Author Topic: Pick and Place Machine TVM802A / TVM802B  (Read 467474 times)
0 Members and 23 Guests are viewing this topic.
Offline rx8pilot
Re: Pick and Place Machine TVM802A / TVM802B
« Reply #525 on: October 04, 2016, 08:53:19 pm »
I just have a cutoff switch that I can set to turn off at just under 29in and turn on when it gets to around 22in. It also has a continuous switch but I have never needed it. I use the same vac system for my various pickup tools and to de-gas silicone and polyurethane for over molding cables.
Offline harry4516
    • www.dj0abr.de
« Reply #526 on: October 04, 2016, 09:05:16 pm »
@rx8pilot , @harry4516 , @ar_systems
Would this vacuum pump do the job? They go for US$100 shipping included..
https://www.aliexpress.com/item/FY-1H-N-150W-1L-Lightweight-portable-air-compressor-vacuum-air-pump-for-vacuum-LCD-separator/32736004424.html?spm=2114.13010208.99999999.304.2cWg7z
Also do you need some kind of regulator to limit the vacuum or will the air valves(solenoids) be okay without it?
this is the same pump as mine. It works ok.
It blows out a fog of oil, you need to separate it from the PnP machine.
I have connected a tube which goes out of the window.
Maybe an oil free pump is a better choice.
@rx8pilot: what size is your storage tank ?
Offline rx8pilot
« Reply #527 on: October 04, 2016, 09:15:11 pm »
I think it is about 10 gallons.
Offline uncle_bob
« Reply #528 on: October 05, 2016, 11:22:12 am »
Hi
I suspect that a two stage oil pump is a bit overkill :)
Bob
sure, this is overkill,
previously I had a membrane pump of the same size. It had two problems. The engine got very hot after a minute and it only started at normal pressure, not if vac was already there.
The new pump costs about $250 and stays cold even after 10 minutes.
Hi
In this application the difference in pump down between a single stage and a double stage pump is likely to be unimportant. They both will get past 29" with no trouble at all. The single stage (possibly of questionable quality) can be had for < $80 in the same ~ 3 to 4 CFM pumping capacity.
Bob
Offline protoneer
« Reply #529 on: October 06, 2016, 10:48:52 pm »
Could it be that you over filled the oil?
I am tinkering with the idea of adding a pressure sensor. Something like this: http://www.mouser.com/ds/2/302/MPXV7002-783439.pdf
Just to get a sense of that the machine is doing.
The more I think about it, if I can get the machine to report an error with the smaller components it would save me plenty of time baby sitting the machine. (It works great on bigger components to the point that I can work on other stuff while it does its job and when there is an issue it just stops)
Offline protoneer
« Reply #530 on: October 06, 2016, 10:51:36 pm »
Does anyone know how many pressure sensors the machine have and where they are located?
(I have about 12 hours of work booked for the machine before I can poke around under the hood)
Offline uncle_bob
« Reply #531 on: October 06, 2016, 11:12:00 pm »
Hi
*IF* you want the machine to report a very small part missing (with a pressure sensor)  ... you need a low volume vacuum pump.
*IF* you want the machine to pick up and hold a very small part ... you need a high volume vacuum pump.
Essentially you have two requirements pointing you in opposite directions. As the nozzle gets smaller and smaller, the flow through that nozzle (when open) gets less and less. With a high enough volume pump, the entire pressure drop would be at the nozzle (for a really small nozzle).
An alternative is to detect flow rather than pressure. You can also check for the part with a camera.
Bob
Offline harry4516
    • www.dj0abr.de
« Reply #532 on: October 06, 2016, 11:26:22 pm »
exactly, thats the problem.
The yuki-503 nozzle (which is the right nozzle for 0603 parts) works with pressure sensor and the original vac pump very well. It detects if a part is missing.
With my new strong vac pump pressure detection does not work any more, so I use the yuki 504 with a larger hole. I placed a few boards and it works well with 0603 parts. This is a big advantage because the TVM802 has two nozzles only.
Previously I used the 503 and the 505, now the 504 and the 505. The better vac let me use a broader range of different components.
Also, I had big problems with SOT23 before (jumping and rotating on the nozzle while travelling), this problem is solved with the better vac.
Harry
Offline protoneer
« Reply #533 on: October 06, 2016, 11:52:16 pm »
Harry
Thanks for pointing out the high vs low flow.
I have ordered the stronger Vacuum pump so that will solve one issue. My TVM802A does not have Juki Nozzles but I have seen a few adapters that might fit. Will give that a go.
Out of interest @harry4516 , what size Juki Nozzle would you use for 5050 led's?
Offline ar__systems
« Reply #534 on: October 07, 2016, 05:39:45 am »
It has two pressure sensor on the bottom side of the circuit board that is screwed to the top of the block.
Both are semiconductor transducers, however schematics is extremely basic. There is no calibration of the sensors, and there is no threshold adjustment.
On my machine I don't have a problem with it not seeing 0603 missing. I think on my machine it is too sensitive even with external pump, and dumps parts that look like picked up relatively ok.
Offline ar__systems
« Reply #535 on: October 07, 2016, 05:51:44 am »
Hi
[/quote]
That's not true. You just need a pressure sensor with adjustable threshold.
Offline uncle_bob
« Reply #536 on: October 07, 2016, 10:59:29 am »
Hi
[/quote]
Hi
As long as you have a pressure sensor that has a perfectly stable threshold, an very small hysteresis, and a set point that will adjust to very close to 29.x" of vacuum .... yes that is correct. With practical sensors, you do indeed have a compromise for very small nozzles.
