Not much time available today, only able to try single board with full components. The result is acceptable but there are some anoying pick failed issue, still need some adjustment. I make some notes of the feeder issue:
- the feeders had some play, the pocket hole is not always on the same position - need several trial to get the right pick position, using small nozzle will help.
- thick components in 8mm feeder is hard to feed, need to remove (or replace) the white plastic base (mentioned before by TheSteve).
- the feeder box and peel box have to be perfectly inline, if not the peeled cover will tend to shift and later failed to peel.
- the rear feeder can not be aligned using camera, have to use the nozzle and your eyes
- pick height default is 0.5 mm, let it be like that just change the placement height as required
- seems it is not possible to use more than one nozzle to pick parts from the same feeder (correct me)
- seems the feeder spit too many components on pick fail retry (no setting for that)
I'm curious to know how you determine the measurements you've made.
You said in a previous post that the machine/board measurements are out by 0.2mm per 100.0mm. Where are you measuring these points from and by what means?
I write coordinates of some points on the pcb from the CAD then put the pcb on the machine, navigate and write the corresponding points coordinates of the machine, then calculate it like below.
![](http://s20.postimg.org/d543p6yel/Measure.jpg)
This way will only find the difference, not telling which one is true. I will try this again on my older machine later, should be interesting as that machine use 2um resolution linear encoder feedback (Renishaw RGH41G).
Out of curiosity: Are the PCBs fixed or clamped down while on the conveyor? Or are they only hold by friction and can move more or less freely (longitudinal and/or transversal)?
The pcb pressed by some spring through the belt on the conveyor (you can see it on "machine stup" video), held firm enough on position.
-ichan
