My mother today emailed me that she considers the LM399 thermography movie by Andreas and branadic "art"
FYI there are LM399 (NS) on the bay at $4.60. I bought some a few months ago and they where OK, even if I have not done any deeeeep measurements on them. Seller Polida2008. I have no affiliation whatsoever.
A temperature difference of 1°C between the two leads of the reference will generate about 30 ?A.
Keep lead lengths short.
Ok, I have finally evaluated the measurements = .csv tables of Branadic from the LM399 thermograpic measurement.
Long leads without slot: around 5 degres stray within pad + 1,7 degrees from pad to pad
Long leads with slots: around 5-6 degres stray within pad + 2,3 degrees from pad to pad
Short leads without slot: around 9-11 degres stray within pad + 3,1 degrees from pad to pad
short leads with slots: around 12-15 degres stray within pad + 6,6 degrees from pad to pad
So from the measurement the conclusion is that with long leads the stray (=thermoelectric voltage) within pad is lower than with short legs. And the thermoelectric voltage between different pads is lower without slot.
If there should be mechanical issues the slots should be at least around 15 mm from the reference to give the pads the possibility to equalize the temperature.
To your sudden die of the reference:
It is winter. Perhaps you have zapped it by ESD.
(I have always to think of the "sweet spot voltage" between unheated and heated device.)
I tried to improve the resolution of this measurement by using another 7V reference on a different supply.
10 Zeners in series (70V) would also violate the max 40V spec of the internal diode if the heater is supplied from a common source.
What kind of supply?
And also linear supplies may have some 10 to 100 pF (parasytic) capacities.
Zener current is set to 4.5 mA ( in datasheet it is set about 1mA )
Wow, cool. You did more progress on this module, that I had
Would be happy to see it in good use with some measurements.
There is no advantage in setting the zener current above 1 mA.
(see statement of Ken).
Maximum stability of LM399 will be at 1 mA.
With best regards
Andreas
@Plesa #334,
You should be using either Bourns 3250 or 3290 wire wound pots (these are military qualified) if you want long term stability, film type pots are not nearly as stable over the long term (2-3 years compared to decades) and also require a minimum amount of current to flow through the wiper to keep it in 'good shape'. The WW pots do not really have to have any current flowing in the wiper but 1uA-3uA is suggested. The Vishay 1280G pots may have a bit better resolution but they are not nearly as stable long term and also cost a lot more than the WW pots.
The main drawback of the LM399/A references is noise compared to the LTZ references, about 4-5 times higher but at the same time they can be just as stable over time as the LTZs. If your application does not need the lower noise level of the LTZ then the LM399/A is certainly the lower cost way to go. As Bob Dobkin said, the higher current level does reduce noise but increases drift, there is no way around that tradeoff, if a little higher drift is okay then you are set with the higher current but noise is a very important spec and sets the minimum accuracy floor of the reference, you cannot filter the noise out from a zener so if you need low noise you must start with a low noise source.
I surprised how stable it is during burnin period (<1ppm).
