: August 03, 2018, 09:47:54 pm »
This is more of a "what did I find in the lab today"?
Amphonel 132360 (901-10106 seems identical) is a SMA plug rated at 500 connections where the nut does not turn with respect to the pin. This damages the female connector, right? Why would they sell such a thing?
(What I actually bought today is a rod of stainless steel that I'll try to machine into a replacement gage pin for a N-type Maury gage kit I got from eBay.)
« Last Edit: August 03, 2018, 10:13:39 pm by pigrew »
Offline thm_w
  • Non-expert
« Reply #6908 on: August 03, 2018, 10:43:59 pm »
I see some of a similar style used here to plug the non-connected port on a wifi router. You would only screw it on once and then never touch it again. Its probably a few cents cheaper to build.
Offline Circuitous
    • Corgi-Tronics
« Reply #6909 on: August 04, 2018, 02:04:57 am »
FedEx ground dropped off a new chair for the lab... a Herman Miller Aeron Stool, extra tall!
https://www.hermanmiller.com/products/seating/stools/aeron-stool/
I've had a regular Aeron in my office for 16 years, and it's still comfortable.  So, why not get one for the lab too?
« Last Edit: August 04, 2018, 02:07:39 am by Circuitous »
Offline MattSR
« Reply #6910 on: August 04, 2018, 02:23:54 am »
Love those chairs!!
Offline HighVoltage
« Reply #6911 on: August 04, 2018, 07:50:36 am »
This is a really good looking lab chair.
Do I see it right, the price is $1,129 ?
Offline Kjelt
« Reply #6912 on: August 04, 2018, 08:08:39 am »
Beautifull chair. Looks spacey and comfy  :-+
My floor is cluttered so I can't get to the other side of the room,
I need a rail system on the ceiling and the chair attached so it floats over the clutter  :-DD
Offline bob225
« Reply #6913 on: August 04, 2018, 04:14:11 pm »
Did it come with minimalist Herman miller packaging with the handles on the box torn out ?
« Last Edit: August 04, 2018, 04:15:58 pm by bob225 »
Offline innkeeper
« Reply #6914 on: August 04, 2018, 04:19:56 pm »
how did you get it to stick to the wall like that  :-DD
Hobbyist and a retired engineer and possibly a test equipment addict, though, searching for the equipment to test for that.
Offline Circuitous
    • Corgi-Tronics
« Reply #6915 on: August 04, 2018, 10:36:58 pm »
Yep.  The box was barely holding together, but nothing inside was damaged, so they must have it figured out.
I think I have the chair properly adjusted now... my back will let me know tomorrow.
Offline Circuitous
    • Corgi-Tronics
« Reply #6916 on: August 04, 2018, 10:42:31 pm »
The fully kitted out Aeron stool, with the full height, and all the adjustments comes in around $1,400 delivered.
Some places will sell for a little less than others, but then charge more for shipping, some have free shipping.  It takes about 3 weeks from ordering to delivery.  In my case, it was due to ship 4 weeks after ordering, but actually arrived at about 3 weeks.
Description:
Aeron Stool - Bar Height, Tilt Limiter with Seat Angle Adjustment, Fully Adjustable Arms, Standard Armpads, Adjustable PostureFit SL Support, Graphite, Graphite Chassis & Foot Ring / Graphite Base, 2.5-inch Hard Floor or Carpet Roll-Away Resistant Casters with Quiet Roll Technology, Black, 8Z Pellicle Graphite
Offline nanofrog
« Reply #6917 on: August 05, 2018, 03:54:19 am »
Very nice.  :-+ Unfortunately they come with a rather high price tag and then some. Looked at the satin aluminum w/ fixed arms & carpet + hardwood floor casters; came out to ~$1400 IIRC.  :o  ;D
Offline rdl
« Reply #6918 on: August 05, 2018, 04:24:52 am »
That looks just like the chairs at NASA Mission Control.
Offline VK5RC
« Reply #6919 on: August 05, 2018, 07:03:16 am »
I broke my favourite little metal poker/spludger thingameebob. It was nice in that it had a metal point on one end and a flat metal surface on the other - really useful little thing. A decent diameter plastic handle.  Ended up having to buy an entire kit of "iPhone repair Kit" to get something similar - I am half tempted to repair it.  |O
I can't really complain as it was part of an el cheapo "Beginners Soldering kit" I have had for 25+yrs - just don't make things like they used to!! :blah:
Offline TheSteve
  • Living the Dream
« Reply #6920 on: August 05, 2018, 08:07:25 pm »
Picked this up for cheap off of Craigslist, it needs some TLC, has a bad ballast and dead/dying/missing cool fans. Was also so green on the sides you couldn't see into it. Poor little clowns.
I'm thinking of naming them TiN and Carlson.
Nothing like moving 770 pounds to wear you out.
I am already pondering a full LED conversion, raspberry pi control/monitoring and a 24/7 live webcam.
VE7FM
Offline bitseeker
« Reply #6921 on: August 05, 2018, 10:58:58 pm »
Cool. Sounds like TiN and Carlson are going to have one high tech home, soon.
Offline vk6zgo
« Reply #6922 on: August 05, 2018, 11:55:51 pm »
That reminds me of when NASA closed their Carnarvon tracking station.
Serendipitously, Radio Australia was looking for a new site to replace the badly damaged Cox Peninsula
Station following Cyclone Tracy, & took over the building & surrounding property.
NASA took most of their stuff away, but Telecom Australia, who operated the Radio stations for RA managed to score several of the very nice chairs, which had pride of place in their control room.
There were a number of unused offices, which looked like their previous occupants had just walked away one day.
There were comments about various missions written with chinagraph pencils on some of the glass partitions.
Really quite eerie!
Offline BravoV
  • +++ ATH1
400V capacitors
« Reply #6923 on: August 06, 2018, 07:35:03 am »
Bunch of 400 Volt caps, used but all cap's capacitance are tested by my self, brand new is about > 100 bucks a pop, but these are really dirt cheap, about 2 bucks, couldn't stand it not grab them.  :palm:
Total capacitance, 22.200 uF (0.0222 mF) 400 Volt caps.
As usual, shot with TO-220 as reference size.
« Last Edit: August 07, 2018, 02:40:48 am by BravoV »
Offline nanofrog
« Reply #6924 on: August 06, 2018, 10:17:52 pm »
BravoV -- You SUCK!  :-+