Bob
Offline Koen
« Reply #537 on: October 07, 2016, 02:57:58 pm »
Hello, what do you guys recommend to make sure the nozzle picked a part at our DIY level ? Vision, a particular pressure sensor, lasers ? Thank you !
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #538 on: October 07, 2016, 03:05:03 pm »
Vision is the best value for money, as it gives you both alignment and mis-pick detection. Any pick & place without vision is just a  toy.
Day Job: Mostly LEDs
Offline SPY GUY
  • Country: cy
« Reply #539 on: October 07, 2016, 04:23:54 pm »
IMHO it seems that the same thing is required.
Both based on taking an analog output from a sensor such as listed and converted into a digital output based on comparison input from a user adjustabe threshold value.
1) The softwares digital pressure sensors detect input.
2) The reservoir pressure that can control the internal or external Vacumn pump(s).
This can easily be achieved via a very basic micro controller with A to D's and coffee break coding, or even with just basic comparitors.
Not so much an analog person myself.
You could even get more fuity with a micro that has TCP/IP input that then applies different vacumn values for 1) based on watching co ordinates.
just my humble 2C's worth
Offline huebsch
  • Country: at
« Reply #540 on: October 07, 2016, 05:31:17 pm »
Folks!
I reported severe problems with the TVM802A powered by W10 about 2 weeks ago. Based on recommendations in this forum I installed a new PC with plain W7 patched it up to the most recent level and started testing. The PC is a 2GB ATOM box which just went out of use. The program does not need much PC power. To make a long story (calibration) short: it works with almost no problems. I have some error messages when I accidentially klick outside the controller program. This does not cause any wrong movements which I had before. I ordered new nozzles as the current ones might got damaged - or I'm not quite sure about them. Sometimes they drop components even speed 50% speed. I do not want to use vision on 1208 resistors.
It's really worth the time to invest time on calibration. Unfortunately I'm still trying to find out what some of the values in the software mean. We should compile some advices on this to help others.
Next upgrade is a touch screen. I used a mouse and later a touchpad keyboard to save space. But when I'm at the machine it might be easier to touch the screen. Especially some confirmation windows are quite annoying. I still have the problem, to stop the machine with the keys on it. So I frequently change back to the computer -> my idea to connect a touch screen.
Arnold
Offline harry4516
    • www.dj0abr.de
« Reply #541 on: October 07, 2016, 09:02:12 pm »
...Sometimes they drop components even speed 50% speed. I do not want to use vision on 1208 resistors...
I had the same problem, it was caused by the poor vacuum (in combination with the level of vibrations). I solved that with an external vac pump.
regarding 1206... after some experience you will use vision for all components. Take more time but need less manual corrections.
Offline tmf
« Reply #542 on: October 08, 2016, 12:19:27 am »
After I align with 2 fiducials I ask the machine to go to say (0,0) I then make note of it, I then move 6.000 inch to the right and it moves 6.014.... I have verified this time and time again, then a 6.000" move in Y and its off approx 0.014" again...... + 0.3 to 0.4mm both axis
I have also tried to not use the fiducials, do not enable them.... and still the same thing....
The 2 point I am moving between on the PCB are exactly correct!
I think the pixels per inch calibration must be off, how do you calibrate this??
Or???
Thanks.
Richard.
Man of many hats :-)
Offline thommo
« Reply #543 on: October 08, 2016, 07:38:49 am »
TFM,
I'd contact the guys at QiHe.
A mate of mine who owns a TVM920 had the same issue.
The gave him an updated version of the App. which rectified it issue immediately.
Good luck - Peter
PS: perhaps one of the other guys may have a later/est version they could send you.
Don't know about the 802, but the 920 has provision to calibrate this and reconfigure.
Offline harry4516
    • www.dj0abr.de
« Reply #544 on: October 08, 2016, 02:20:55 pm »
my software for the TVM802 is: Version 2.12
Offline huebsch
  • Country: at
« Reply #545 on: October 08, 2016, 02:30:23 pm »
Hello!
My SW Version of TVM802 is 2.23Beta2. If somebody wants to have it I can put it on a public space.
Arnold
Sorry folks there was a typo in the version I modified the posting
« Last Edit: October 08, 2016, 03:28:01 pm by huebsch »
Offline tmf
« Reply #546 on: October 08, 2016, 02:47:57 pm »
That would be nice.... mine is 2.23beta2 and they sent me the "solution" but when you goto the screen that has the config its missing! So they are probably talking about a newer version.... (you did mean 2.32beta2 or did you mix up 2 characters)
Please let me know when you upload.. looking forward to it!
Thanks!
« Last Edit: October 08, 2016, 02:56:10 pm by tmf »
Offline tmf
« Reply #547 on: October 08, 2016, 04:41:00 pm »
china just sent me 2.27 and it wont even home!  |O
RichardS
Offline huebsch
  • Country: at
« Reply #548 on: October 08, 2016, 04:46:43 pm »
No good news. But how have you got access to the update?
-AH-
Offline harry4516
    • www.dj0abr.de
« Reply #549 on: October 09, 2016, 12:06:44 am »
instead of mailing bad updates QiHE should release the source code.
The community could fix the problems in a very short time.
I think thommo from Australia is in close contact with these people. Could you talk about it ?
